    FILAMENT_RUNOUT_DISTANCE_MM or similar at reprap?
    Firmware wishlist
    659
    • apak
      apak last edited by
      Is it there any way to get somehow the marlin feature like
      that runs "x"mm of filament when filament sensor detects NO filament..
      Thanks
      OwenD 1 Reply Last reply Reply Quote 0
      • OwenD
        OwenD @apak last edited by OwenD
        @apak
        When the filament sensor triggers, RRF runs filament-error(n).g if present, where (n) is the sensor number.
        If that's not present it tries to run filament-error.g
        If that's not present, it runs pause.g
        So to achieve what you want I'd try this.
        NOTE - THIS IS UNTESTED
        Create a global variable in config.g
        global filamentDistance= 0 ;
        Create a filament-error.g file in the /sys directory and have it set the variable to whatever the current filament distance is.
        ;0:/sys/filament-error.g
        ; run whenever the sensor detects no filament
        var runoutDistance = 100 ; this is just so you can change easily
        var thisExtruderValue = move.extruders[tools[state.currentTool].filamentExtruder].position
        set global.filamentDistance = var.thisExtruderValue + var.runoutDistance
        Then create a daemon.g file and check the cure value against the the limit you set
        ;0:/sys/daemon.g
        ; run every 10 seconds by default
        ; This should only trigger if a print is in progress and the runout value has been set by a runout.
        if (move.extruders[tools[state.currentTool].filamentExtruder].position > global.filamentDistance)  &&  (global.filamentDistance !=0) && (state.status = "processing")
            M25
        ; to run at intervals less than 10 seconds, use a loop instead of above
        ;while true
        ;    if (move.extruders[tools[state.currentTool].filamentExtruder].position > global.filamentDistance)  &&  (global.filamentDistance !=0) && (state.status = "processing")
        ;        M25
        ;    G4 S5 ; run every 5 secs
        You would also need to ensure that your resume.g file resets your counter to zero
        ;resume.g
        set global.filamentDistance = 0 ;
        • OwenD
          OwenD @OwenD last edited by
          Hmmm
          I tried the method I suggested, but it doesn't work.
          Although the macro gets called and the global is set, RRF pauses immediately after filament-error.g is called.
          That is probably deliberate and kind of logical, but renders this method unworkable.
          • T3P3Tony
            T3P3Tony administrators @OwenD last edited by
            @owend @apak I have asked @dc42 to look at this because I can see the argument for only pausing when a filament-error.g is present if the filament-error contains the explicit pause command.
            www.duet3d.com
            dc42 T3P3Tony 2 Replies Last reply Reply Quote 1
              dc42 administrators @T3P3Tony last edited by
              @t3p3tony the daemon.g file suggested by OwenD contains an explicit M25 command. That's probably why pause.g is being run.
              @apak what do you mean by "runs x mm of filament"? Do you mean "extrudes x mm of filament"?
              OwenD apak 3 Replies Last reply Reply Quote 0
              • T3P3Tony
                T3P3Tony administrators @T3P3Tony last edited by
                @OwenD @apak apologies. I missed that M25. Try it without!
                www.duet3d.com
                • OwenD
                  OwenD @dc42 last edited by OwenD
                  @dc42 @T3P3Tony
                  The M25 should not be called until the current extruder position exceeds the global variable position set.
                  I.e when the filament sensor is tripped, the M25 should not be called until another 200mm of filament has been extruded.
                  This allows for the filament between the sensor and the extruder to be used up. On my case that's about 600mm
                  At that point a pause is called.
                  I'll check again but I'm pretty sure the the code in daemon.g evaluated to false when pause was called.
                  EDIT:
                  I'm wondering if it's because I have a filament monitor defined using M591, rather than just an external trigger using M581?
                  • OwenD
                    @dc42 said in FILAMENT_RUNOUT_DISTANCE_MM or similar at reprap?:
                    I just ran a quick test.
                    The M25 in daemon.g isn't being called.
                    In config.g I have
                    ; Filament monitor
                    M591 P1 C"e0stop" S1 D0 									; filament monitor for extruder 0 connected to E0 endstop
                    In filament-error0.g (and filament-error.g) I have
                    ;0:/sys/filament-error#.g
                    ; run when filament error for extruder # is found.
                    ; if this file not found runs filament-error.g
                    ; if neither found runs pause.g
                    G4 P10 ; delay 10ms to debounce
                    if sensors.filamentMonitors[0].status="ok"
                    	echo "switch bounce detected"
                    	M99 ; break out if sensor value is zero again (bouncing)
                    var runoutDistance = 300 ; this is just so you can change easily
                    echo "filament-error0.g run - print will be paused after " ^ var.runoutDistance ^ "mm"
                    In daemon.g I have
                    		echo "paused called from daemon"
                    		M25 ; pause print if filament has run out
                    	G4 S2 ; add a delay for these checks
                    The console output seems to show the print is paused before filament-error.g is run
                    In any case, it's paused before the daemon can do it.
                    Here is the extruder position vs the position it should have paused.
