Duet 3 Mini 5+ with New 3HC, Suddenly Wifi Disconnects
I just added a 3HC to my setup, and now i suddenly have wifi disconnects almost continuously. This is the first time i have booted up and started using the printer since adding expansion.
Its an IDEX machine with Duet 3 Mini 5+ running 2 toolboards over can bus. all working normally. Now i have added a 3HC in the middle of the mini 5>3HC>toolboard 1>toolboard 2.
when i run homeall, the motion and homing completes normally. but during or usually at the completion, the DWC disconnects from wifi and i must manually chose the wifi connection to regain communication.
same if i run G29 bed level or G32 bed mesh. it disconnects pretty quickly after running those.
config.g
; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"V-Core3" ; set printer name M669 K11 Y1:-1:0:-1 ; Dual Markforged Kinematics https://forum.duet3d.com/topic/7796/haq-xy/125 https://forum.duet3d.com/topic/21021/dual-markforged-kinematics?_=1672244913067 ;M669 K1 X1:0:0:0 Y1:-1:0:-1 Z0:0:1:0 U0:0:0:1; Matrix mapping for Axis - X:Y:Z:U G21 ; Set Units to Millimeters ; Network M552 S2 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet G4 S2 ; wait for expansion boards to start ; Drives M569 P0.0 S0 D2 ; Left Z physical drive 0.0 goes forwards M569 P0.1 S0 D2 ; Rear Z physical drive 0.1 goes forwards M569 P0.2 S0 D2 ; Right Z physical drive 0.2 goes forwards M569 P0.3 S1 D2 ; Right U toolhead drive 0.3 goes forwards M569 P0.4 S1 D2 ; Left X toolhead drive 0.4 goes forwards M569 P0.5 S0 D2 ; Left Y drive 0.5 goes forwards M569 P0.6 S1 D2 ; Right Y drive 0.6 goes reverse M569 P20.0 S1 D2 ; Extruder physical drive 20.0 goes forwards M569 P21.0 S1 D2 ; Extruder physical drive 21.0 goes forwards M584 Z0.0:0.1:0.2 Y0.5:0.6 X0.4 U0.3 E20.0:21.0 ; set drive mapping M350 U16 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation M92 U80.0 X80.00 Y80.00 Z800.00 E690:690 ; set steps per mm M906 U2000 X2000 Y2000 Z1800 E1000:1000 I30 ; set motor currents (mA) and motor idle factor in per cent -- safe for Duet 3 mini 5+ M84 S30 ; Set idle timeout M566 U500.00 X500.00 Y500.00 Z60.00 E300:300 P1 ;E300:120 P1 ;X1500.00 Y1500.00 Z6.00 E300 P1 ;E120.00 P1 ; set maximum instantaneous speed changes (mm/min) M203 U30000.00 X30000.00 Y30000.00 Z1000.00 E7200:7200 ;E7200:3600 ;E3600.00 ; set maximum speeds (mm/min) M201 U10000.00 X10000.00 Y10000.00 Z100.00 E10000:10000 ;E10000:3600 ;E3600.00 ; set accelerations (mm/s^2) M207 S0.6 F7200 Z0.2 ; firmware retraction orbiter 2.0 ; Axis Limits M208 X-70 U0 Y0 Z0 S1 ; set axis minima M208 X310 U380 Y306 Z300 S0 ; set axis maxima ;M208 X-70:310 Y0:308 U0:308 Z0:300 ; Endstops M574 X1 S1 P"20.io2.in" ; configure active high endstops Toolhead 1 low end M574 U2 S1 P"21.io2.in" ; configure active high endstops Toolhead 2 high end M574 Y2 S1 P"io2.in" ; configure active high endstops. IO0 and IO1 also are UART, so do not put endstops on them, use them elsewhere to free up UART. M574 Z1 S2 M671 X-4.5:155:304.5 Y-4.5:305:-4.5 S5 ; define positions of Z leadscrews or bed levelling screws ;M557 X30:280 Y20:300 P5 ; define 5x5 mesh grid M557 X30:280 Y20:270 P5 ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Keenevo 600W Bed" ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 Q10 ; Define Heater0 as the heated bed, bind to Sensor0 M140 H0 P0 ; Define