Correction of heightmap is not really working
@fcwilt Hello frederick,
we need to do it tommorow, because need to leave now home.
But i got an message the the axis are not homed because of z
error in macro line 8
I think its not ready somehow the distance from z
@fcwilt Good morning frederick,
back to my calibration problem.
I run now the button on the display for leveling.
head moves to all 4 corners and than to the middle and stays there.
<G32 Leadscrew adjustments made: 0.040 0.051 0.023 0.047, points used 4, (mean, deviation) before (0.039, 0.007) after (0.000, 0.000)>
if i do g28 than
i get the following error message:
<G28 Error: in file macro line 8: G30: Z probe 0 not found>
If i hit the button HOME ALL
<Error: in file macro line 7: G30: Z probe 0 not found Error: Homing failed Error: in file macro line 8: G30: Z probe 0 not found>
my homeall.g
<M280 P0 S60 I1 G91 ; relative positioning G1 H2 Z5 F200 ; lift Z relative to current position G1 H1 X-605 Y605 F3000 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X5 Y-5 F600 ; go back a few mm G1 H1 X-605 Y605 F600 ; move slowly to X and Y axis endstops once more (second pass) G90 ; absolute positioning G30 ; home Z by probing the bed>
Dieter
Please post you current files:
- config.g
- config_probe.g
- bed.g
In your homeall.g file you are not moving to the center of the bed before doing the G30 to home. That is not the cause of the error messages but it should be added.
@fcwilt hello frederick,
here are my files:
config.g
<; General preferences_________________________________________________________ G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M111 S0 ; Debug off M555 P2 ; Set output to look like Marlin M575 P0 B57600 S2 ; communication parameters for USB serial M575 P1 B57600 S1 ; Set auxiliary serial port baud rate and require checksum (for PanelDue) ; Network_____________________________________________________________________ M550 P"Big 60X V3.4 15.02.2022" ; set printer name ; History ; removed U 15.02.2022 ; ; M552 S1 ; enable network M552 P192.168.10.169 ; My IP Address M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; add probe file ; global.g_probe_z_trigger ; global.g_probe_z_trigger = 2.915 ; default - set as appropriate for the Z probe M98 P"config_probe.g" M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters woher kommt der test wie wurde der Winkel bestimmt Unklar! M376 H10 ; stop z-leveling after 10 layers ; Drives_________________________________________________________________________ ;Main board______________________________________________________________________ M569 P0 S1 ; Physical drive 0 . X1 M569 P1 S0 ; Physical drive 1 . X2 M569 P2 R-1 ; Physical drive 2 . Canceled M569 P3 S1 ; Physical drive 3 . Main Extruder M569 P4 S0 ; Physical drive 4 . Secondary Extruder ;Duex5 board_____________________________________________________________________ M569 P5 S0 ; Physical drive 5 . Y M569 P6 S0 ; Physical drive 6 . Z1 (0,1000) M569 P7 S0 ; Physical drive 7 . Z2 (0,0) M569 P8 S0 ; Physical drive 8 . Z3 (1000,0) M569 P9 S0 ; Physical drive 9 . Z4 (1000,1000) ;Settings_________________________________________________________ M584 X0:1 Y5 Z6:7:8:9 E3:4 P3 ; Driver mapping ; M671 X-189:-189:645:645 Y645:-64:-64:645 S10 ; Anticlockwise old ; M671 X-168:-168:655:655 Y655:-64:-64:655 S10 ; Anticlockwise M671 X-168:-168:645:645 Y645:-64:-64:645 S10 ; Anticlockwise ;___________________________________________________________________ M350 X16 Y16 I1 ; Configure microstepping with interpolation M350 Z16 E16:16 I0 ; Configure microstepping without interpolation M92 X100.00 Y100.00 Z1969.60 E416.21:416.21 ; Set steps per mm changed to fit my values 100mm messen und eintragen M566 X240 Y360 Z30.00 E120.00:120.00 P1 ; Set maximum instantaneous speed changes (mm/min) M203 X9000.00 Y9000.00 Z200.00 E1200.00:1200.00 ; Set maximum speeds (mm/min) M201 X1000 Y1000 Z120.00 E250.00:250.00 ; Set accelerations (mm/s^2) M204 P500 ; Set print and travel accelerations (mm/s^2) M906 X1800 Y1800.00 E1000.00:1000.00 I40 ; Set motor currents (mA) and motor idle factor in per cent M906 Z1800.00 I50 ; Set motor currents (mA) and motor idle factor in per cent M84 S100 X Y E0 E1 ; Set idle timeout - one minute ; Axis Limits M208 X0 Y0 Z-1 S1 ; set axis minima M208 X600 Y600 Z630 S0 ; my print area, changed to hight 630 do changes ; Endstops M574 X1 S1 P"xstop + e0stop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop M574 Y2 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop ; Height (mm) over which to taper off the bed compensation 10, 30 ; Heaters___________________________________________________________ M140 H-1 ; disable heated bed (overrides default heater mapping) ;E0_________________________________________________________________ M308 S0 P"spi.cs1" Y"rtd-max31865" M950 H0 C"e0heat" T0 ; create nozzle heater output on e0heat and map it to sensor 0 M307 H0 B0 R3.818 C129.1:116.6 D3.00 S1.00 V23.9 ;New TAKOTO mit Wärmeleitpaste M143 H0 S300 ; set temperature limit for heater 0 to 300° ;E1_________________________________________________________________ M308 S1 P"spi.cs2" Y"rtd-max31865" M950 H1 C"e1heat" T1 ; create nozzle heater output on e1heat and map it to sensor 1 M307 H1 B0 R3.746 C151.8:132.3 D3.63 S1.00 V23.9 ; NEW TAKOTO M143 H1 S300 ; set temperature limit for heater 1 to 300° ; Fans______________________________________________________________ M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned on M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned on M950 F2 C"duex.fan7" Q500 ; create LED on pin fan2 and set its frequency M106 P2 S0 H-1 ; Disable fan channel for LED M950 F3 C"duex.fan5" Q500 ; create fan 3 on pin fan1 and set its frequency M106 P3 S255 H0 T45 ; set fan 3 value. Thermostatic control is turned on M950 F4 C"duex.fan6" Q500 ; create fan 4 on pin fan1 and set its frequency M106 P4 S255 H1 T45 ; set fan 4 value. Thermostatic control is turned on ; Tools______________________________________________________________ ;T0_________________________________________________________________ M563 P0 S"E0 Primary" D0 H0 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S210 ; set initial tool 0 active and standby temperatures to 0C ;T1_________________________________________________________________ M563 P1 S"E1 Secondary" D1 H1 F1 ; define tool 1 G10 P1 X0 Y49 Z0 ; set tool 1 axis offsets G10 P1 R0 S210 ; set initial tool 1 active and standby temperatures to 0C ; Automatic power saving____________________________________________ M911 S22.5 R29.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss. Power Failure Pause ; Custom settings__________________________________________________ M950 J0 C"exp.e2stop" ; create Input Pin 0 on pin E2 to for M581 Command. M581 T1 P0 S0 R1 ; Regular filament sensor for E0 As External Trigger M950 J1 C"exp.e3stop" ; create Input Pin 1 on pin E3 to for M581 Command. M581 T1 P1 S0 R1 ; Regular filament sensor for E1 As External Trigger M950 J2 C"exp.e4stop" ; create Input Pin 2 on pin E4 to for M581 Command.>
Here is my config_Probe.g
<; probe_config.g ; config the probe and call the other files.g ; M950 S0 C"duex.pwm5" M558 P9 C"zprobe.in" H5 F120 T6000 A5 R0.7 ; G31 P500 X-18 Y24 Z{global.g_probe_z_trigger} ; set Z probe trigger value, offset and trigger height (larger value is closer) ; change to zvalue global.g_probe_z_trigger did not work G31 P500 X-25 Y37 Z2.915 ; set Z probe trigger value, offset and trigger height (larger value is closer) >
Here is my bed.g
