    Heater fault on heated bed because it's rising to slow.
    65
    6.4k
    • SIamundefined
      SIam @Gixxerfast
      Short feedback from my side, the problem is not solved 😞
      The Result from the pid tuning with RFF 3.4.b6:
      M307 H0 R0.460 C286.278:286.278 D0.90 S1.00 V24.3 B0 I0
      and the result from PID tuning with RRF 3.4.b7:
      M307 H0 R0.484 K0.438:0.000 D0.85 E1.35 S1.00 B0
      and the error:
      Error: Heater 0 fault: temperature rising too slowly: expected 0.43°C/sec measured 0.19°C/sec
      Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
      Duet WiFi 1.02 or later + DueX5
      RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
      Duet WiFi Server: 1.26
      Duet Web Control 3.4.0beta4 (2021-09-27)
      hestiahuangundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • hestiahuangundefined
        hestiahuang @SIam
        @siam @joeko pls refer to the workaround to make your printers work first. Change the code and build at your local, then flash it. The workaround I posted above.
          hestiahuang @hestiahuang
          @hestiahuang said in Heater fault on heated bed because it's rising to slow.:
          yes, I did. Ran Auto PID and saved, also restarted. But still failed, even I used bangbang mode, full speed, I mean.
          Then I changed the code and built Beta7 version, everything looks good now.
          I adjusted the factor 0.5 to small value simplely => RepRapFirmware\src\Heating\LocalHeater.cpp => Line#317 => if (actualTemperatureRise < expectedTemperatureRise * 0.5)
          Quoted here.
          However I don't have dropbox, and can't share my firmware here. Good Luck!
          hestiahuangundefined 1 Reply Last reply Reply Quote 0
            Quoted here.
            Highlight the code for you all again.
            I adjusted the factor 0.5 to small value simplely =>🐤 [RepRapFirmware\src\Heating\LocalHeater.cpp]🐤 => Line#317 => if (actualTemperatureRise < expectedTemperatureRise * 0.5)
            SIamundefined 1 Reply Last reply Reply Quote 0
            • SIamundefined
              SIam @hestiahuang
              @hestiahuang your workaround is not for everybody to make, so the easier way is to half the R value and the bed is heating without error
                hestiahuang @SIam
                @siam I want to say even I use bangbang mode the issue is still, bangbang is using the full power(24V) already. So code change is the only way to me.
                  dc42 administrators @SIam
                  @siam said in Heater fault on heated bed because it's rising to slow.:
                  and the error:
                  Please post the temperature plot while heating up the bed, to help me diagnose this.
                  SIamundefined hestiahuangundefined 4 Replies Last reply Reply Quote 0
                  • SIamundefined
                    SIam @dc42
                    @dc42 here you can download a short video:
                    https://kleinersonnenschein.eu/video/heaterfault.mp4
                    dc42undefined 1 Reply Last reply Reply Quote 1
                      hestiahuang @dc42
                      @dc42 said in Heater fault on heated bed because it's rising to slow.:
                      and the error:
                      yes, the same issue, I mean too.
                        hestiahuang @dc42
                        and the error:
                        Want to confirm that, the same printer with different firmware, such as rrf and klipper, no issue on klipper
                          hestiahuang @dc42
                          and the error:
                          For the bed heater case above, it is very normal that take 5~10mins to heat the bed from around 20°C to around 80°C, (80°C-20°C) / 0.19°C/sec /60sec/min=5.26min. So I think 'the quick factor' is good to apply to tools heater but not for bed heater.
                            @siam thanks for the video, that's really helpful.
                            What I suspect is happening is that your bed heater has a high thermal mass (e.g. aluminium plate) and the thermistor is embedded in the heater, not in good contact with the plate. Does that describe your bed heater? This makes the long-term heating behaviour very different from the short-term behaviour. The current tuning algorithm measures the short term behaviour, because that is what is required for computing suitable PID parameters.
                            Please can you do a video of the heater being tuned, so that I can see the complete temperature graph during the tuning process.
                            As a workaround until I have a solution, if you reduce the R parameter in the M307 command by 30%, that should be sufficient to avoid getting heater faults.
                            dc42undefined hestiahuangundefined 2 Replies Last reply Reply Quote 1
                              dc42 administrators @dc42
                              @siam @hestiahuang please try the firmware build at https://www.dropbox.com/sh/5ubjszy9fmlvzwu/AAAeOMGP-Yi-Gn9LZwQoPfita?dl=0.
                              Gixxerfastundefined SIamundefined 2 Replies Last reply Reply Quote 0
                              • Gixxerfastundefined
                                Gixxerfast @dc42
                                @dc42 I wasn't addressed but I tried it anyway since I was having problems but with this version it heated up without any errors. Absolutely perfect. Before, with b7 I would have had three errors before reaching target temp. Thanks!
                                Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
                                Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
                                Ender 3 Pro with BTT SKR-2 + RRF
                                • NikAundefined
                                  NikA
                                  I also have this problem and noticed that the difference is double (or half) of what is expected.
                                  tuning again and again did not change much, but it looks like you're already fixing the problem 🙂
                                  I have a suggestion: could you add a feature that makes it possible to zoom in on the temperature chart (as in temporarily increase the window size or open in a new window)?
                                  The way it currently is makes it impossible to see small changes, but I would be interested in seeing them.
                                  I think it would make it possible to see changes when feeding too fast or having air flow etc
                                  • SIamundefined
                                    SIam @dc42
                                    @dc42 I have tested the new firmware, thanks for this! Now the PID-Tuning takes a long time (over a half hour) and after this I get now a warning;
                                    If I use this PID settings to heat up my bed, I still get the heater fault
                                    Error: Heater 0 fault: temperature rising too slowly: expected 0.34°C/sec measured 0.11°C/sec
                                    I have recorded the PID Tuning and you can view this long video under:
                                    https://kleinersonnenschein.eu/video/pidtuning_3.4.b7+1.mp4
                                    I hope this will help you when you need more tests then let me know
                                    But first I wish you and the whole great duet team a merry Christmas, thanks for your hard work!
                                    Phaedruxundefined SIamundefined 2 Replies Last reply Reply Quote 0
                                      Phaedrux Moderator @SIam
                                      @siam Perhaps I've asked this before in another thread, but can you show/describe what your bed assembly is like?
                                      • SIamundefined
                                        SIam @SIam
                                        I forget to answer your question
                                        My Alu plate is 420 x 420 x 8 mm
                                        and the thermistor is embedded in the heater,not in good contact with the plate.
                                        yes it is
                                        yes
                                        I haven't test with 30% at the moment, I reduce it to 50% and this works for now
                                        • SIamundefined
                                          SIam @Phaedrux
                                          @phaedrux The structure of the heating plate is as follows :
                                          First the Alu plate with 420 x420 x 8 mm
                                          Then this silicone heatbed :
                                          https://de.aliexpress.com/item/32612060131.html?spm=a2g0o.9042311.0.0.27424c4daTA4uh
                                          With 220V / 500W
                                          and under this I have a cork plate for isolation.
                                          joekoundefined 1 Reply Last reply Reply Quote 0
                                          • Exerqtorundefined Exerqtor referenced this topic
                                          • joekoundefined
                                            joeko @SIam
                                            This post is deleted!