Heated Bed M307 H0 R0.602 K0.401:0.000 D2.44 E1.35 S1.00 B0 ; PID Tuning for Heater0, Heated Bed (100C) M143 H0 S140 ; Set temperature limit for Heater0 to 120C M308 S1 P"20.temp0" Y"thermistor" T100000 B4725 C7.060000e-8 A"Slice Hotend 0" ;Slice Engineering 300C thermistor, settings are online M950 H1 C"20.out0" T1 Q100 ; Define Heater1 as Extruder0 heater, bind to Sensor1 M307 H1 R2.808 K0.368:0.000 D4.56 E1.35 S1.00 B0 V23.8 ; PID Tuning for Heater1, Extruder0 (240C) M143 H1 S325 ; Set temperature limit for heater 1 to 285C M308 S2 P"temp1" Y"thermistor" T100000 B3950 C7.060000e-8 A"Chamber" ; configure sensor 2 as thermistor on pin temp1 M950 H2 C"out1" T2 ;Q10 ; create chamber heater output on out1 and map it to sensor 2 M307 H2 R0.01 K0.200:0.000 D60 E1.35 S1.00 B1 ; enable bang-bang mode for the chamber heater and set PWM limit M141 H2 ; map chamber to heater 2 M143 H2 S120 ; set temperature limit for heater 2 to 60C M308 S3 P"21.temp0" Y"pt1000" A"Slice Hotend 1" ;Slice Engineering RTD PT1000 450C, settings are online M950 H3 C"21.out0" T3 Q100 ; Define Heater1 as Extruder0 heater, bind to Sensor1 M307 H3 R2.808 K0.368:0.000 D4.56 E1.35 S1.00 B0 V23.8 ; PID Tuning for Heater1, Extruder0 (240C) M143 H3 S325 ; Set temperature limit for heater 1 to 285C M308 S4 P"20.temp1" Y"thermistor" A"Cooling Block" T100000 B3950 C7.060000e-8 ; Define Sensor as Chamber temperature M308 S5 Y"drivers" A"4028 Power" ; 4028 power using spare heater M308 S6 Y"mcu-temp" A"Mini 5+ MCU" ; Define Sensor3 as the integrated MCU temperature sensor M308 S7 Y"drivers" A"Mini 5+ TMC Drivers" ; Define Sensor4 as the TMC overheat sensor M308 S8 Y"mcu-temp" P"20.dummy" A"Toolboard0 MCU" M308 S9 Y"drivers" P"20.dummy" A"1LC0 Stepper" M308 S10 Y"mcu-temp" P"21.dummy" A"Toolboard1 MCU" M308 S11 Y"drivers" P"21.dummy" A"1LC1 Stepper" M308 S12 Y"mcu-temp" P"1.dummy" A"3HC MCU" M308 S13 Y"drivers" P"1.dummy" A"3HC TMC Drivers" M308 S14 P"temp2" Y"thermistor" T100000 B3950 C7.060000e-8 A"Orbiter Motor" ; configure sensor 9 as thermistor on pin temp2 M308 S15 P"spi.cs1" Y"thermocouple-max31856" K"K" A"TC0 Chamber Heater"; define temperature sensor number 10 as a K Type thermocouple on the first port of a temperature daughter board plugged into the expansion board with CAN bus address 3. M308 S16 P"spi.cs2" Y"thermocouple-max31856" K"K" A"TC1 Chamber Fins"; define temperature sensor number11 as a T Type thermocouple on the first port of a temperature daughter board plugged into the expansion board with CAN bus address 3. ; Fans M950 H4 C"!out2" T2 Q10 ;H2 ; Define Heater2 as the 4028 fan power, bind to Sensor3 M143 H4 P2 S200 ; Needed M143 to set max temp so the graph scaled correctly M950 F0 C"!20.out1+out1.tach" Q25000 ;Q500 ; create fan 0 on pin out4 and set its frequency M106 P0 C"T0 Layer Fan" L0.0 X1.0 S0 H-1 B0.1 ; set fan 0 name and value. Thermostatic control is turned off M950 F1 C"20.out2+out2.tach" Q500 ; Fan 1 uses out3, and using out3.tach as a tacho input M106 P1 C"T0 Hotend Fan" S0 H1 T45 ; set fan 1 name and value. Thermostatic control turned on for Hotend M950 F2 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency M106 P2 C"Mini 5+ Board Fan" S0 H5:6:7 T45 ; set fan 1 name and value. Thermostatic control turned on for Hotend M950 F3 C"!out3+out3.tach" Q500 ; Chamber Heater Fan Noctua NF-F12 Industrial M106 