<; bed.g ; called to perform automatic bed compensation via G32 ; M98 P"config_probe.g" ; insure probe is using most recent configuration values G29 S2 ; cancel mesh bed compensation M290 R0 S0 ; cancel baby stepping G90 ; absolute moves G1 Z5 F99999 ; insure Z starting position is high enough to avoid probing errors ; M671: Define positions pf manual bed levelling screws or Z leadscrews ; Xnn:nn:nn... list of between 2 and 4 X coordinates of the leadscrews that drive the Z axis or the bed levelling screws ; Ynn:nn:nn... list of between 2 and 4 Y coordinates of the leadscrews that drive the Z axis or the bed levelling screws ; Snn maximum correction allowed for each leadscrew in mm (optional, default 1.0) ; Pnnn pitch of the bed levelling screws (not used when bed levelling using independently-driven leadscrews). Defaults to 0.5mm which is correct for M3 bed levelling screws ; Fnn fudge factor, default 1.0 M671 X-168:-168:645:645 Y645:-64:-64:645 S10 ; Anticlockwise ; --- level bed --- while true ; run leveling pass G30 P0 X10 Y40 Z-99999 ; Probe near a leadscrew G30 P1 X600 Y40 Z-99999 ; Probe near a leadscrew G30 P2 X600 Y620 Z-99999 ; Probe near a leadscrew G30 P3 X10 Y620 Z-99999 S4 ; Probe near a leadscrew if move.calibration.initial.deviation < 0.015 break ; check pass limit - abort if pass limit reached if iterations = 5 M291 P"Bed Leveling Aborted" R"Pass Limit Reached" abort "Bed Leveling Aborted - Pass Limit Reached" ; --- finish up --- ; --- set Z=0 datum which can be affected by leveling --- G1 X300 Y300 ; move probe to center of bed - set values aaa and bbb as appropriate G30 ; do single probe which sets Z to trigger height of Z probe G31 >
thx dieter
Let's add the M98 P"config_probe.g" to your home all file right before the G30 and see if that makes a difference.
It shouldn't since you are calling config_probe.g in your config.g but let's make the change and test it.
@fcwilt
hello,works,
we had a mismatch config_probe.g against probe_config.g
with the variable Z{global.g_probe_z_trigger} it´s not working
as soon as i add a value for z it works.
@icy_snake said in Correction of heightmap is not really working:
@fcwilt
hello,works,
As @Phaedrux pointed out the Z trigger height should be the same regardless of which buildplate is in use.
But using a variable doesn't hurt if you want to be able to easily change the Z trigger height without stopping to edit a file.
I verified that using a variable works but it is required that the variable be created in config.g before any attempt to use it.
I think I recall you initially declared it after the call to config_probe.g (the file name doesn't matter - if you prefer another name just check that you use the same name everywhere.
@fcwilt This has been great, I am having the exact same problems as @ICY_SNAKE with the same machine. V3.3, I have followed and made all the same changes.
But I am having a Errror: in file macro line 6 column 43: G31 : unknown
variable 'g_probe_z_trigger"I don't understand what that is ?
@sculpt-fabricator said in Correction of heightmap is not really working:
Did you create the variable in your config.g file as I specified in my example?
@fcwilt
Here is my Config.g; General preferences_________________________________________________________ G21 ; dimentions in mm G90 ; for X,Y,Z use absolute coordinate values M83 ; for E0,E1,etc use relative coordinate values M111 S0 ; Debug off M555 P2 ; Set output to look like Marlin M575 P0 B57600 S2 ; communication parameters for USB serial M575 P1 B57600 S1 ; Set auxiliary serial port baud rate and require checksum (for PanelDue) ; Network_____________________________________________________________________ M550 P"Big 60" ; set printer name M552 S1 ; enable (S1) networking (WiFi) M586 S1 P1 ;T0 ; enable (S1) FTP (P1) Disable TLS (T0) M586 S1 P2 ;T0 ; enable (S1) Telnet (P2) Disable TLS (T0) ;;M586 P0 S1 ; enable HTTP ;;M586 P1 S0 ; disable FTP ;;M586 P2 S0 ; disable Telnet ; mode control variables _____________________________________________________ global g_z_home = 5 ; can be used to always move Z to known height global g_z_datum_set = false ; can be used to prevent unneeded setting of Z=0 datum global g_map_mode = "300 point" ; determines which kind of height map is created/loaded global g_probe_mode = "two consecutive" ; determines if z proving used consecutive or averaging global g_level_mode = "4 point" ; determines if 3 or 4 points are used for leveling global g_print_beg_prime = 10 ; default - set desired in filament config.g global g_print_beg_retract = 0 ; default - set desired in filament config.g global g_print_end_retract = 0 ; default - set desired in filament config.g global g_print_end_mode = "heat off" ; determines if heaters are turned off when print is done ; Drives_________________________________________________________________________ ;Main board______________________________________________________________________ M569 P0 S0 ; Physical drive 0 . X1 M569 P1 S1 ; Physical drive 1 . X2 M569 P3 S1 ; Physical drive 3 . Main Extruder M569 P4 S0 ; Physical drive 4 . Secondary Extruder ;Duex5 board_____________________________________________________________________ M569 P5 S0 ; Physical drive 5 . Y M569 P6 S0 ; Physical drive 6 . Z1 (0,0) M569 P7 S0 ; Physical drive 7 . Z2 (600,0) M569 P8 S0 ; Physical drive 8 . Z3 (600,600) M569 P9 S0 ; Physical drive 9 . Z4 (0,600) ;Settings_________________________________________________________ M584 X0:1 Y5 Z6:7:8:9 E3:4 P3 ; Driver mapping U1 M671 X-189:-189:645:645 Y645:-64:-64:645 S10 ; Anticlockwise ;;M671 X-190:-190:641:641 Y-63:643:643:-63 S10 ; Anticlockwise ;___________________________________________________________________ M350 X16 Y16 I1 ; Configure microstepping with interpolation U16 M350 Z16 E16:16 I0 ; Configure microstepping without interpolation M92 X100.00 Y100.00 Z2000.00 E686:700 ; Set steps per mm U100.00 M566 X300 Y500 Z100.00 E120.00:120.00 P1 ; Set maximum instantaneous speed changes (mm/min) U240 M203 X18000.00 Y18000.00 Z300.00 E1200.00:1200.00 ; Set maximum speeds (mm/min) U9000.00 M201 X1000 Y1000 Z120.00 E250.00:250.00 ; Set accelerations (mm/s^2) U1000 ;M566 X240 Y360 Z30.00 E120.00:120.00 U240 P1 ; Set maximum instantaneous speed changes (mm/min) ;M203 X9000.00 Y9000.00 Z200.00 E1200.00:1200.00 U9000.00 ; Set maximum speeds (mm/min) ;M201 X1000 Y1000 Z120.00 E250.00:250.00 U1000 ; Set accelerations (mm/s^2) M204 P500 ; Set print and travel accelerations (mm/s^2) M906 X1800 Y1800.00 E1270:1270 I40 ; Set motor currents (mA) and motor idle factor in per cent (E1270 per dyze) U1800 M906 Z1800.00 I50 ; Set motor currents (mA) and motor idle factor in per cent M84 S100 ; Set idle timeout - 100 seconds ; Axis Limits M208 X0 Y0 Z-1 S1 ; set axis minima M208 X590 Y580 Z630 S0 ; set axis maxima ; Endstops ;;M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop ;;M574 U1 S1 P"e0stop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop M574 X1 S1 P"xstop + e0stop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop M574 Y2 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop ; add probe file ; global.g_probe_z_trigger ; global.g_probe_z_trigger = 1.9 ; default - set as appropriate for the Z probe M558 P9 C"^zprobe.in" H5 F120 T6000 A1 R1 ; set Z probe type to bltouch and the dive height + speeds M950 S0 C"duex.pwm5" ; set probe pin M98 P"config_probe.g" M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters woher kommt der test wie wurde der Winkel bestimmt Unklar! M376 H10 ; stop z-leveling after 10 layers ; Z-Probe ;M558 P9 C"^zprobe.in" H5 F120 T6000 A1 R1 ; set Z probe type to bltouch and the dive height + speeds ;M950 S0 C"duex.pwm5" ; set probe pin ;M98 P"config_probe.g" ; configure probe after a reboot or reset ;global g_probe_z_trigger = 1.8 ; default - set as appropriate for the Z probe ;;G31 P500 X-30 Y0 Z2.64 ; set Z probe trigger value, offset and trigger height **** Z height change + 0.29 **** ;;M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters ;;M557 X0:560 Y0:580 S90:108.75 ; define mesh grid and probe points, fine S30:36.25 ;;M376 H10 ; Height (mm) over which to taper off the bed compensation ; Heaters___________________________________________________________ M140 H-1 ; disable heated bed (overrides default heater mapping) ;M308 S0 P"bedtemp" Y"thermistor" A"Bed Heat" T100000 B3950 ; define bed temperature sensor ;M950 H0 C"bedheat" T0 Q10 ;heater 0 uses the bed_heat pin, sensor 0, PWM 10hz ;E0_________________________________________________________________ M308 S0 P"spi.cs1" Y"rtd-max31865" A"Main Extruder" ; create sensor number 1 as a PT100 sensor in first position daughterboard M950 H0 C"e0heat" T0 ; create nozzle heater output on e0heat and map it to sensor 0 M307 H0 B0 R2.004 C403.6:385.3 D14.93 S1.00 V23.8 ; PID calibration M143 H0 S450 ; set temperature limit for heater 0 to 450C ;E1_________________________________________________________________ M308 S1 P"spi.cs2" Y"rtd-max31865" A"Support Extruder" ; create sensor number 2 as a PT100 sensor in sec position daughterboard ;M950 H1 C"e1heat" T1 ; create nozzle heater output on e1heat and map it to sensor 1 TEMP OFF ;M307 H1 B0 S1.00 ; PID calibration TEMP OFF ;M143 H1 S450 ; set temperature limit for heater 1 to 450C TEMP OFF ;E4_________________________________________________________________ M308 S1 P"duex.e4temp" Y"thermistor" T100000 B4267 ; configure sensor 1 as thermistor on pin e1temp M950 H5 C"duex.e4heat" T1 ; create nozzle heater output on e4heat and map it to sensor 4 ;M307 H5 B0 S1.00 ; PID calibration M143 H5 S120 ; set temperature limit for heater 1 to 120C ; Fans & LED___________________________________________________________ M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned on M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned on M950 F2 C"fan2" Q500 ; create air filter fan on fan 2 on pin fan2 and set its frequency M106 P2 S0 H-1 ; set fan 2 value. Thermostatic control is turned on M950 F7 C"!duex.fan7" Q500 ; create LED on pin fan7 and set its frequency M106 P7 S0 H-1 ; Disable fan channel for LED M106 P7 S255 ; remove ";" to set the LED to full brightness by default M950 F3 C"duex.fan3" Q500 ; create fan 3 on pin fan3 and set its frequency M106 P3 S1 H-1 ; set fan 3 value. Thermostatic control is turned on Bed relay to on ; Tools______________________________________________________________ ;T0_________________________________________________________________ M563 P0 S"E0 Main" D0 H0 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S265 ; set initial tool 0 active and standby temperatures to 0C ;T1_________________________________________________________________ M563 P1 S"E1 Support" D1 H1 F1 ; define tool 1 G10 P1 X0 Y65 Z0 ; set tool 1 axis offsets Y-2 moves filament 2mm to back of machine X-1 moves filament 1mm to the right G10 P1 R0 S265 ; set initial tool 1 active and standby temperatures to 0C ;T2____________________________________________________________________ ;M563 P2 S"BED TEMP" H-1 ;Temp off ;G10 P2 ;Temp off ;T3___________________________________________________________________ M563 P3 S"CHAMBER TEMP" H5 G10 P3 R0 S40 ; Custom settings__________________________________________________ M591 D0 P1 C"duex.e2stop" S1 ; Regular filament sensor for E0 M591 D1 P1 C"duex.e3stop" S1 ; Regular filament sensor for E1 ;M950 P2 C"fan2" Q500 M42 P2 S255 ; Start up air filter ; Automatic power saving____________________________________________ M911 S22.5 R29.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss. Power Failure Pause
@fcwilt
I am just not picking up this coding. I have spent 5 days straight on this.Question - So when a Error pops up it is there to tell you there is a problem and to point you in the direction of the problem to fix the issue, I assume ?
So, when I get a -
Error: in file macro line 44 column 10: meta command: 'break' was not inside a loopHow do I know what macro, and column is the spot on line 10?
Amazing.
What are the odds you would have global variables with the exact same names as mine.
In any case the variable mentioned in the error appears more than once in your config.g file but they are all commented out.
Enable the second one (the one with 1.9) by removing the comment character.
Also I see these two commands:
M558 P9 C"^zprobe.in" H5 F120 T6000 A1 R1 M950 S0 C"duex.pwm5"
They should be moved to your config_probe.g file. If they are already in that file simply remove them from your config.g file.
