    0.8 Nozzle not bad for the first try bt I need your help
    • claustroundefined
      claustro
      Hi guys ,
      I am trying a 0.8 nozzle for big print but I am having some problems of perimeter gaps.
      Perimenter and internal gap are separated by abot 0.1mm space
      Any idea how can solve this problem.
      My setting for this print
      PLA
      nozzle 0.8 vulcano
      temperature 220
      extrusion multiplier 1.02
      extrusion width 1.0
      layer eight 0.5
      top solid layer 3
      bottom solid layer 3
      outline perimeter 3
        Are you perhaps exceeding your hot end melt rate?
        https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s177
        See the steps beginning here to find your max extrusion rate. Once you know the max extrusion rate you can find your max speed based on the height and width you want to use.
        Also with larger nozzles you may need to increase the overlap setting and retune pressure advance and retraction.
        • Touchthebitumundefined
          Touchthebitum
          I use 0.8 nozzle size too for large prints. I have this problem too but it seems that acceleration may be modified. Be careful with speed because extruder motor has to provide more speed for the print. So try to lower your print speed 😉
          Sparkcube XL V 1.1 300x300x190, Radds, Raspberry, Keenovo silicone bedheat 220v, Big Booster Extruder, DIY building
          BLV Cube 665mm Direct Drive with Duet3/SBC (RPi 4) Mosquito Magnum/Bond Tech Extruder/Vanadium Nozzle, Keenovo silicone bedheat 220v
          • claustroundefined
            claustro
            @phaedrux Thank you I am in the range / max speed 50mm/s printing at 40 mm/s.
            I am goiong to try overlapp seting and reducing the sped a bit
            • deckingmanundefined
              deckingman @claustro
              @claustro Also, if you use pressure advance, disable it or set it to really low value. Any pressure build up that you might see with a 0.4mm nozzle will be much reduced with a 0.8mm nozzle.
              • oliofundefined
                oliof
                Depending on your slicer you may increase infill overlap for the holes in the top layer, and tune Z seam settings for the gap at the seam.