P3 C"Chamber Heater Fan" H11 T30 ; S0.3 L0.3 X0.6 B0.1 T30:40 ; set fan 1 name and value. Thermostatic control turned on for Hotend. M950 F4 C"out6" Q500 ; create fan 4 for Water Cooling 12V Fan 4 on pin out4 and set its frequency M106 P4 C"Radiator Cooling Fan" S0 H4 T35 ; set fan 1 name and value. Thermostatic control turned on for liquid cooling hotend M950 F5 C"out4+out4.tach" Q500 ; create fan 4 for Water Cooling 12V Fan 4 on pin out4 and set its frequency M106 P5 C"Liquid Cooling Pump" S0 H4 T20 ; set fan 1 name and value. Thermostatic control turned on for liquid cooling hotend M950 F6 C"!21.out1+out1.tach" Q25000 ;Q500 ; create fan 6 on pin out4 and set its frequency M106 P6 C"T1 Layer Fan" L0.0 X1.0 S0 H-1 B0.1 ; set fan 6 name and value. Thermostatic control is turned off M950 F7 C"21.out2+out2.tach" Q500 ; Fan 7 uses out3, and using out3.tach as a tacho input M106 P7 C"T1 Hotend Fan" S0 H3 T45 ; set fan 7 name and value. Thermostatic control turned on for Hotend M950 F8 C"1.out6" Q500 ; create fan 1 on pin out5 and set its frequency M106 P8 C"3HC Board Fan" S0 H12:13 T45 ; set fan 1 name and value. Thermostatic control turned on for Hotend ; Tool 0 X Axis M563 P0 D0 H1 X0 F0 S"Mosquito Mag Liquid" ; define tool 0 G10 P0 X0 Y0 Z0 S210 R175 ; ; set tool 0 axis offsets, set initial tool 0 active 60C and standby temperatures to 0C ; Tool 1 U Axis M563 P1 D1 H3 F6 X3 S"Mosquito Mag Air" ; define tool 0 G10 L1 P1 U-0.10 X0 Y2.54 Z0 S210 R175 ; ; set tool 0 axis offsets, set initial tool 0 active 60C and standby temperatures to 0C ; Tool 2-- copy mode M563 P2 S"copy mode" D0:1 H1:3 X0:3 F0:6 ; tool 2 uses both extruders and hot end heaters, maps X to both X and U, and uses both print cooling fans G10 P2 X77.5 Y0 U-77.5 S0 R0 ; set tool offsets and temperatures for tool 2 M567 P2 E1:1 ; set mix ratio 100% on both extruders for copy mode ;M568 P2 S1 ; turn on mixing for tool 2 ; Tool 3-- mirror mode ;M563 P3 S"mirror mode" D0:1 H1:3 X0:3 F0:6 ; tool for mirror mode ;G10 P3 X77.5 Y0 U-77.5 S0 R0 ; tool offset for mirror mode (flipped X offset) ;M567 P3 E1:1 ; set mix ratio 100% on both extruders for mirror mode ;M568 P3 S1 ; turn on mixing for tool 2 ; Z-Probe Inductive Probe ;M558 P5 C"20.io0.in" H5 F400 T5000 ; set Z probe type to unmodulated and the dive height + speeds M558 P8 C"^20.io0.in" H8 F400 T9000 A1 ; S0.01 ; set Z probe type to unmodulated and the dive height + speeds G31 P1000 X-28 Y-20 Z10.54 ; Z8.86 ; K0 ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed ;; BLTouch ; M950 S0 C"io7.out" ; Create a servo pin on io7 ; M558 P9 C"io7.in" H5 F240 T10800 A5 ; set Z probe type to unmodulated and the dive height + speeds ; G31 P25 X-28.00 Y-13.00 Z0.78 ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed ;Accelerometer M955 P20.0 I16 ;Input Shaper M593 P"zvdd" F44 ; for 10k acceleration ;M593 P"mzv" F42.5 ; for 15k acceleration ;Filament Sensor0 ;M591 D0 P3 C"20.io1.in" S1 ;M591 D0 L27 R10:190 ;PanelDue 5i M575 P1 S1 B57600 ;NeoPixels x3 M150 X3 Q4000000 ;R128 U128 B128 P128 S2 F0 M150 X3 R255 U255 B255 W255 P255 S2 F0 ; display led ; Custom settings G29 S1 M572 D0:1 S0.01 ; set Pressure Advance K-factor M501 M376 H3 ;M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss global daemonLoop = true ; init filament sensor error global variables if !exists(global.filamentTimestamp) global filamentCounter = 0 global filamentTimestamp = state.Uptime ; init print time logging if !exists(global.runtime) M98 P"runtime.g" ; init LED variables if !exists(global.warmUp) global warmUp = false ; Select default tool M404 N1.75 ; Define filament diameter for print monitor T0 M122
