    Input Shaping plugin "Machine is not homed!"
    503
    • jjudeundefined
      jjude
      I'm trying to run "Record Motion Profile" but I get a message "Machine is not homed!".
      All axes is homed.
      Input Shaping plugin 3.4.1-b1, DWC 3.4.3, Duet2 Wifi firmware 3.4.3.
      Sparkfun accelerometer
      https://www.sparkfun.com/products/13963
      Wiring and config https://docs.duet3d.com/User_manual/Connecting_hardware/Sensors_Accelerometer
        Please update to 3.4.5 and update the plugin as well.
        Upload this zip file to the system tab in DWC.
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2and3Firmware-3.4.5.zip
        https://plugins.duet3d.com/plugins/InputShapingPlugin.html
        jjudeundefined 1 Reply Last reply Reply Quote 0
        • jjudeundefined
          jjude @Phaedrux
          @Phaedrux said in Input Shaping plugin "Machine is not homed!":
          3.4.5
          Duet Web Control 3.4.5
          Duet 2 WiFi/Ethernet 3.4.5
          Input Shaping 3.4.1-b1
          will still come
          Rushmere3Dundefined 1 Reply Last reply Reply Quote 0
          • Rushmere3Dundefined
            Rushmere3D @jjude
            @jjude What happens if you click the Home All button?
            Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
            • jjudeundefined
              jjude @Rushmere3D
              @Rushmere3D
              The printer drives the axes home, nothing else happens.
              The notification remains, NEXT is gray
                Please post your full config.g and homing files.
                • jjudeundefined
                  jjude @Phaedrux
                  @Phaedrux
                  Please try to find out..
                  homez.g homey.g homex.g homeall.g config.g
                  • jjudeundefined
                    jjude @jjude
                    @jjude
                    I removed config.g the filament changer motors and axes, now working fine!
                    • T3P3Tonyundefined
                      T3P3Tony administrators @jjude
                      @jjude how are you configuring the filament changer motors? if you are configuring them as axes rather than extruders then those will be the unhomed axes that are causing the issues.
                      If you need to keep them as axes rather than extruders then either home them, or send G92 A0 B0 C0
                      or whatever the axes are to se them to a known position (does not need to be 0).
                      www.duet3d.com