                    (pause caused a retract)
                    OwenD apak 2 Replies Last reply Reply Quote 1
                    • OwenD
                      I should also point out that the print paused in the position where the filament sensor tripped
                      It did not move away as I have in pause.g
                      M83            ; relative extruder moves
                      G91		; relative movement
                      G10  ; retract filament
                      G1 Z+5 F600     ; lift Z by 5mm
                      G90            ; absolute positioning
                      G1 X{move.axes[0].min} Y{move.axes[1].max} F6000 ; move bed forward and clear nozzle away
                      ;M144 ; put bed on standby
                      T100 ; Put nozzle in standby
                      • apak
                        apak @dc42 last edited by
                        @dc42 yes. It´s a direct extruder, but with reversed bowden of 400mm, and at the beginning of the reversed bowden it´s the filament sensor, so It would be nice to extrude at leat 90% of that lenght in order not to waste that filament
                        • apak
                          apak @OwenD last edited by apak
                          @owend Looking at how caribou3d duet handles the sensor
                          https://github.com/Caribou3d/CaribouDuet2Wifi-ConfigurationMacros
                          may be, on trigger we could deactivate sensor, continue printing for var runoutDistance, and then trigger pause, reactivate, load an resume
                          • T3P3Tony
                            T3P3Tony administrators @apak last edited by
                            @apak @OwenD I am working on recreating this issue because it looks like there is a pause happening which should not be happening if the filament-error.g file is present.
                            www.duet3d.com
                            T3P3Tony apak 2 Replies Last reply Reply Quote 0
                            • T3P3Tony
                              I have recreated this - and moved it to firmware wishlist section as the behaviour will need to be changed to allow the filament out logic to run without a pause.
                              www.duet3d.com
                              OwenD apak DonStauffer 3 Replies Last reply Reply Quote 0
                              • OwenD
                                OwenD @T3P3Tony last edited by OwenD
                                @t3p3tony
                                Thanks Tony 👍
                                • apak
                                  apak @T3P3Tony last edited by
                                  @t3p3tony thanks
                                  • apak
                                    apak @T3P3Tony last edited by apak
                                    @t3p3tony does this feature have an ETA?
                                    • T3P3Tony
                                      @apak no ETA yet.
                                      www.duet3d.com
                                      • Referenced by  T3P3Tony T3P3Tony
                                      • DonStauffer
                                        DonStauffer @T3P3Tony last edited by DonStauffer
                                        @t3p3tony Tell me if I'm correct:
                                        A workaround should be possible by setting a global variable in filament-error.g if you want to cancel the pause. pause.g checks for the variable, and does an M24 if the variable was set, instead of its usual commands.
                                        Do you think this would work? Or would it skip pause.g if filament-error.g ran, giving you no opportunity to cancel the pause? I'm uncertain whether pause.g gets run or not if filament-error.g exists. I know it's not supposed to.
                                        • T3P3Tony
                                          T3P3Tony administrators @DonStauffer last edited by
                                          @donstauffer if filament-error.g runs then pause.g does not run AFAIK. The issue is that there is always a pause as part of the process no matter which macro is called.
                                          www.duet3d.com
                                          DonStauffer 1 Reply Last reply Reply Quote 0
                                          • DonStauffer
                                            @t3p3tony Confirmed. pause.g doesn't run.
                                            • OwenD
                                              Just confirming that this is now possible with 3.4.0b7
                                              Albeit you must be aware that the macro called is now filament_error.g, not filament-error.g
                                              i.e. must have an underscore "_" and not a hyphen "-"
                                              There is also a problem if filament_error.g contains an M291 as described here
                                              filament_error.g
                                              ;0:/sys/filament_error.g
                                              ;run when a filament sensor error is detected.  Print will be paused bt Daemon.g after runout distance.
                                              var runoutDistance = 350 ; this is just so you can change easily
                                              ; first check that we are not currently in an error state and the switch has been toggled again.
                                              if (global.filamentDistance !=0) || !(state.status = "processing")
                                              	echo "Filament sensor triggered, but already no print in progress.  No action taken"
                                              	M99 ; exit macro
                                              echo "filament_error.g run"
                                              	echo "switch bounce detected - error cancelled"
                                              echo {"Filament error type " ^ param.P ^ " detected on extruder " ^ param.D}
                                              ;M291 R"Filament Error" P{"Filament error type " ^ param.P ^ " detected on extruder " ^ param.D} S1 T3
                                              echo "filament_error.g run - print will be paused after " ^ var.runoutDistance ^ "mm"
                                              In daemon.g
                                              (Note this is run in a while loop so it's called at intervals less than 10 seconds)
                                              while true
                                              	; I have a bunch of other stuff in here
                                              	;check the filament runout
                                              	if state.currentTool != -1
                                              			echo "paused called from daemon - filament runout"
                                              In resume.g we reset the distance
                                              	set global.filamentDistance = 0 ; reset filament sensor extrusion distance
                                              ;do all the other stuff needed for resuming
                                              You also need to set the distance to zero in start.g
                                              else
                                              	abort "Filament sensor shows no filament loaded.  Print aborted"
                                              and of course define the global in config.g
                                              if !exists(global.filamentDistance)
                                              	global filamentDistance = 0 ; global for use to allow filament to feed for set distance after sensor trips
                                              else
                                              apak 1 Reply Last reply Reply Quote 2
                                              • apak
                                                thanks, will try
                                                MrTwinkys 1 Reply Last reply Reply Quote 0
                                                • apak
                                                  apak last edited by
                                                  This post is deleted!
                                                  • MrTwinkys
                                                    MrTwinkys @apak last edited by
                                                    @apak any word on whether or not this is functioning correctly? I would like to set this up for a reverse Bowden setup also.
                                                    • Referenced by  selva_tvi selva_tvi
