Issues with pressure advance since RRF 3.4
@Argo Flipper on a RRF board is a kind of a disgrace.
@Argo Well there certainly seems to be a bulge on the top right corner in that test print. It also looks like you are using a different filament.... Is this using the same gcode as the RRF case becuase the seam looks like it may be in the bottom right corner, I thought it was in a different place in the RRF prints?
Unfortunately I don't think you can run RRF with the same hardware setup, so again it is going to be hard to compare like for like....
Bottom left and top right have a small bulge.
PA was set to 0.05 which is a little bit too low. For RRF I need 0.08 to get similar results and the SuSl feature to switch between PA values whilst printing because PA 0.08 would cause defects all over the place which I'm still getting.The hardware / printer was the same except for the tool board. Unfortunately Klipper can't communicate with the 1LC that's why I had to make a mess in my room and needed 2m of cables or so to wire up the BTT tool board.
I just wanted to rule out a hardware issue and show that is has to be somehow software related.Things we tried or can rule out:
- extruder (I tried LGX and LDO Orbiter 2.0)
- tool board (someone tried with and without in this thread)
- nozzle (I switched from Bondtech CHT to E3D V6)
- stepper motors (I switched the motor when switching from LGX to Orbiter 2.0)
- RRF 3.3 and RRF3.4 (same results for me and others)
I have another printer (bed slinger) that's also running a Duet 3 Mini with RRF 3.4. This printer has no issues with bulging corners.
Could it be a issue with the CoreXY logic RRF uses? -
@gloomyandy no, on Duet 3 6hc.
I think that not only z but all axles brake harder. But I'll record it and open another topic and ask if Duet wanted it that way.
@Argo Was the Klipper setup using the same speeds/accelerations as your RRF configuration? Have you printed the test using the same filament? It really is important to try and keep as many things the same if possible. I suspect that PA values do not map 1:1 between Klipper and RRF. I think if you really want to rule out hardware you probably need to connect the extruder directly to the main board (because that way you can use both Klipper and RRF with the same hardware), but I can uderstand why that would be a total pain....
If you are going to test further I'd suggest getting the Klipper setup as good as you can (probably without input shaping for now). Then once you have what you think are two setups that are as close as possible to each other and you think there is a significant difference between them, ideally using the same filament, gcode settings etc, post photos of both along with the klipper and RRF configurations and slicer settings. Hopefully @jay_s_uk can have a go at reproducing the problem as he has a setup that can be switched between RRF and Klipper pretty easily. I think for this test it might be best just to use a single PA setting for RRF rather than the dynamic stuff that gives better results.
@Heartleander81 Yes please start a new thread and provide details of what you think the change is, though honestly if there was a change in something like this I would have expected to see lots of comments about it already....
@gloomyandy its probably the change between stealthchop being default to spreadcycle being default...
and I better run some more tests. @Argo do we have a consensus on the test piece? your one with curves and a square in the middle or just a 40 x 40 x 2 cube?
I've made a more efficient version of the model to save time and filament:
I would set the seam to rear. Otherwise it'll be at one of the corners.
@gloomyandy
Yep it's a total pain as I would need to rewire all the chains. My Klipper test was just a dirty hang all wires along the frame to the top and to the tool head method. And during the test I held the wires to they don't get caught lol. -
@Argo Does that mean you can't easily run any further Klipper tests?
I can but not for weeks as itβs quite the mess here and not really safe to print unattended.
I can print the test again with adjustments to flow and PA. Iβll post the results soon.
Inputshaping does not decrease print quality with Klipper as long you stay within the recommended acceleration settings. -
@Argo I'd rather you keep input shaping off with Klipper (and with RRF) as that just simplifies things (as it does seem to have an impact on RRF).
Bumped PA up from 0.05 to 0.052. I think maybe 0.054 could be the optimal value.
Decreased flow a tiny bit to improve top layer quality.
(Klipper)The result is quite comparable to what I get with RRF with "dynamic PA" (0.05 -> 0.08).
Sorry that I had to switch color. The bright green is empty after tons of testing. -
@Argo No problem, could you post your klipper and slicer settings (maybe post the gcode file you used with Klipper as that will have a lot of the details in it).
For Klipper itself nothing fancy.
square corner velocity = 5 mm/s
max feedrate = 350 mm/s
max acceleration = 5000 mm/sSlicer speed settings:
Been following this thread for a while now,
, and wondering if there's been any concrete, official update?
Latest official statement is that the Duet team can't reproduce the issue so I assume there won't be a fix. That's why I'm glad I found a partial fix by using Super Slicer extrusion roles:
https://forum.duet3d.com/post/298231
At the moment I'm using 0.052 PA for every role except perimeter which use 0.075 PA (PLA filament). -
@Argo said in Issues with pressure advance since RRF 3.4:
At the moment I'm using 0.052 PA for every role except perimeter which use 0.075 PA (PLA filament).As you found, that isn't great though, since the change in PA causes the printer to dwell.
From my own testing a while ago I had noticed a difference in extruder jerk when I was getting some bulging corners. After retuning E jerk and PA it improved.
Has anyone noticed a difference in E jerk?
@Phaedrux possibly. It at least seems to be very sensitive to it. Right now, with even just a low poly curved surface, each segment is ~1.5mm long, I get a bulge at every direction change.
Yes, definitely.
If I increase or decrease the extruder pressure, I can influence whether there is more or less overshoot. But I can't get rid of it completely.
