    Arcwelder?
    304
    • CNCModeller
      CNCModeller last edited by
      Hi All,
      Has anyone had any success using Arcwelder? Am thinking about giving it a try.
      Any thoughts would be much appreciated.
      Cheers
      Barry M
      Polar Printer Duet3 Mini + 1HCL
      https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
      Wanhao D4S: Duet2
      https://forum.duet3d.com/post/296755
      Wanhao D5S & K40 Laser, Duet2 TBD
      https://www.youtube.com/CNCModellerUK
      PCR o_lampe Stephen6309 GeneRisi 4 Replies Last reply Reply Quote 0
      • PCR
        PCR @CNCModeller last edited by
        @cncmodeller If you are useing high accel then i would give it a try.IMG_20211003_101520.jpg
        First one without Second one with.
        IT also depends on the resulotion of the stl
        • oliof
          oliof last edited by
          ArcWelder can improve prints but I'd inspect every single model for unwanted changes before printing it after postprocessing with ArcWelder. Some slicers do what ArcWelder does natively now, and even there I rarely enable the feature.
          <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
          • o_lampe
            o_lampe @CNCModeller last edited by
            @cncmodeller I'm using it permanently without problems.
            I don't expect any advantages other than smaller files, so I didn't make any testprints.
            • Stephen6309
              Stephen6309 @CNCModeller last edited by
              @cncmodeller I'm using with Prusa Slicer. So far, no problems. I've added program to my post-processing scripts section, so it's run when saving/uploading the gcode.
              Marius Breuer 1 Reply Last reply Reply Quote 0
              • GeneRisi
                GeneRisi @CNCModeller last edited by
                @cncmodeller I am using but started getting strange results. After I get the job printed with gcode that doesn't use "G3" I will watch what it is doing and report back here.
                • Marius Breuer
                  Marius Breuer @Stephen6309 last edited by
                  @stephen6309 +1
                  I also use it with duet 2 Ethernet, external drivers (BLDC Servos for X and Y) and as a script in Prusaslicer. I've not done extensive tests, but the prints do look smoother. Never had any issues with it.
                  • CNCModeller
                    Ok, so the general consensus seems to be it's worth a look. I'll add it to my post processing options in S3D and see how it fairs.
                    Thanks for the thoughts folks.
                    Cheers
                    Barry M
                    Wanhao D4S: Duet2
