    Issues with pressure advance since RRF 3.4
    308
    37.9k
    • MartinNYHCundefined
      MartinNYHC @gloomyandy
      @gloomyandy My extruder is clogged 🤕 Will do the test prints tomorrow.
      • R4ffersundefined
        R4ffers @gloomyandy
        @gloomyandy I'm also using rapido hotend now, was using a dragon SF. I've just changed from SBC to standalone which hasn't altered the results.
        Mb6hc + 3hc + 1lc on Voron V2.4, Mini 5+ exp 2+ on Vzbot 235 AWD, Duet 2 wifi on Ox CNC and Mini 5+ on Millennium Milo v1.5 mini mill.
        • Heartleander81undefined
          Heartleander81
          I have this corner issuse to.
          My System
          Duet 3 6 hc SBC
          Duet 3 1lc
          Rapido Hotend
          Hextrudort Extruder ( ~ 20mm tube from extruder to hotend )
          Test with extruder on toolboard and on the MB direkt but the corners issuse ob both connection.
          Test with IS on and off at both connection.
          My PA bevor the issuse was 0.035.
          When I turned up the PA to 0.04, the wall on the corners open it.
          Need you more Info?
          Config.g?
          M122?
          I print a simple Cube with 40x40x2mm
          Argoundefined 1 Reply Last reply Reply Quote 1
          • Argoundefined
            Argo @Heartleander81
            @MartinNYHC has no access to the printer at the moment so maybe @Heartleander81, could you do these tests? https://forum.duet3d.com/post/297234
            1. A print using RRF 3.3 (ideally both with and without the toolboard)
            2. A print using RRF 3.4 but with input shaping disabled (again with and without a toolboard)
            3. A print using RRF 3.4 with input shaping enabled (I think we already have these, but it would be good to confirm them with the same settings and gcode).
              Hopefully all test prints using the same filament etc.
              Heartleander81
              @Argo
              With which file?
              Which settings?
              I only have PETG filament at home.
              oh flashing back to 3.3, I don't know how that works and whether I changed something from 3.3 to 3.4 in the Config.g, I unfortunately don't know anymore either.
              The problem with and without Toolboard is. I don't have an adapter and then have to re-solder the cable from the motor every time.
              My tests up to now (cube 40x40x2) show that with 3.4.3 the corners are always the same. Whether with toolboard IS on or off and without toolboard with IS on or off. The corners only get smaller when I print a lot slower than 60mm/s
              Argoundefined 1 Reply Last reply Reply Quote 0
              • Argoundefined
                @Heartleander81
                Flashing to 3.3 is the same procedure as flashing ton 3.4.
                Just upload the files to the system folder.
                Maybe the result will be different with RRF 3.3.
                If not then maybe we’ll have to send our printers to Duet3D.
                Heartleander81undefined 1 Reply Last reply Reply Quote 0
                  Heartleander81
                  I use SBC not standalone
                    Phaedrux Moderator @Heartleander81
                    @Heartleander81 said in Issues with pressure advance since RRF 3.4:
                    Try this: https://github.com/DanalEstes/DuetVersions
                      Heartleander81 @Phaedrux
                      @Phaedrux
                      Sorry I doun't understand what I must do.
                      The git can I clone but what now?
                      I think I must install ore copy files on the pi but what and who.
                        @Heartleander81
                        I believe you can also use apt-get to retrieve a specific version.
                        sudo apt-get install <package name>=<version>
                        Though I haven't done that myself.
                        Also see here: https://docs.duet3d.com/User_manual/Machine_configuration/DSF_RPi#downgrade-packages
                        Heartleander81undefined 2 Replies Last reply Reply Quote 0
                          @Phaedrux sudo apt-get install duetsoftwareframework=3.3.0 doun't work
                            @Phaedrux ok have 3.3.0 on MB and Toolboard. Now I test with is on is off extruder on MB and the same with Toolboard
                              Heartleander81 @Argo
                              @Argo
                              3.3.0 PA 0.045 Extruder onToolboard
                              3.3.0 PA 0.045 Extruder on Mainboard
                              3.4.4 PA 0.045 Extruder on Toolboard with IS
                              3.4.4 PA 0.045 Extruder on Toolboard without IS
                              3.4.4 Extruder on Mainboard with IS and without IS look the same
                              Printed clockwise.
                              Outer walls, inner walls, bottom layer and top layer all at 200mm/s.
