    Meta commands
    Gcode meta commands
    2.1k
    • jens55undefined
      jens55
      Please forgive the stupid question but why is the following section in a macro causing an infinite loop ?
      while true
        if iterations < 10
          m118 s"hello world"
          g4 s2
          continue
      abort
      alankilianundefined 1 Reply Last reply Reply Quote 0
      • alankilianundefined
        alankilian @jens55
        @jens55 You want to rewrite the logic of that code using a 'break' statement instead of a 'continue' statement.
        'continue' causes the loop to go back to the top of the loop.
        'break' causes the loop to be exited.
        Maybe something like this? (UNTESTED)
        while true
          m118 s"hello world"
          g4 s2
          if iterations > 9
            break
        abort
        From HERE:
        A loop may contain one or more break statements, which would normally be inside if-constructs:
        while <boolean-expression>
          if <boolean-expression>
            break
        The break statement transfers control to the line following the end of the loop body.
        A loop may also contain one or more continue statements, which would normally be inside if-constructs:
            continue
        The continue statement increments the iteration counter and transfers control back to the start of the loop, ready to evaluate the while-condition again.
        • jens55undefined
          jens55
          Thanks for that but I still don't quite understand. From what I understand (yeah, very little), the 'continue' statement does go back to the top like you said but the block that has the 'continue' statement is in the loop of 'if iteration < 10.' So in my thinking, if iterations gets to 10, that 'if' block fails and the next executed statement should be 'abort' .... ????
          DanS79undefined alankilianundefined 2 Replies Last reply Reply Quote 0
          • DanS79undefined
            DanS79 @jens55
            @jens55
            It's just a guess, but since no commands are being run when the if statement fails interations might not get incremented (maybe a bug).
            As a developer I'm not sure i like the concept of an iterations variable.
            the documentation says this about it.
            iterations - The number of completed iterations of the innermost loop
            If you have nested looping structures it could get difficult to follow the code.
            if i have all the syntax correct, something like this is more standard in the software development world.
            var cnt = 0
            while cnt < 10
                set var.cnt = cnt + 1
                m118 s"hello world"
                g4 s2
            jens55undefined 1 Reply Last reply Reply Quote 0
              alankilian @jens55
              @jens55 said in Meta commands:
              You can take that 'continue' statement out completely and see that the macro runs just the same.
              Every time the interpreter gets to the end of the loop it will jump back to the top of the loop.
              So when the 'if' statement is not true, the interpreter does go to the next 'statement'. If there are no more statements in the loop, so it goes back to the top.
              This might be a better way to do the loop and make it more understandable to you.
              while iterations < 10
                  m118 s"hello world"
                  g4 s2
              Or this might make it even MORE clear (I tested this one!)
              m118 s"Starting the loop"
                    m118 s"hello world"
                    g4 s2
              m118 s"Done with the loop"
              8/12/2021, 2:27:26 PM 	Done with the loop
              8/12/2021, 2:27:24 PM 	hello world
              8/12/2021, 2:27:22 PM 	hello world
              8/12/2021, 2:27:20 PM 	hello world
              8/12/2021, 2:27:18 PM 	hello world
              8/12/2021, 2:27:16 PM 	hello world
              8/12/2021, 2:27:14 PM 	hello world
              8/12/2021, 2:27:12 PM 	hello world
              8/12/2021, 2:27:10 PM 	hello world
              8/12/2021, 2:27:08 PM 	hello world
              8/12/2021, 2:27:06 PM 	M98 P"0:/macros/000_test"
              Starting the loop
              hello world
              • jens55undefined
                jens55 @DanS79
                @dans79, agreed, that is the way I am used to program a loop and yes, nested loops will be a nightmare.
                  alankilian @jens55
                  Why?
                  Each loop gets its own iterator (which is what iterators ARE) so everything works out.
                  while iterations < 3
                        m118 s"hello world first"
                          m118 s"hello world second"
                            m118 s"hello world third"
                  8/12/2021, 2:57:50 PM 	M98 P"0:/macros/000_test"
                  Starting the loop
                  hello world first
                  hello world second
                  hello world third
                  hello world third
                  hello world third
                  hello world second
                  hello world third
                  hello world third
                  hello world third
                  hello world second
                  hello world third
                  hello world third
                  hello world third
                  hello world first
                  hello world second
                  hello world third
                  hello world third
                  hello world third
                  hello world second
                  hello world third
                  hello world third
                  hello world third
                  hello world second
                  hello world third
                  hello world third
                  hello world third
                  hello world first
                  hello world second
                  hello world third
                  hello world third
                  hello world third
                  hello world second
                  hello world third
                  hello world third
                  hello world third
                  hello world second
                  hello world third
                  hello world third
                  hello world third
                  Done with the loop
                  DanS79undefined 1 Reply Last reply Reply Quote 0
                  • DanS79undefined
                    DanS79 @alankilian
                    @alankilian said in Meta commands:
                    Why?
