    Dual Z axis safety
    135
    • tom33
      tom33 last edited by
      I use a dual Z axis on my machine with 2 1XD board for auto alignement at start.
      There is a way to stop the machine if one of the 2 motors doesn't move ?
      I use 2 nema 23 with brake and encoder and leadshine cs1 d507s as driver
      Thanks !
      PCR T3P3Tony 2 Replies Last reply Reply Quote 0
      • tom33
        nobody has the same problem ?
        fcwilt o_lampe 2 Replies Last reply Reply Quote 0
        • fcwilt
          fcwilt @tom33 last edited by
          @tom33 said in Dual Z axis safety:
          So there are times when one of your Z steppers doesn't turn?
          When is that happening?
          Thanks.
          • PCR
            PCR @tom33 last edited by
            @tom33 Why should one motor not move ?
            mrehorstdmd 1 Reply Last reply Reply Quote 0
            • o_lampe
              o_lampe @tom33 last edited by o_lampe
              @tom33 Well, I had the same problem with two Nema23 motors on the Y-axis. It ripped apart my CNC machine.
              What does the leadshine provide (unknown driver for me) about cross-referencing the encoder signals?
              Does it have an error output-signal you could link (in series) with the other drivers enable signal?
              • tom33
                @pcr Is to prevent if an extension board doesn't works or a wiring problem,...
                • T3P3Tony
                  T3P3Tony administrators @tom33 last edited by
                  cs1 d507s as
                  looking at the data sheet there is an Alarm output (which you could connect to the Duet to pause the machine using a trigger. There is also a reset input which you could connect to a IO output to reset the alarm if you wanted to be able to do that.
                  www.duet3d.com
                  • mrehorstdmd
                    mrehorstdmd @PCR last edited by
                    @pcr bad cable/connector, dead driver, controller board that has gone insane...