                              First layer with 90mm/s .
                              The part is 2mm high with the dimensions 40x40mm.
                              Layer height is 0.2mm.
                              ; Drive direktion
                              M569 P0.1 S0 D2 H20 V2000 				; X physical drive 0.1 goes backwards
                              M569 P0.2 S0 D2 H20 V2000 				; Y physical drive 0.2 goes backwards
                              M569 P0.0 S1 D2 							; Z1 physical drive 0.0 goes forwards
                              M569 P0.4 S1 D2 							; Z2 physical drive 0.4 goes forwards
                              M569 P0.3 S1 D2							; Z3 physical drive 0.3 goes forwards
                              M569 P0.5 S0 D2 							; (free) physical drive 0.5 goes forwards
                              M569 P20.0 S1 D2						; E physical drive 0.0 Driver0 tool goard goes forwards
                              ; Motor mapping and steps per mm
                              M584 X0.1 Y0.2 Z0.0:0.4:0.3 E20.0			; set drivers mapping
                              M350 X16 Y16 Z16 I1						; configure microstepping 1/16 with interpolation
                              M350 E16								; configure microstepping 1/16
                              M92 X80.40 Y80.40 Z800.00 E705.485		; set steps per mm
                              ; Drive currents
                              M906 X1300 Y1300 Z950 E900 				; set motor currents (mA)
                              M906 I80								; motor idle factor in per cent
                              M84 S120 								; set idle timeout
                              ; Acceleration and speed
                              M566 X1800.00 Y1800.00 Z90.00 E3000.00 P1	; set maximum instantaneous speed changes (mm/min)
                              M203 X30000.00 Y30000.00 Z900.00 E15000.00	; set maximum speeds (mm/min)
                              M201 X6000.00 Y6000.00 Z100.00 E1800.00		; set accelerations (mm/s^2)
                              M201.1 Z40.00								; Homimg smooth ACC
                              ; Accelerometer
                              M955 P20.0 I10 S1344 R10			; R12 Accelerometer 20:0 type LIS3DH with orientation 10 samples at 1344Hz with 10-bit resolution
                              ; PA, IS
                              ; At config-override.g
                              • Argoundefined
                                @Heartleander81 thanks a lot!
                                @gloomyandy does this help now? 🙂
                                • gloomyandyundefined
                                  gloomyandy @Argo
                                  @Argo I'm not sure it does. From what I can see there is not any significant difference between with and without a toolboard, nor is there any difference between 3.3 and 3.4 (when IS is off). The only thing I can see is that there may be some interaction between IS and PA. At least that's my take on the pictures, perhaps others see something different? My understanding is that the advice is to tune PA after you have selected a value for IS, so in this case perhaps a different PA value would remove the differences between the with and without IS cases....
                                  The odd thing is that I'm not sure that any of the above tests shows the same degree of bulging corner seen in the sample posted here: https://forum.duet3d.com/post/297824 Which seems a little strange.
                                  Heartleander81undefined Argoundefined 2 Replies Last reply Reply Quote 0
                                    Heartleander81 @gloomyandy
                                    @gloomyandy
                                    The problem is that the Pa is already increased in the pictures. I used to always use a Pa of 0.035.
                                    In the pictures you can see with 0.045 Pa that the walls open in front of the corner but the corner is still sticking out. No longer at a 45° angle but in the direction of travel.
                                    If I remember correctly without PA they stand out at a 45° angle.
                                      gloomyandy @Heartleander81
                                      @Heartleander81 Could you edit your previous post (the one with the 4 photos) and either add your config.g file or add details of acceleration, jerk, max speed etc. Also what speed did you set in the slicer for the various walls and infill?
                                      Also what was the print direction when printing those tests? I'm guessing it was clockwise with the seam at the bottom left corner?
                                        @gloomyandy
                                        That's right, the Z seam is on the bottom left.
                                        Is Edit with Config.g data
                                        • ladkiiundefined
                                          ladkii
                                          I just flashed RRF 3.4 beta 2 as this is the first beta that mentions input shaping and I assume PA has been rewritten for input shaping.
                                          • Argoundefined
                                            Argo @gloomyandy
                                            @gloomyandy
                                            Yup, that does not surprise me. I‘m also getting similar results with RRF 3.3 / 3.4 - IS on / off.
                                            So what would be the next step to find the issue?