2/12/2023, 1:20:06 PM M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.4.2 (2022-09-13 15:14:33) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: J6RFD-NR6KL-K65J0-409NN-LK02Z-7M5YU Used output buffers: 1 of 40 (29 max) === RTOS === Static ram: 103684 Dynamic ram: 113556 of which 156 recycled Never used RAM 20956, free system stack 130 words Tasks: NETWORK(notifyWait,14.1%,233) HEAT(notifyWait,0.1%,348) Move(notifyWait,0.0%,278) CanReceiv(notifyWait,0.1%,774) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.0%,348) TMC(notifyWait,1.2%,72) MAIN(running,83.5%,425) IDLE(ready,0.1%,30) AIN(delaying,0.9%,263), total 100.0% Owned mutexes: === Platform === Last reset 00:08:36 ago, cause: power up Last software reset at 2023-02-10 06:23, reason: User, GCodes spinning, available RAM 22020, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 516134, completed 516134, timed out 0, errs 0 Step timer max interval 1467 MCU temperature: min 35.6, current 43.6, max 45.6 Supply voltage: min 20.2, current 24.1, max 27.5, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/872/840, gc cycles 1 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 17, reads 46863, writes 17, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 17, reads 46863, writes 17, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 17, reads 46863, writes 17, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 17, reads 46863, writes 17, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 17, reads 46863, writes 17, timeouts 0, DMA errors 0, CC errors 0 Driver 5: standstill, SG min 0, read errors 0, write errors 0, ifcnt 17, reads 46863, writes 17, timeouts 0, DMA errors 0, CC errors 0 Driver 6: standstill, SG min 0, read errors 0, write errors 0, ifcnt 17, reads 46863, writes 17, timeouts 0, DMA errors 0, CC errors 0 Date/time: 2023-02-12 13:20:05 Cache data hit count 874953800 Slowest loop: 15.20ms; fastest: 0.07ms === Storage === Free file entries: 9 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 3.3ms, write time 2.1ms, max retries 0 === Move === DMs created 83, segments created 21, maxWait 85726ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 121, completed 121, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters 2 -1 -1 -1, ordering errs 0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 S10 " in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === CAN === Messages queued 4788, received 29067, lost 0, boc 0 Longest wait 3ms for reply type 6053, peak Tx sync delay 31, free buffers 18 (min 17), ts 2581/2580/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 12.56ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 = WiFi = Network state is active WiFi module is providing access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.27 WiFi MAC address ea:68:e7:e5:63:f4 WiFi Vcc 3.38, reset reason Power up WiFi flash size 2097152, free heap 25248 WiFi IP address 192.168.1.10 Connected clients 1 Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0 i now see this new message which i didnt have previously.
