    M106 behaviour
    228
    • tecnoundefined
      tecno
      Can I get some help to get part cooling fan to work.
      Snippet from gcode
      G92 E0.0000
      G1 E-6.0000 F2100
      ; layer 2, Z = 0.772
      M106 S255
      ; tool H0.222 W0.400
      Running PLA first layer fan off and want to have 100% from layer 2. But nothing happens.
      This is what is set in S3D
      This in config.g
      M950 F0 C"121.out1" Q500 ; create fan 0 on pin out5 and set its frequency // PART FAN
      M106 P0 S0 H-1
      Advise on this is appreciated.
      alankilianundefined 1 Reply Last reply Reply Quote 0
      • alankilianundefined
        alankilian @tecno
        @tecno
        That all matches my system and my fan turns on at layer 2 as expected.
        Here's my tool configuration. Is yours the same?
        Post your complete config.g for others to look at to see if something else is wrong.
        tecnoundefined 1 Reply Last reply Reply Quote 1
        • tecnoundefined
          tecno @alankilian
          @alankilian
          M950 F0 C"121.out1" ; create fan 0 on pin out5 and set its frequency // PART FAN
          M106 P0 S0 H-1 ; P0 = fan0 S0 = Speed 0 H-1 = Disable Termostatic mode
          M950 P0 C"121.out2" ; create fan 1 on pin out6 and set its frequency // TOOL FAN
          M42 P0 S1 ; P1 = fan1 S1 = Speed 100% H1 = Enable Thermostatic mode T45 = start at 45°C
          M950 P2 C"out3" ; create fan 2 on pin out3 and set its frequency // Main Board Fan
          M42 P2 S1 ; P2 = fan2 S1 = speed 100% H-1 = Disable Termostatic mode
          M563 P1 D0 H1 F1 ; P1 = tool1 D0 = ext drive H1 = heater1 F1 = fan1
          G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
          G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
          tecnoundefined 1 Reply Last reply Reply Quote 0
          • tecnoundefined
            tecno @tecno
            F0 not F1 right?
            engikeneerundefined 1 Reply Last reply Reply Quote 1
            • engikeneerundefined
              engikeneer @tecno
              @tecno your second and third M950 command have P0 and P2, where I think you want F1 and F2 respectively
              i3 clone with a bunch of mods
              • tecnoundefined
                tecno @engikeneer
                @engikeneer
                https://forum.duet3d.com/topic/28182/toolboard-fixed-fan
                  engikeneer @tecno
                  @tecno ah sorry I misunderstood your comments!
                  In that case your M563 tool definition should reference F0 (as that's the part cooling fan you've created), not F1.
                  FYI I'm guessing if you run M98 P"config.g" you'll see an error on that line
                  • tecnoundefined
                    tecno @engikeneer
                    @engikeneer
                    No you can not see that error with M98 P"config.g"