                    They are all called iterations.
                    If use want to use multiple of them to set a variable, the code would be very hard to read (assuming scoping even allows you to access all of them).
                    The following would be real confusing to follow if you replaced a, b, and c with iterations .
                    var x = 0
                    var a = 0
                    var b = 0
                    var c = 0
                    while a < 10
                        set var.b = 0
                        while b < 20
                            set var.c = 0
                            while c < 40
                                set var.x = (a * b) - c
                                set var.c = c + 1
                             set var.b = b + 1
                        set var.a = a + 1
                      alankilian @DanS79
                      @dans79 Yeah, there are a thousand wrong ways to use a programming feature for every right way to use them.
                      • jens55undefined
                        jens55
                        I think we are drifting away from the part that I am having problems with which is why the particular construct I was using was having issues. Yes, there is a way to change things but WHY is it needed.
                        Here is a different way of going:
                        This works:
                          m118 s{"hello world " ^ iterations}
                          g4 s2
                          continue
                        This gives:
                        Error: in file macro line 6 column 11: meta command: 'continue' was not inside a loop
                        ;  m118 s{"hello world " ^ iterations}
                          g4 s2
                          continue
                        The commented out line seems to dump the 'continue' statement outside of the loop and seems to me to be a bug in interpretation.
                          alankilian @jens55
                          @jens55 You don't need to add a 'continue' statement at the end of a loop.
                            alankilian @jens55
                            You need to be very particular with the left-side whitespace to keep things working.
                            The interpreter is going to look at how many tab (or space)?) characters you have at the beginning of every line to know where the end of the loops are.
                            Your commented-out line starts with a semicolon in column one which tells the interperter that's the end of your while loop.
                            So, the 'continue' statement is not outside of the loop.
                            • jens55undefined
                              jens55 @alankilian
                              @alankilian, I realize that .... but what I am getting at is that something is fishy about how this is interpreted. While I don't need the 'continue', there should be nothing barring me from using it. It isn't inherently wrong.
                                alankilian @jens55
                                @jens55 That semicolon in column-1 causes the interpeter to end the while loop.
                                This works:
                                  g4 s2
                                  continue
                                • jens55undefined
                                  jens55 @alankilian
                                  @alankilian, I will test that but the semicolon is there to comment out the line and should not cause this reaction.
                                    alankilian @jens55
                                    @jens55 This works to keep the whitespace:
                                      g4 s2
                                      continue
                                    • jens55undefined
                                      jens55 @alankilian
                                      @alankilian
                                      Ahhhh, I need the spaces before the comment .... ok but that s a bug in the interpreter
                                        alankilian @jens55
                                        This post is deleted!
                                          alankilian @jens55
                                          From the documentation:
                                          The body ends just before the first line that is not indented.
                                          So, it could be argued that the interpreter is working fine.
                                          It's not up to me to decide.
                                          I'm happy you're getting going on your project again.
                                          And I learned some things from this discussion, so thank you for that also.
                                          • jens55undefined
                                            jens55
                                            Here is another example of strange behaviour:
                                            while true
                                              if iterations < 10
                                                m118 s"hello world"
                                                g4 s2
                                                continue
                                            break
                                            This executes but leaves the printer in a 'busy' state
                                            Without the 'break' command it does the same
                                            If I move the 'break' command to the right by two spaces, everything finishes ok - it breaks out of the loop
                                            Point is, there is no such thing as an 'endif' to clearly identify where the 'if' statement ends. IMHO there should be (optional maybe) an 'endif' for readability but in any case, the 'break' should break out of the loop no matter what.
                                            Edit: On re-reading this, there is a flaw in my thinking here, and unless the 'break' is indented two spaces over, the 'while' loop has no exit. Interesting note here is that the iteration variable apparently isn't reset until after exiting the 'while' loop because it only prints 'hello world' for one 'if' loop.
                                            That to me seems rather odd ....
                                            OwenDundefined 1 Reply Last reply Reply Quote 0
