    Kit Recommendation: Two Materials 300x300
    36
    2.4k
    • auserundefined
      auser @martin7404
      @martin7404 very kind of you that you offer to help with a muldex! I'm inside europe but not in the EU. Will contact you by PM if that is ok?
      • poofjuniorundefined
        poofjunior @auser
        @auser Looks like I'm getting to this one a bit late, but a kit for the frame has been in the works via Filastruder, and we're almost done aggregating everything. Our target is end of this month (Jan), which feels a bit surreal, since we've been at this for a good ten months now.
        The kit should totally eliminate the need for making your own wire harnesses, come with all the assembly tools except a soldering iron for installing the heat-set inserts, and leverage a Duet3 Mini + 3HC Expansion with 2 drivers to spare for tools by default. (There's also a hole mounting pattern for 2 additional 3HC boards.)
        Along the way, I totally revamped the default extruder tool to be Orbiter-based with support for the 1.5 and 2.0, and then support groovemount heatsinks, threaded heatsinks, and v6 and v7 heads, not to mention a bunch of clones. It also sports dual 5015 fans. More info on the Baby Bullet here, but the folks who've built one or modified one seem to be really happy with it.
        I totally acknowledge that building Jubilee is lots of work, but hopefully this will get folks much further out faster.
        Cheers--and have fun on your build--whatever platform you pick!
        auserundefined 1 Reply Last reply Reply Quote 3
        • auserundefined
          auser @poofjunior
          @poofjunior said in Kit Recommendation: Two Materials 300x300:
          Great news! And thanks for letting me / us know! And no not (for me) I was away a few days and I'm still considering my options. Will there also be an european distributor? As mentioned > 200 usd for shipping and then import tax + VAT does add up.
          Maybe you can post here again when the kit goes life?
          best regards
          poofjuniorundefined 1 Reply Last reply Reply Quote 0
            poofjunior @auser
            @auser There's no EU distributer for a kit now, but folks building Jubilees in the EU usually go to HighTemp3D for parts. I'd be open to looking for more folks willing to do kits.
            I totally acknowledge that shipping costs add up. Test driving a kit in the US is one way to help solve that issue, but not the last. Baby steps!
            And I'll gladly post an announcement when kits go live if I'm allowed to do some self-promotion!
            auserundefined T3P3Tonyundefined Sindariusundefined 3 Replies Last reply Reply Quote 2
            • auserundefined
              auser @poofjunior
              @T3P3Tony: Is announcing a kit (duet powered) considered ok in this forum? If not @poofjunior, can you maybe suggest (e.g. in PN) where to subscribe?
              Thanks all!
              Edit: formatting
              zaptaundefined 1 Reply Last reply Reply Quote 0
              • T3P3Tonyundefined
                T3P3Tony administrators @poofjunior
                Yes that will be ok. In general I am happy for Duet based printer kits to be linked to on this forum as long as:
                1. The use genuine Duet3D products
                2. Its not spammed in loads of posts unnecessarily.
                www.duet3d.com
                • zaptaundefined
                  zapta @auser
                  @auser, I presume that you can also mention it in your signature, since it's fine print and tells about your background. 😉
                  auserundefined 1 Reply Last reply Reply Quote 1
                  • auserundefined
                    auser @zapta
                    @zapta
                    I think that suggestion was directed @poofjunior. He is the jubiliee designer if I'm not mistaken?
                    • Sindariusundefined
                      Sindarius @poofjunior
                      @poofjunior I for one am excited about a Jubilee kit!
                      • breedundefined
                        breed @auser
                        @auser rat rig v-cast
                        • A Former User?
                          A Former User
                          Print your own.
                          The complete process can be much fun and you´ll learn so much.
                          I could help you.
                          cheers
                          Richard
                          • auserundefined
                            auser
                            the filastruder jubilee kit was just announced yesterday: https://forum.duet3d.com/topic/27241/jubilee-kits-are-live
                            To me this looks very good, and is my current favourite. Especially considered that Ratrigs V-Cast update no longer seems to be "coming soon". But is "on hiatus" [1]. I'm off discussing budgets...
                            [1] https://www.ratrig.com/3d-printing-cnc/rat-rig-v-cast.html
                            • AlexKidundefined
                              AlexKid @martin7404
                              @martin7404
                              Than I think we have at least three Muldex builds in Europe. I build one during last year. It was very interessting to do this.
                              • martin7404undefined
                                martin7404
                                @alexkid I am glad, it is great to have one more
                                where are you located
                                Muldex IDEX Duet2+Duex5
                                Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
                                Sapphire Pro with Duet2, with closed-loop motors
                                custom high temp E3D tool changer with Duet2+Duex
                                AlexKidundefined 1 Reply Last reply Reply Quote 0
                                • AlexKidundefined
                                  AlexKid @martin7404
                                  @martin7404
                                  I'm from germany, Lower Saxony. And you?
                                  martin7404undefined 1 Reply Last reply Reply Quote 0
                                    martin7404 @AlexKid
                                    @alexkid Bulgaria, Sofia
