    CONSTANT AJAX disconnect errors
    307
    55.0k
    • KeeganBundefined
      KeeganB
      And this is tonight's error….
      This was loading DWC about 1 min after a fresh power up of the printer:
      Error reason: SyntaxError: JSON Parse error: Unterminated string
      Then after hitting refresh for the web browser I got a different error that I wasn't able to copy before it disappeared, but I think it ended in "invalid digits."
      after M552 S-1 and S1, this is the new error:
      Error reason: SyntaxError: JSON Parse error: Expected '}'
      EDIT:
      updated to all the latest firmwares from the edge GitHub, disconnects continue. That was expected, but just as an FYI for those following along.
      Artemis
      Rostock Max v2
      Orion
      • KeeganBundefined
        KeeganB
        Hey David,
        Just checking in on the new firmware. I continue to have disconnects, but haven't done much or posted any further on them in the past few days.
        Artemis
        Rostock Max v2
        Orion
          I recall that some of you report that the WiFi is reliable when the printer is idle, but it disconnects a little while after printing starts, even though you are not using high microstepping. It occurs to me that this could be temperature-related. The WiFi module gets warm in normal use, and when the stepper drivers are generating heat as well it could be getting too hot to function properly. So please try the following:
          • Monitor the CPU temperature in DWC until the point at which it disconnects. Is there a significant rise in temperature?
          • Try cooling the Duet with a fan, if you don't already.
          • KeeganBundefined
            KeeganB
            David,
            Where in DWC can I see the board temp?
            Thanks
            Artemis
            Rostock Max v2
            Orion
            • Dougal1957undefined
              Dougal1957
              on any page if you check the Temp area top left you will see an Extras label click it and the MCU temp will appears which you can add to the Line chart if you wish.
              • Jareryundefined
                Jarery
                My Board is mounted above my delta, so bed heat has no effect. The board temp is low to mid 30's when no fan is used. (calibrated just yesterday its about 3 degrees below the PT100 temp)
                Mine also disconnects while idle.
                • KeeganBundefined
                  KeeganB
                  @Dougal1957:
                  perfect, thanks!
                  32.8C at idle after being powered on for several hours.
                  Artemis
                  Rostock Max v2
                  Orion
                  • KeeganBundefined
                    KeeganB
                    Over a couple different hour long prints the MCU temp stayed right around 34 C.
                    Artemis
                    Rostock Max v2
                    Orion
                      Please can those of you who are experiencing disconnect errors and are running DuetWiFiFirmware 1.20beta1 try changing the wifi firmware to version 1.20alpha1+1, which is available here: https://www.dropbox.com/s/u7vpp2wg4rlqs8l/DuetWiFiServer.bin?dl=1. Then let me know if you think it is better or worse.
                      • Jareryundefined
                        Jarery
                        DuetWiFiFirmware1.20alpha1+1
                        • Install 6:55
                        • idle
                        • Disconnect 7:55
                        The log showed slightly different times. The disconnect happened at 7:55 but doesn't show on the log till 8:05. It would not connect via connect button during that time.
                        2017-10-12 06:56:11 Event logging started
                        2017-10-12 08:05:21 WiFi reported error: Lost connection, auto reconnecting
                        2017-10-12 08:05:22 WiFi reported error: Auto reconnect succeeded
                        after reconnect M122:
                        Network state is running
                        WiFi firmware version 1.20alpha1+1
                        WiFi MAC address a0:20:a6:10:55:89
                        WiFi Vcc 3.16, reset reason Turned on by main processor
                        WiFi flash size 4194304, free heap 38352
                        WiFi IP address 192.168.2.32
                        WiFi signal strength -45dBm
                        Reconnections 1
                        HTTP sessions: 1 of 8
                        Socket states: 2 0 0 0 0 0 0 0
                        Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                        Edit 2:
                        Left idle it disconnected again, after waiting 30 min Im able to reconnect. Log doesn't show that it ever knew it was disconnected: The 10:10 log is me reconnecting after disconnecting 30 min or so previous
                        2017-10-12 08:58:13 HTTP client 192.168.2.49 login succeeded
                        2017-10-12 10:10:20 HTTP client 192.168.2.49 login succeeded
                        • Jareryundefined
                          Jarery
                          First print, disconnected while printing the skirt
                            Thanks for your feedback. Which country are you in?
