    after print part orientation change
    886
    • patelundefined
      patel
      i try to many change but i am fail all the time. i upload gcode file and check G code viewer look ok after start printing orientation changeIMG_6182.jpg IMG_6184.jpg
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Fri Dec 03 2021 13:59:14 GMT-0600 (Central Standard Time)
      G21 ; Work in millimetres
      ; Axis and motor configuration
      M669 K0 ; Cartesian mode
      M550 P"My Printer" ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S0 ; physical drive 0 goes forwards X
      M569 P1 S1 ; physical drive 1 goes forwards Z
      M569 P2 S1 ; physical drive 2 goes backwards Y
      M584 X0 Y2 Z1 E3 ; set drive mapping
      M92 X87.50 Y87.50 Z1052.20 E476.50 ; set steps per mm
      M566 X1000.00 Y1000.00 Z50.00 E1500.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X24000.00 Y24000.00 Z400.00 E3600.00 ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1400 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      ;M98 Pmachine_axisdimension.g ; configure the axes dimensions
      M208 X0 Y0 Z0.0 S0 ; Set axis minima
      M208 X260 Y280 Z215.80 S1 ; Set axis maxima
      M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !xstop
      M574 Y1 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !ystop
      M574 Z1 S1 P"!zstop"
      M558 P5 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
      G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
      ;M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp
      ;M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
      M308 S1 P"e0temp" Y"pt1000" ; sensor 1
      M950 H1 C"e0heat" T1 ; create heater and map sensor 1
      ;M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency
      ;M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off
      HebigTundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • HebigTundefined
        HebigT @patel
        @patel Is it flipped with respect to the X-axis?
        I suspect that changing the M569 command in config.g for the x-axis would solve it.
        You have: M569 P0 S0
        And you can instead try: M569 P0 S1
        YOu may also have to adjust the config for your x-axis endstop since the motor will attempt to home in the opposite direction!
        patelundefined 1 Reply Last reply Reply Quote 0
        • patelundefined
          patel
          This post is deleted!
          • patelundefined
            patel @HebigT
            @hebigt
            I try before changing S0 to S1 but nothing change
            When I move X and y axis moving right direction
            But printing times I don’t know why changing
            • oliofundefined
              oliof
              Looks like you are using Simplify3D which has "Flip Build Table Axis" enabled by default for Y:
              Try disabling that maybe?
              patelundefined 1 Reply Last reply Reply Quote 2
              • patelundefined
                patel @oliof
                @oliof
                thank you for suggestion. i try right know. is the same . did not change
                • oliofundefined
                  oliof
                  if you conduct moves via Duet Web Control, do the axes move in the right direction?
                  • patelundefined
                    patel @oliof
                    @oliof x axis i set g92 x250 and y axis i set g92 y280. when i try to move Duet Web control i need you - side
                    example i need to move x20 than i need to press x-230 then i reach x20.
                      Phaedrux Moderator @patel
                      @patel said in after print part orientation change:
                      Your M208 S values are reversed.
                      S0 = set axis maximum, 1 = set axis minimum
                      • patelundefined
                        patel @Phaedrux
                        @phaedrux Thank you for reply
                        I made corrections but still results is the same
                        • rjenkinsgbundefined
                          rjenkinsgb
                          I believe it is a setting within the slicer:
                          From the initial images, the parts are mirrored within themselves - but the part positions are not exchanged along the same axis, which they would be if it were in any way related to printer movement.
                          I cannot see how it can be anything but some form of mirror setting within the slicer - possibly done during an early setup, trying to compensate a reversed axis in the printer??
                          Robert J.
                          Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                          Phaedruxundefined 1 Reply Last reply Reply Quote 1
                            Phaedrux Moderator @rjenkinsgb
                            @rjenkinsgb said in after print part orientation change:
                            Maybe. I don't think the photo shows the parts on the build surface though. Perhaps they were exchanged?
                              Can you post your homing files as well please?
                              Can you confirm for me a few details?
                              Where are your endstops located? Photo?
                              When looking at the printer from the front, the 0,0 position should be located at the front left corner.
                              -X should move to the left, +X should move to the right, -Y should move to the front, +Y should move the back.
                              patelundefined 2 Replies Last reply Reply Quote 0
                              • patelundefined
                                patel @Phaedrux
                                @phaedrux
                                I send all data tomorrow. We have power outage today
                                Sorry for delay
                                • FrankVundefined
                                  FrankV
                                  As earlier mentioned, I think you have to rule out some things:
                                  Is your x motor your x motor. (sending gcode)
                                  Is your y motor your y motor. (sending gcode)
                                  Does they rotate in the correct way. (sending gcode)
                                  Does x home before y?
                                  Read your gcode in another slicer (or gcode viewer) and see the result.
                                  From there you can troubleshoot. Looks to me you changed x and y.
                                  • patelundefined
                                    patel @Phaedrux
                                    ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sun Dec 12 2021 20:23:27 GMT-0600 (Central Standard Time)
                                    G21
                                    M669 K0
                                    M569 P2 S0 ; physical drive 2 goes forwards
                                    M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                                    M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
                                    M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                                    M208 X260 Y280 Z215.8 S0 ; set axis maxima
                                    M574 X2 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                                    M574 Y2 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                                    M574 Z2 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
                                    M950 F0 C"fan1" Q500 ; create fan 0 on pin fan1 and set its frequency
                                    HOME FILE
                                    ; homex.g
                                    ; called to home the X axis
                                    ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Dec 15 2021 15:04:17 GMT-0600 (Central Standard Time)
                                    G91 ; relative positioning
                                    G1 H1 X-265 F1800 ; move quickly to X axis endstop and stop there (first pass)
                                    G1 H2 X5 F6000 ; go back a few mm
                                    G1 H1 X-265 F360 ; move slowly to X axis endstop once more (second pass)
                                    G1 H2 Z-5 F6000 ; lower Z again
                                    G90 ; absolute positioning
                                    ; homey.g
                                    ; called to home the Y axis
                                    G1 H1 Y-285 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                                    G1 H2 Y5 F6000 ; go back a few mm
                                    G1 H1 Y-285 F360 ; move slowly to Y axis endstop once more (second pass)
                                    ; homez.g
                                    ; called to home the Z axis
                                    G1 H1 Z-220.8 F1800 ; move Z down until the endstop is triggered
                                    G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                                    ;G91 ; relative positioning
                                    ;G1 Z5 F100 ; lift Z relative to current position
                                    ;G90 ; absolute positioning
                                    ; homeall.g
                                    ; called to home all axes
                                    G1 H1 X-265 Y-285 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                                    G1 H2 X5 Y5 F6000 ; go back a few mm
                                    G1 H1 X-265 Y-285 F360 ; move slowly to X and Y axis endstops once more (second pass)
                                    G1 H1 Z-220.8 F360 ; move Z down stopping at the endstop
                                    • patelundefined
                                      patel @patel
                                      @patel
                                      M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                                      M574 Y1 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                                      M574 Z1 S1 P"!zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
                                        @patel
                                        Which is it?
                                        Is the red dot the endstop location for both X and Y?
                                        @phaedrux said in after print part orientation change:
                                        Does it move like this?
                                        • patelundefined
                                          patel @Phaedrux
                                          @phaedrux
                                          Yes red dot end stop switch
                                          • patelundefined
                                            patel @Phaedrux
                                            @phaedrux
                                            thank you very much you fix my printer .
                                            1 week i am looking problem . lot of search google, lot of change file but what you say When looking at the printer from the front, the 0,0 position should be located at the front left corner.
