    Warning: motor phase B may be disconnected
    14
    2.5k
    • hbrownellundefined
      hbrownell
      I get this warning when my machine is working. It just started and I have no idea why.
      Warning: motor phase B may be disconnected reported by driver(s) 3
        dc42 administrators @hbrownell
        @hbrownell said in Warning: motor phase B may be disconnected:
        When RRF reports just one phase may be disconnected, it's usually caused by a bad crimp connection in the motor cable connected to that driver.
        hbrownellundefined 1 Reply Last reply Reply Quote 0
          hbrownell @dc42
          @dc42 Okay, so this was the latest error I got today
          M0 H1
          Which motor should I consider suspect?
            jay_s_uk @hbrownell
            @hbrownell driver 3 and in a standard setup that's the extruder, but check your M584 to see where it's mapped to
              Here's some detail on connecting motors.
              https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Connecting_stepper_motors
              Chances are it's a bad crimp.
                hbrownell @Phaedrux
                @phaedrux Bad wire confirmed. I ordered a new one, hooked it up and no more problems. Thank you!
                Tinchusundefined 1 Reply Last reply Reply Quote 0
                • Tinchusundefined
                  Tinchus @hbrownell
                  @Phaedrux Sorry to bring this topic alive again, I guess is better to keep it like this since Im having the same problem.
                  Im getting this error in a random way. Printer works but if I look at the logs in the console, I can see some of these errors from time to time.
                  can this error be a false positive detection fro the driver or this error means with no doubt at all that there is an error either on the crimp or the cable (or the motor wich it would be really difficult if the motor is a good quality one, steppers from my experience are really no prone to fail)?
                  Thanks in advance
                    dc42 administrators @Tinchus
                    @tinchus if you get warnings for both phase A and phase B then they may be false positives, especially if they only occur at certain speeds. If it's only one phase then there is almost certainly a problem, usually a bad connection.
                    Tinchusundefined MrDuiundefined 2 Replies Last reply Reply Quote 1
                    • Tinchusundefined
                      Tinchus @dc42
                      @dc42 yes. Im getting both warnings: A nad phase B. But not exactly at equal amounts. In logs I can see 2 warnings for phase B, and 1 for phase A at the same time. Other times in logs the amounts of B and A are exactly the same.
                      And this happens at hight speeds
                      • oliofundefined
                        oliof
                        if you run a direct extruder or a kinematic setup where one stepper is moved around (lokemthe flying X setup on an ender 5) and you get this on high speed moves, it might be showing when you pull the wires around.
                        • MrDuiundefined
                          MrDui @dc42
                          @dc42 said in Warning: motor phase B may be disconnected:
                          I think I am exactly in this case right now: the printer works fine, but it reports error on the Z axis for all three motors :
                          Warning: motor phase A may be disconnected reported by driver(s) 5 6 7
                          Warning: motor phase B may be disconnected reported by driver(s) 5 6 7
                          Is there a way to fix it that you would be aware of?
                          Thanks !
                            jay_s_uk @MrDui
                            @MrDui please start a new thread rather than replying to one thats 2 years old
                            MrDuiundefined 1 Reply Last reply Reply Quote -1
                            • MrDuiundefined
                              MrDui @jay_s_uk
                              @jay_s_uk This thread is the first one we find on Google when doing a search for this issue, it's better for everyone if the information stays in one place no matter when it came from.
                              I'd really like an answer to this problem if you don't mind 🙂
                                droftarts administrators @MrDui
                                @MrDui said in Warning: motor phase B may be disconnected:
                                No, it's not. This thread is marked as solved, and is from two years ago. You have 3 motors, different firmware and possibly different hardware. Please start a new thread. To make it easier, I'm locking this thread.
                                When you do start a new thread, please supply some useful information, as mentioned in the first post here: https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help
                                • droftartsundefined droftarts locked this topic
