    Low effort Duet controlled air filter: IKEA Förnuftig
    ikea hack air filter
    • pixelpieperundefined
      pixelpieper
      I grabbed one of the IKEA air filters last weekend and was surprised to find out at home that it is actually a 24V device - 800mA, 19W and hence very well suited for being hooked up to a heater output on my Duet 3 Mini…
      I tried to find the plugs used by IKEA but failed, so I ended up just cutting the wire. Black is gnd, white is 24V if you want to do the same. I just configured it as a fan in my config.g
      Voron V2.434 / Duet 3 Mini5+, Duet 3 Expansion Mini 2+, Duet 1LC V1.1 Toolboard
      Voron V0.250 / Duet 2 Maestro
      zaptaundefined 1 Reply Last reply Reply Quote 1
        Is that the grey thing behind the purple thing?
        pixelpieperundefined 1 Reply Last reply Reply Quote 0
          pixelpieper @Phaedrux
          @phaedrux Yes
            jay_s_uk @pixelpieper
            @pixelpieper got a link to it on the IKEA site?
              pixelpieper @jay_s_uk
              @jay_s_uk here you go. Note that the VOC activated carbon filter is sold separately.
              • zaptaundefined
                zapta @pixelpieper
                @pixelpieper, very nice design. Are you aware of the Nevermore? The micro version for example fits under the bed, between the two rails.
                https://github.com/nevermore3d
                • zaptaundefined
                  zapta @pixelpieper
                  @pixelpieper said in Low effort Duet controlled air filter: IKEA Förnuftig:
                  There are some reports in the Voron forums about activated carbon that is acidic and corrodes the printer, so pick carefully.
                  I am using this one based on recommendations.
                  https://envirosupply.net/products/4mm-pellet-virgin-coal-activated-carbon-charcoal-for-vapor-filtration-1-lb-bag?variant=14036431372323