@fcwilt
So, when I get a -
Well I test each macro as I code it so I know which macro is creating the error. Then since the error messages tells me what line and column I can focus in on the error.
I don't move on to some other coding until the macro is error free.
Do you have a bed.g file?
If so post it here, please.
Ok so me making 100 changes at once is not good ! LOL
;M98 P"config_probe.g" ; insure probe is using most recent configuration values G29 S2 ; cancel mesh bed compensation M290 R0 S0 ; cancel baby stepping G90 ; absolute moves G1 Z5 F99999 ; insure Z starting position is high enough to avoid probing errors ; M671: Define positions pf manual bed levelling screws or Z leadscrews ; Xnn:nn:nn... list of between 2 and 4 X coordinates of the leadscrews that drive the Z axis or the bed levelling screws ; Ynn:nn:nn... list of between 2 and 4 Y coordinates of the leadscrews that drive the Z axis or the bed levelling screws ; Snn maximum correction allowed for each leadscrew in mm (optional, default 1.0) ; Pnnn pitch of the bed levelling screws (not used when bed levelling using independently-driven leadscrews). Defaults to 0.5mm which is correct for M3 bed levelling screws ; Fnn fudge factor, default 1.0 M671 X-189:-189:645:645 Y645:-64:-64:645 S10 ; Anticlockwise ; --- level bed --- while true ; run leveling pass G30 P0 X10 Y10 Z-99999 ; probe near a leadscrew G30 P1 X570 Y10 Z-99999 ; probe near a leadscrew G30 P2 X570 Y570 Z-99999 ; probe near a leadscrew G30 P3 X10 Y570 Z-99999 S4 ; probe near a leadscrew and calibrate 4 motors if move.calibration.initial.deviation < 0.02 break ; check pass limit - abort if pass limit reached if iterations = 5 M291 P"Bed Leveling Aborted" R"Pass Limit Reached" abort "Bed Leveling Aborted - Pass Limit Reached" ; --- finish up --- ; --- set Z=0 datum which can be affected by leveling --- G1 X270 Y270 ; move probe to center of bed - set values aaa and bbb as appropriate G30 ; do single probe which sets Z to trigger height of Z probe
; config_probe.g ; config the probe and call the other files.g M558 P9 C"^zprobe.in" H5 F120 T6000 A1 R1 M950 S0 C"duex.pwm5" G31 P25 X-30 Y0 Z1.688 ; set Z probe trigger value, offset and trigger height (larger value is closer)G31 P500 X-18 Y24 Z2.917
that is my bed.g
and config_probe.g -
that is my bed.g
and config_probe.gOK your config_probe.g file looks good. So remove the commands I mentioned from config.g
Please upload your bed.g file using the "upload file" tag. I will edit it to correct the errors.
You simply have not used the required indentation.
Got the lines changed in the config.g
Here is the bed.g
bed.g -
Here is homeall.g
; homeall.g ; called to home all axes G91 ; relative positioning G1 H2 Z5 F200 ; lift Z relative to current position G1 H1 X-605 Y605 F3000 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X5 Y-5 F600 ; go back a few mm G1 H1 X-605 Y605 F600 ; move slowly to X and Y axis endstops once more (second pass) G90 ; absolute positioning M98 P"config_probe.g" G30 ; home Z by probing the bed G1
mesh.g
M98 P"config_probe.g" ; insure probe is using most recent configuration values G29 S2 ; cancel mesh bed compensation M290 R0 S0 ; cancel baby stepping G90 ; absolute moves ; --- set Z=0 datum which is needed for creating a heightmap G1 Z5 F99999 ; insure Z starting position is high enough to avoid probing errors G1 X270 Y270 ; move probe to center of bed - set values aaa and bbb as appropriate G30 ; do single probe which sets Z to trigger height of Z probe M557 X0:560 Y0:580 S58 ; define mesh grid 420 points S58 G28 G29 S0 ; probe bed and create height map
So another question. Modix had a Macro -
Automatic tilt calibration + Bed Compensation - 101 pointsThat Macro has all changed now with your code correct ?
So how do I run the bed tilt calibration
and the bed probe calibration ?I am confused on it I wipe those clean and add a M98 P"bed.g"
and run it trough the macro
or just type that into the console comand ?
