    Heater fault on heated bed because it's rising to slow.
    65
    7.3k
    • Exerqtorundefined
      Exerqtor
      I've suddenly started getting heater faults on the bed heater while heating up before a print because it's allegedly heating up slower than what RRF wants it to.
      It's a PID tuned 230v 750w 300x300mm silicone heater attached to a 8mm thick 350x350mm cast aluminum bed, switched with a SSR.
      config-override.g:
      M307 H0 B0 R0.902 C267.4 D3.56 S1.00 V12.5 ; Bed heater tuned for 80C with 230v 750w heater
      When I just tried heating the bed from room temp (22c ish) to 85c I got three faults that i had to reset before i got it up to the requested 85c.
      The faults were:
      26.11.2021, 10:13:01	Error: Heater 0 fault: at 83.5°C temperature is rising at 0.2°C/sec, well below the expected 0.5°C/sec
      26.11.2021, 10:12:16	Error: Heater 0 fault: at 75.0°C temperature is rising at 0.3°C/sec, well below the expected 0.7°C/sec
      26.11.2021, 10:11:13	Error: Heater 0 fault: at 63.6°C temperature is rising at 0.4°C/sec, well below the expected 0.7°C/sec
      26.11.2021, 10:09:28	M32 "0:/gcodes/MGN12_z_carriage_rear_3hole+counterweight_0.2mm_CPE_3h12m.gcode"
      File 0:/gcodes/MGN12_z_carriage_rear_3hole+counterweight_0.2mm_CPE_3h12m.gcode selected for printing
      I was holding an eye with it on the Paneldue all the time, and it's almost like the heater refresh stutters for half a second or so (for both bed and hotend) right before the faults get thrown.
      Should i try to re-tune the heater? Or is it something else i should do?
      Edit:
      Oh yeah and the bed related stuff from config.g:
      ; Bed heater
      M308 S0 P"bedtemp" Y"thermistor" T104400 B4138 A"Bed"	; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0					; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B0 S1.00					; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0							; map heated bed to heater 0
      M143 H0 S110						; set temperature limit for heater 0 to 110C
      M143 H0 A2 C0 S110					; make sure bed heater stays below 110°C
      M143 H0 A1 C0 S125					; make sure bed heater shuts down at 125°C
      cosmowaveundefined Alex.crundefined 2 Replies Last reply Reply Quote 0
      • cosmowaveundefined
        cosmowave @Exerqtor
        @exerqtor Eventually you should adjust the heating rate with the M307 R paramenter...
        Mankati FSXT+, DeltaTowerV2, E3D MS/TC
        Exerqtorundefined 1 Reply Last reply Reply Quote 0
        • Exerqtorundefined
          Exerqtor @cosmowave
          @cosmowave
          Thanks for the tip, I'll try lowering it to 0.8 and see if that's enough.
          • Gixxerfastundefined
            Gixxerfast
            I had a thermistor fail in my Keenovo heater that gave me heater errors.
            How do the temp curve in DWC look like, smooth or uneven?
            Also, take a look at your temp fuse if you have a chinese lower temp variant
            Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
            Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
            Ender 3 Pro with BTT SKR-2 + RRF
            • Exerqtorundefined
              Exerqtor @Gixxerfast
              @gixxerfast
              That's what's so strange because everything looks (and "feels" fine) even when it throw's the fault. Curve is all good and it's heating fast. and holds temp steady once it reaches it no matter what the temp should be.
              I'm about to do a print with the heating rate set to 0.800, so fingers crossed that will be help.
              Edit:
              Turns out 0.800 wasn't enough, it helped but it still threw an error (un in the 70c range this thime), adjusted it to 0.750, and it did the rest of the heating without throwing a tantrum.
                Where is the bed thermistor attached? on the heater itself or in the plate to be heated?
                • Exerqtorundefined
                  Exerqtor @Phaedrux
                  @phaedrux
                  It's attached straight on the silicone heater from factory.
                    I'm surprised it's taking longer to heat up in that case. Is there an air bulge or something keeping the thermistor out of contact with the heater itself? I'd be tempted to try with a different thermistor to try and rule that out, even if only temporarily.
                    • Alex.crundefined
                      Alex.cr @Exerqtor
                      @Exerqtor
                      I have to ask the simple question because I didn’t see an answer for it yet. Do you have an M501 at the end of you config.g ?
                      config-override.g:
                      After performing a reboot you can try sending an M307 H0 to verify the correct Param are set for the heated bed?
                      Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
                      • rjenkinsgbundefined
                        rjenkinsgb
                        You appear to be using the default PWM frequency, but with an SSR?
                        That is unlikely to work well, as the PWM will interact with the AC power frequency, which is all the SSR can switch at.
                        That could be causing the "stutter" as well.
                        Try setting the PWM frequency to eg. 5Hz or enabling bang-bang mode instead?
                        Robert J.