M98 P"config.g"
2/12/2023, 1:21:25 PM Error: bad model parameters Accelerometer 20:0 type LIS3DH with orientation 16 samples at 1344Hz with 10-bit resolution Warning: the height map was loaded when the current Z=0 datum was not determined by probing. This may result in a height offset. Warning: Macro file config-override.g not found Error: in file macro line 186 column 20: meta command: variable 'daemonLoop' already exists 2/12/2023, 1:21:23 PM M98 P"config.g" HTTP is enabled on port 80 FTP is disabled TELNET is disabled 2/12/2023, 1:21:05 PM Error: bad model parameters Accelerometer 20:0 type LIS3DH with orientation 16 samples at 1344Hz with 10-bit resolution Warning: the height map was loaded when the current Z=0 datum was not determined by probing. This may result in a height offset. Warning: Macro file config-override.g not found Error: in file macro line 186 column 20: meta command: variable 'daemonLoop' already exists 2/12/2023, 1:21:03 PM M98 P"config.g" HTTP is enabled on port 80 FTP is disabled TELNET is disabled -
@RogerPodacter said in Duet 3 Mini 5+ with New 3HC, Suddenly Wifi Disconnects:
= WiFi =
WiFi module is providing access pointI just wanted to check to make sure I understand your networking.
The Duet is providing a WiFi access point and you are connecting to it using your PC?
Have you run an M587 to setup the SSID and password when running the duet as an access point?
Sorry if this is all basic stuff, I have a Duet/Ethernet, and most people run their Duet/WiFi as a client so I'm full of questions right now.
@alankilian yes you read it correctly. i run my Duet as an access point and connect directly to its IP address using my laptop. I havent changed this for many months so it should still be working normally. (dont have any issues with it to speak of).
i have now run a few prints and havent seen any disconnects during printing. so maybe everything is good. i will keep checking...
This is another thing that's a little funny.
Is your power supply getting so loaded down that it can't quite maintain proper voltage to the board?
Adding another board, even if it's a low-power-consumption board might have pushed your power supply over the edge.
Hi do a M122 in console and see what the signal strength is like .
Can you send M122 B# where #is the canbus address of the 3hc board and make sure the firmware matches?
You should also probably update the firmware anyway by uploading the full 3.4.5 zip file. That should update the 3hc as well.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2and3Firmware-3.4.5.zip
i think the voltage is ok now. i'm not sure why it showed such a voltage drop. but this is a new power supply i specifically added for this expansion; its a new 24V 20A power supply which i'm only using about 10A total.
here is another M122 today of the mainboard.