                            • Jareryundefined
                              Jarery
                              Canada, Vancouver BC specificaly,
                              • KeeganBundefined
                                KeeganB
                                Ill be away from the printer for about a week, but will updated to that new version you shared David as soon as I return.
                                Artemis
                                Rostock Max v2
                                Orion
                                • fmaundefined
                                  fma
                                  David, I juste realized that my WiFi signal strength is really low: -68dBm! I think I'm lucky it's working so well, despite such poor signal!
                                  I think I will order the new ESP module, with antenna.
                                  Frédéric
                                  • callilundefined
                                    callil
                                    Updated to alpha1+1 - pretty much the same story for me unfortunately.
                                    The following log is right after a disconnect when idle. I restarted the wifi module with M552 on device.
                                    [[language]]
                                    Used output buffers: 3 of 32 (17 max)
                                    RepRapFirmware for Duet WiFi version 1.20beta1 running on Duet WiFi 1.0
                                    Board ID: 08DAM-9K9K2-NGNSN-6JKD0-3SJ6T-15UBM
                                    Static ram used: 15128
                                    Dynamic ram used: 96048
                                    Recycled dynamic ram: 3512
                                    Stack ram used: 1352 current, 4880 maximum
                                    Never used ram: 11504
                                    Last reset 00:06:35 ago, cause: reset button or watchdog
                                    Last software reset reason: User, spinning module GCodes, available RAM 11504 bytes (slot 3)
                                    Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
                                    Error status: 0
                                    Free file entries: 10
                                    MCU temperature: min 41.1, current 41.6, max 42.8
                                    Supply voltage: min 24.1, current 24.2, max 24.6, under voltage events: 0, over voltage events: 0
                                    Driver 0: stalled standstill
                                    Driver 1: stalled standstill
                                    Driver 2: stalled standstill
                                    Driver 3: standstill
                                    Driver 4: standstill
                                    Date/time: 2017-10-15 15:01:57
                                    Slowest main loop (seconds): 0.008844; fastest: 0.000033
                                    MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                                    Scheduled moves: 0, completed moves: 0
                                    Bed compensation in use: none
                                    Bed heater = 0, chamber heater = -1
                                    Heater 0 is on, I-accum = 0.0
                                    Heater 1 is on, I-accum = 0.3
                                    Segments left: 0
                                    Movement lock held by null
                                    http is idle in state(s) 0
                                    telnet is idle in state(s) 0
                                    file is idle in state(s) 0
                                    serial is idle in state(s) 0
                                    aux is idle in state(s) 0
                                    daemon is idle in state(s) 0
                                    queue is idle in state(s) 0
                                    Code queue is empty.
                                    WiFi MAC address 5c:cf:7f:ef:4c:24
                                    WiFi Vcc 3.11, reset reason Turned on by main processor
                                    WiFi flash size 4194304, free heap 35064
                                    WiFi IP address 192.168.1.107
                                    WiFi signal strength -58dBm
                                    Reconnections 0
                                    • JohnOCFIIundefined
                                      JohnOCFII
                                      I've been leery of updating beyond 1.18.2 due to the frequent reports of WiFi issues. Today I decided to take the leap. The upgrade to 1.19.2 went well. Checking M122 my RSSI varied between -53 and -58 (the access point is one floor away in a wood framed house). I stayed connected from a web browser (Google Chrome from a Mac) for approximately 4 hours. During the middle of that 4 hour window was a single 90 minute print.
                                      All seemed good. Not posting to gloat - but just wanted to add some data points. My access point is an Asus router running the third party Asus-Merlin firmware.
                                      John
                                      • Jareryundefined
                                        Jarery
                                        @JohnOCFII:
                                        My setup is similar, albeit with the issues.
                                        I have an Asus AC3100 as my main router about 3m away, and an AC66U about 12m away as an access point both with same firmware version, both Merlins.
                                        • saironundefined
                                          sairon
                                          I experienced the same issue on a new Duet Wifi I received this week. I recalled that I had similar problems with some devices in the past with WMM mode enabled on the router. And indeed, disabling it fixed the issue. I have a router running OpenWrt based distribution, which allows to enable/disable WMM on per-SSID basis. I'm not sure about other routers, such as those ASUS devices mentioned here, but I think it should be at least possible to toggle WMM globally to try if it solves the problem.
                                          • fmaundefined
                                            fma
                                            As I use an OpenWRT-based router, I'll give this a try! Thanks.
                                            Frédéric
