    Heated chamber air circulation fan
    1.7k
    • chris94undefined
      chris94 @mrehorstdmd
      @mrehorstdmd that was my current plan but i couldn't find a suitable motor. like i sad i dont know too much about electronics so i have no idea which motor is suitable for this application because i would like to control it with the slicer fan configuration
        Since you're just trying to even the air temp you don't need anything more than turbulence so a real fan blade design isn't even needed. All you need are paddles on a spinning shaft. That would simplify the design considerably.
        chris94undefined 1 Reply Last reply Reply Quote 0
        • rjenkinsgbundefined
          rjenkinsgb @chris94
          @chris94 said in Heated chamber air circulation fan:
          I totally agree with you but sadly there is no space left on top of the chamber
          The corner duct type of setup in your drawing would be fine, just with the fan at the bottom pulling air downwards rather than blowing upwards?
          ps. Have you used high temperature cable all the way through for the motors etc?
          Normal PVC insulation is not rated for 120'C - the industrial "Tri-rated" cable we use in machine tools etc. is only rated to 105'C.
          Robert J.
          Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
          • chris94undefined
            chris94 @Phaedrux
            @phaedrux The Mechanical design is not my problem. But the selection of the electronic component is. I Don’t have a problem putting an oven fan in the chamber but controlling it would kill my knowledge because I don’t even have a clew how to control such a motor or if it’s even possible to do so. My favourite solution would be a simple fan motor outside the chamber but I don’t know witch motor I should use and how I should control it. I just want the fan to be quiet (1k rpm) and easy to use so I can control it via the slicer. Is it necessary to design a radial fan from the ground up with a part cooling in mind? No decently not but I like to learn as much as possible while building this printer and that’s why there is so much “overcomplicated” stuff like the hydraulic tool changer inside. I just need someone to guide me a bit in the right direction.
            @rjenkinsgb Yes everything inside this Printer was selected with the Temperature of 120°C in mind (HT- cables, Stepper and Hotend are watercooled etc.). The position of the inlet isn't ideal but it should works good enough and if I put the whole thing upside down I wouldn't have a chance to use the fan in the future as a "part cooler" as well
              Phaedrux Moderator @chris94
              If the fan is outside the chamber where is it drawing air from? If it's drawing air from inside of the chamber that is at 110c then you'll be hard pressed to find a plastic construction fan and motor that would survive that. Best I've seen rated at 70c.
              • chris94undefined
                chris94 @Phaedrux
                @phaedrux the fan itself sits in the chamber and is connected to the motor by a shaft through the chamber. same principle as an oven fan
                  My current solution is a radial fan out of a temperature resisted filament.
                  What filament?
                  • chris94undefined
                    chris94 @Phaedrux
                    @phaedrux 3dktop
                      3dktop
                      Wow, I've never heard of that before.
                      https://3dk.berlin/en/3dktop-heat-resistent/200-3dktop-white.html
                      • chris94undefined
                        chris94 @Phaedrux
                        @phaedrux it's quite nice and not too expensive for its properties
                          Well since you have the fan blade portion possibly solved, the external motor and it's control is where you're stuck?
                          How heavy is the shaft/blade? Do you have a normal fan you could cannibalize to attach to the shaft?
                          • chris94undefined
                            chris94 @Phaedrux
                            @phaedrux the rotor itself is currently 16,54 Grams and the inertia is at 86,87 gcm². the shaft will be as small as possible and so not really heavy. cannibalize of some random fan would be possible but I don’t have one on hand and i would rather by a separate motor (less getto style)
                            • mrehorstdmdundefined
                              mrehorstdmd
                              Buying a new motor for the task is going to be unnecessarily expensive when so many fans are available for pennies. I'd pick up an old desk fan at a garage sale, especially if it has a metal blade, and add a shaft coupler. You're not trying to control the speed, just stir the air, so all the controller has to do is switch it on and off. One of the controller's standard fan outputs can drive a small SSR to operate the fan. If you don't want it running very fast add a small speed controller and just set it to run slow.
                              Whenever you're running the chamber heater you probably want to run the fan, too, so you could just power the two from the same source.
                              DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                              • DIY-O-Sphereundefined
                                DIY-O-Sphere @mrehorstdmd
                                What about using a convection blower of an oven?
                                Used ones are really cheap and metal blades are included....
                                (UTC+1)
                                • chris94undefined
                                  chris94 @DIY-O-Sphere
                                  @diy-o-sphere all the cheap ones are loud but the bigger problem is that there is no space for one. under the chamber is a filament drawer so its not possible to mount something down there. i cant put something in the top part because of the motion system. so the only place left is at the back between the side panel and the cabel cover (95mm)
                                  • A Former User?
                                    A Former User
                                    This post is deleted!
                                    • chris94undefined chris94 has marked this topic as solved