2/13/2023, 9:24:06 AM M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.4.2 (2022-09-13 15:14:33) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: J6RFD-NR6KL-K65J0-409NN-LK02Z-7M5YU Used output buffers: 11 of 40 (40 max) === RTOS === Static ram: 103684 Dynamic ram: 115560 of which 28 recycled Never used RAM 18600, free system stack 118 words Tasks: NETWORK(notifyWait,49.3%,195) HEAT(notifyWait,0.6%,336) Move(notifyWait,0.6%,261) CanReceiv(notifyWait,1.2%,772) CanSender(notifyWait,0.0%,325) CanClock(delaying,0.1%,339) TMC(notifyWait,13.5%,72) MAIN(running,24.9%,417) IDLE(ready,0.3%,30) AIN(delaying,9.5%,263), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 17:29:25 ago, cause: software Last software reset at 2023-02-12 15:54, reason: User, GCodes spinning, available RAM 18840, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x04 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 62965840, completed 62965840, timed out 0, errs 0 Step timer max interval 1487 MCU temperature: min 40.4, current 43.6, max 45.6 Supply voltage: min 23.2, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/1152/1120, gc cycles 169 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 173, reads 22478, writes 23, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 173, reads 22478, writes 23, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 173, reads 22478, writes 23, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 177, reads 22473, writes 27, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 177, reads 22472, writes 27, timeouts 2, DMA errors 0, CC errors 0, failedOp 0x6f Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 178, reads 22474, writes 27, timeouts 0, DMA errors 0, CC errors 0 Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 179, reads 22474, writes 27, timeouts 0, DMA errors 0, CC errors 0 Date/time: 2023-02-13 09:24:06 Cache data hit count 4294967295 Slowest loop: 200.38ms; fastest: 0.07ms === Storage === Free file entries: 9 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 9.0ms, write time 16.4ms, max retries 0 === Move === DMs created 83, segments created 41, maxWait 3517145ms, bed compensation in use: mesh, comp offset 0.026 === MainDDARing === Scheduled moves 16902, completed 16902, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 7], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters 2 -1 -1 -1, ordering errs 0 Heater 2 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 S10 " in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === CAN === Messages queued 588706, received 3526774, lost 0, boc 0 Longest wait 7ms for reply type 6013, peak Tx sync delay 389, free buffers 18 (min 11), ts 314829/314828/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 196.47ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 = WiFi = Network state is active WiFi module is providing access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.27 WiFi MAC address ea:68:e7:e5:63:f4 WiFi Vcc 3.38, reset reason Power up WiFi flash size 2097152, free heap 24184 WiFi IP address 192.168.1.10 Connected clients 2 Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0 M122 B1 for the 3HC expansion.
M122 B1 Diagnostics for board 1: Duet EXP3HC rev 1.02 or later firmware version 3.4.1 (2022-06-01 21:15:27) Bootloader ID: SAME5x bootloader version 2.4 (2021-12-10) All averaging filters OK Never used RAM 158772, free system stack 178 words Tasks: Move(notifyWait,0.1%,160) HEAT(notifyWait,2.6%,88) CanAsync(notifyWait,0.0%,69) CanRecv(notifyWait,1.6%,82) CanClock(notifyWait,0.8%,71) TMC(notifyWait,774.5%,99) MAIN(running,112.9%,436) IDLE(ready,0.0%,40) AIN(delaying,138.5%,263), total 1030.9% Last reset 17:40:08 ago, cause: software Last software reset data not available Driver 0: pos 0, 80.0 steps/mm,standstill, SG min 0, mspos 8, reads 35365, writes 11 timeouts 0, steps req 0 done 0 Driver 1: pos 0, 80.0 steps/mm,standstill, SG min 0, mspos 8, reads 35366, writes 11 timeouts 0, steps req 0 done 0 Driver 2: pos 0, 80.0 steps/mm,standstill, SG min 0, mspos 8, reads 35367, writes 11 timeouts 0, steps req 0 done 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0 Peak sync jitter -9/12, peak Rx sync delay 182, resyncs 0/0, no step interrupt scheduled VIN voltage: min 23.6, current 24.2, max 24.3 V12 voltage: min 12.3, current 12.3, max 12.3 MCU temperature: min 28.2C, current 32.1C, max 33.3C Last sensors broadcast 0x00003000 found 2 91 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 1017737, send timeouts 0, received 1081318, lost 0, free buffers 37, min 37, error reg 0 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0 -
@Phaedrux said in Duet 3 Mini 5+ with New 3HC, Suddenly Wifi Disconnects:
https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2and3Firmware-3.4.5.zipYour firmwares on the boards are mismatched, which can lead to unexpected problems, please update the firmware by uploading that zip file, then check the boards firmware versions again to ensure they match up.
