Duet Wifi Closed Loop and Panel Due
I made a quick wiring diagram in paint.
@alankilian @I have 5 closed loop stepper drivers for context. Can I connect all of the closed loops stepper drivers to the same 5V and Ground Terminal or would that break something?
@gost101 That will be fine as long as you don't draw too much current for the 5 Volt supply or the connector you are using.
