    Small Fdm printer
    406
    • oliofundefined
      oliof @peirof
      @peirof you could take a look at Tiny-M.
      You can get Duet boards from re-sellers without issue.
      peirofundefined 1 Reply Last reply Reply Quote 0
      • peirofundefined
        peirof @oliof
        @oliof Spain reseller its out stock... and some more
        • oliofundefined
          oliof @peirof
          @peirof Thankfully, you are in the EU (-: Depending on what you need you can check Dold Mechatronik (Germany), RatRig (Portugal, limited selection), and others.
          • PCRundefined
            PCR @peirof
            @peirof https://github.com/hartk1213/Micron
            • peirofundefined
              peirof @PCR
              @pcr thanks.... looks good...
              • fcwiltundefined
                fcwilt @peirof
                @peirof said in Small Fdm printer:
                HI,
                I'm looking for recommendation for a printer Fdm DIY.
                So you are looking to build a printer from parts you purchase/make as opposed to kit?
                • peirofundefined
                  peirof @fcwilt
                  @fcwilt i am open to all options....
                  what i search?
                  Small
                  Detail 0.05 layer or less
                    Voron 0 maybe?
                    • peirofundefined
                      peirof @Phaedrux
                      @phaedrux Voron 0, looks great.... for the moment, its preselected...
                      Thanks to all
                      • tenajaundefined
                        tenaja
                        look at the Dice. Might not be big enough for you, but should be precise enough.
                        • peirofundefined
                          peirof @tenaja
                          This post is deleted!