                        Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                        • Exerqtorundefined
                          Exerqtor @Alex.cr
                          @phaedrux said in Heater fault on heated bed because it's rising to slow.:
                          Well adjusting it the R value to 0.75 seemed to fix the issue. S it looks like it just werent able to heat up as fast as result of the tuning wanted it too.
                          I haven't got the feeling that it was/is an physical problem at all.
                          @alex-cr said in Heater fault on heated bed because it's rising to slow.:
                          @Exerqtor
                          config-override.g:
                          Yeah all that's ok, M501 is the secound last line (followed by T0) in the config.g, so it's applying the parameters correctly. It was just expecting it to heat up faster than what it actually was capable off.
                            Adding a Q10 to your M950 for the bed might be a good idea
                            • A Former User?
                              A Former User
                              This post is deleted!
                              Exerqtorundefined pfnundefined 2 Replies Last reply Reply Quote 0
                              • Exerqtorundefined
                                Exerqtor @A Former User
                                Sure I can add a Q to the M950, but what should i go for? 5,10 or 50?🤔 Also i didn't see any mention of the need oe posible need for it when running a SSR to regulate mains voltage anywhere in the documentation😬 Or have I missed it somewhere?
                                Phaedruxundefined rjenkinsgbundefined 2 Replies Last reply Reply Quote 0
                                  Phaedrux Moderator @Exerqtor
                                  @exerqtor https://duet3d.dozuki.com/Wiki/Choosing_a_bed_heater#Section_RepRapFirmware_3_x
                                    rjenkinsgb @Exerqtor
                                    @exerqtor said in Heater fault on heated bed because it's rising to slow.:
                                    No more than 10.
                                    An AC SSR is normally "zero voltage switching" - at the start of each AC half cycle, it either switches on, or not. It does not change state during the half cycle.
                                    That means you have 100 or 120 (for 50/60 Hz) on or off "timeslots" each second.
                                    Running at or above the power frequency will give unpredictable results, more luck than anything if it works anywhere near smoothly.
                                    The control frequency needs to be low enough to give a reasonable range of control, different power levels, within each PWM cycle.
                                    10Hz would give roughly 10% increments at 50Hz or 8% increments at 60Hz.
                                    5Hz would give nearer 5% / 4% increments, so slightly smoother control at the cost of fractionally slower response - but with a big heated bed that's not really an issue.
                                    You could try both & see which gives best response. It won't hurt anything, just re-tune at each setting.
                                    Save both tuning result lines in case you want to change in the future.
                                    Robert J.
                                    • Exerqtorundefined
                                      Exerqtor @rjenkinsgb
                                      Haven't looked at that specific page in ages! Would have been really nice with a "mentioned in/ referanced in" ish thing at the bottom of each gcode specific dozuki page that links to every other documents that contain or mention that specific code. Kinda like the way wikipedia is settup with referance links in the bottom (yeah i know that's alot of work to setup, but if it was a quick'n easy interface for setting up referance links for logged in users i'm pretty sure it would get done relatively quickly).
                                      BUT, now i know 😂
                                      @rjenkinsgb said in Heater fault on heated bed because it's rising to slow.:
                                      No more than 10.
                                      Yeah it's an original Omron "Zero-crossing" SSR I'm using, and were on 230V/50Hz here in Norway so I'll try with 5Hz in the M950 and then do a new tune.
                                      Again, thanks for the help and enlightenment guys ❤
                                      Edit:
                                      Ran a new tuning now with the PWM set to 5Hz, and ended with "M307 H0 B0 R0.955 C228.2 D3.40 S1.00 V12.5", an even higher heating rate.
                                      Waiting for it to settle down to room temp before I try running a preheat with those parameters to see how it behaves.
                                      Exerqtorundefined 1 Reply Last reply Reply Quote 1
                                      • Exerqtorundefined
                                        Exerqtor @Exerqtor
                                        @exerqtor
                                        Didn't have time to test yesterday, so i just tried a heatup and :
                                        Error: Heater 0 fault: at 64.9°C temperature is rising at 0.4°C/sec, well below the expected 0.7°C/sec
                                        So i get the feeling the tuning outputs a higher than realistic heating rate to be honest.
                                        • pfnundefined
                                          pfn @A Former User
                                          @arnold_r_clark
                                          I'm also seeing similar behavior since updating to 3.4.0b6 (from 3.3.0)
                                          My bed heater faults very often while initially warming up. And I can also clear the fault and continue heating, but very annoying.
                                          Re-running PID tuning did not improve the situation.
                                          SIamundefined gloomyandyundefined 2 Replies Last reply Reply Quote 0
                                          • SIamundefined
                                            SIam @pfn
                                            Try to use the half of the computed R value from the PID Tuning, This is how it works with my printer
                                            https://forum.duet3d.com/topic/25321/bed-heater-fault-3-4-b5
                                            Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                                            Duet WiFi 1.02 or later + DueX5
                                            RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                                            Duet WiFi Server: 1.26
                                            Duet Web Control 3.4.0beta4 (2021-09-27)
