    Duet mini 5 lulzbot won’t drive extruder
    649
    • anthony1mundefined
      anthony1m
      Hello I am currently converting a lulzbot mini v2, to a duet 3 mini5, I am able to get everything working except the extruder it just buzzes. I can hook up that stepper to another driver and it works fine and vise versa , But it won’t drive the extruder not sure that I’m doing wrong this printer prints 2.85 mm filament. I could use some help
      jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @anthony1m
        @anthony1m m122 output please as well as your config
        • anthonymundefined
          anthonym
          ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
          ; generated by RepRapFirmware Configuration Tool v3.3.16 on Wed Mar 22 2023 18:56:16 GMT-0600 (Mountain Daylight Time)
          M575 P1 S1 B57600                               ; enable support for PanelDue
          G90                                             ; send absolute coordinates...
          M83                                             ; ...but relative extruder moves
          M550 P"My Printer"                              ; set printer name
          M552 S1                                         ; enable network
          M586 P0 S1                                      ; enable HTTP
          M586 P1 S0                                      ; disable FTP
          M586 P2 S0                                      ; disable Telnet
          M569 P0.0 S1                                    ; physical drive 0.0 goes forwards
          M569 P0.1 S1                                    ; physical drive 0.1 goes forwards
          M569 P0.2 S1                                    ; physical drive 0.2 goes forwards
          M569 P0.4 S1                                    ; physical drive 0.4 goes forwards
          M569 P0.3 S1                                    ; physical drive 0.3 goes forwards
          M584 X0.0 Y0.1 Z2:3 E0.4                    ; set drive mapping
          M350 X16 Y16 Z16 E16:16 I1                      ; configure microstepping with interpolation
          M92 X80.00 Y80.00 Z80.00 E80:80.00          ; set steps per mm
          M566 X900.00 Y900.00 Z60.00 E120.00:60.00      ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z200.00 E1200.00:200.00 ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z100.00 E250.00:100.00      ; set accelerations (mm/s^2)
          M906 X1300 Y1300 Z1300 E1350:1300 I30           ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                         ; Set idle timeout
          M208 X0 Y0 Z0 S1                                ; set axis minima
          M208 X245 Y250 Z200 S0                          ; set axis maxima
          M574 X1 S1 P"io2.in"                            ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io2.in
          M574 Y1 S1 P"io4.in"                            ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io4.in
          M574 Z1 S2                                      ; configure Z-probe endstop for low end on Z
          M950 S0 C"io3.out"                              ; create servo pin 0 for BLTouch
          M558 P9 C"io3.in" H5 F120 T6000                 ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X0 Y0 Z2.5                             ; set Z probe trigger value, offset and trigger height
          M557 X15:215 Y15:195 S20                        ; define mesh grid
          M308 S0 P"temp0" Y"thermistor" T100000 B4138    ; configure sensor 0 as thermistor on pin temp0
          M950 H0 C"out0" T0                              ; create bed heater output on out0 and map it to sensor 0
          M307 H0 R0.391 K0.323:0.000 D1.74 E1.35 S1.00 B0; disable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                         ; map heated bed to heater 0
          M143 H0 S120                                    ; set temperature limit for heater 0 to 120C
          M308 S1 P"temp1" Y"thermistor" T100000 B4138    ; configure sensor 1 as thermistor on pin temp1
          M950 H1 C"out1" T1                              ; create nozzle heater output on out1 and map it to sensor 1
          M307 H1 R3.215 K0.349:0.000 D6.27 E1.35 S1.00 B0 V24.1 ; disable bang-bang mode for heater  and set PWM limit
          M143 H1 S280                                    ; set temperature limit for heater 1 to 280C
          M950 F0 C"out4" Q500                            ; create fan 0 on pin out4 and set its frequency
          M106 P0 S0 H0 T45                               ; set fan 0 value. Thermostatic control is turned on
          M950 F1 C"out3" Q500                            ; create fan 1 on pin out3 and set its frequency
          M106 P1 S1 H0 T45                               ; set fan 1 value. Thermostatic control is turned on
          M563 P0 D0 H1 F0                                ; define tool 0
          G10 P0 X0 Y0 Z0                                 ; set tool 0 axis offsets
          G10 P0 R0 S0                                    ; set initial tool 0 active and standby temperatures to 0C
          • anthonymundefined
            anthonym
            RepRapFirmware for Duet 3 Mini 5+ version 3.4.5 (2022-11-30 19:41:16) running on Duet 3 Mini5plus WiFi (SBC mode)
            Board ID: 98BFS-8396U-D65J0-40KMA-3K03Z-RBNJ0
            Used output buffers: 1 of 40 (19 max)
            Static ram: 103652
            Dynamic ram: 98320 of which 12 recycled
            Never used RAM 39656, free system stack 146 words
            Tasks: SBC(ready,1.2%,478) HEAT(notifyWait,0.0%,358) Move(notifyWait,0.0%,290) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.0%,341) TMC(notifyWait,0.7%,82) MAIN(running,97.2%,502) IDLE(ready,0.0%,30) AIN(delaying,0.8%,272), total 100.0%
            Owned mutexes: HTTP(MAIN)
            Last reset 00:21:41 ago, cause: power up
            Last software reset at 2023-03-23 19:14, reason: User, GCodes spinning, available RAM 39656, slot 0
            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task SBC Freestk 0 n/a
            Error status: 0x00
            Aux0 errors 0,0,0
            MCU revision 3, ADC conversions started 1301325, completed 1301323, timed out 0, errs 0
            Step timer max interval 1490
            MCU temperature: min 19.1, current 32.8, max 32.9
            Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
            Events: 0 queued, 0 completed
            Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 14, reads 2921, writes 14, timeouts 0, DMA errors 0, CC errors 0
            Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 14, reads 2921, writes 14, timeouts 0, DMA errors 0, CC errors 0
            Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 14, reads 2921, writes 14, timeouts 0, DMA errors 0, CC errors 0
            Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 14, reads 2920, writes 14, timeouts 0, DMA errors 0, CC errors 0
            Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 2926, writes 9, timeouts 0, DMA errors 0, CC errors 0
            Driver 5: not present
            Driver 6: not present
            Date/time: 2023-03-26 02:39:27
            Cache data hit count 2919028547
            Slowest loop: 61.18ms; fastest: 0.07ms
            === Storage ===
            Free file entries: 10
            SD card 0 not detected, interface speed: 0.0MBytes/sec
            DMs created 83, segments created 3, maxWait 1081036ms, bed compensation in use: none, comp offset 0.000
            === MainDDARing ===
            Scheduled moves 7, completed 7, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
            === AuxDDARing ===
            Segments left: 0
            Movement lock held by null
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            SBC is idle in state(s) 0
            Daemon is idle in state(s) 0
            Aux2 is idle in state(s) 0
            Code queue is empty
            === CAN ===
            Messages queued 11616, received 0, lost 0, boc 0
            Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 6506/0/0
            Tx timeouts 0,0,6505,0,0,5109 last cancelled message type 30 dest 127
            === SBC interface ===
            Transfer state: 5, failed transfers: 0, checksum errors: 0
            RX/TX seq numbers: 50349/50349
            SPI underruns 0, overruns 0
            State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x0f1bc
            Buffer RX/TX: 0/0-0, open files: 0
            === Duet Control Server ===
            Duet Control Server v3.4.5
            Code buffer space: 4096
            Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
            Full transfers per second: 0.32, max time between full transfers: 59.1ms, max pin wait times: 36.6ms/12.4ms
            Codes per second: 0.00
            Maximum length of RX/TX data transfers: 3276/572
            3/25/2023, 7:35:42 PM	Connected to 192.168.0.113
              Phaedrux Moderator @anthony1m
              @anthony1m said in Duet mini 5 lulzbot won’t drive extruder:
              vise versa
              Meaning you can hook up a different motor to that driver and it works?
              How are you commanding extrusion?
              anthonymundefined 2 Replies Last reply Reply Quote 0
              • anthonymundefined
                anthonym @Phaedrux
                @Phaedrux correct and I can hook the motor to another driver and it works fine , Just whatever driver is E wont work I can switch e to driver 1 and wont work , I can run z2 on driver 4 no problem.
                • anthonymundefined
                  anthonym @Phaedrux
                  @Phaedrux the motor will turn outside but has no torque can stop it by hand.
                    droftarts administrators @anthonym
                    @anthonym for all of these commands, remove the second E parameter:
                    anthonymundefined 2 Replies Last reply Reply Quote 1
                    • anthonymundefined
                      anthonym @droftarts
                      @droftarts M350 X16 Y16 Z16 E16: I1 ; configure microstepping with interpolation
                      M92 X80 Y80 Z80 E420:80 ; set steps per mm
                      M566 X900 Y900 Z150 E420:150 ; set maximum instantaneous speed changes (mm/min)
                      M203 X6000.00 Y6000.00 Z300.00 E120.00: ; set maximum speeds (mm/min)
                      M201 X500.00 Y500.00 Z300.00 E250.00: ; set accelerations (mm/s^2)
                      M906 X1300 Y1300 Z1300 E150: I30 ; set motor currents (mA) and motor idle factor in per cent
                      • anthonymundefined
                        anthonym @droftarts
                        @droftarts still does the same thing. I have another stepper I also tried and same thing. if I move over to the x driver it works. Same basically it wont drive e.
                          Phaedrux Moderator @anthonym
                          @anthonym said in Duet mini 5 lulzbot won’t drive extruder:
                          Is this what you changed it to? Try this
                          M92 X80.00 Y80.00 Z80.00 E80 ; set steps per mm
                          M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                          M203 X6000.00 Y6000.00 Z200.00 E1200.00 ; set maximum speeds (mm/min)
                          M201 X500.00 Y500.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
                          M906 X1300 Y1300 Z1300 E1350 I30 ; set motor currents (mA) and motor idle factor in per cent
                          Also send M98 P"config.g" in the gcode console and copy and paste any error messages here.
                          • anthonymundefined
                            anthonym @Phaedrux
                            @Phaedrux Yes
                            • anthonymundefined
                              anthonym @Phaedrux
                              @Phaedrux said in Duet mini 5 lulzbot won’t drive extruder:
                              M98 P"config.g"
                              Error: in file macro line 27: M566: array too long, max length = 1
                              anthonymundefined 1 Reply Last reply Reply Quote 0
                              • anthonymundefined
                                anthonym @anthonym
                                @anthonym Error: in file macro line 26: M92: array too long, max length = 1
                                  Did you use the block from me above?
                                  • anthonymundefined
                                    anthonym @Phaedrux
                                    @Phaedrux Yes that seems to have fixed it !!
                                      FYI these errors were because you didn’t remove the second E parameter.
                                      You also left the colons : in after the first E parameter value, which may not have helped. And the motor had no torque as you had set it to 150mA:
                                      • anthonymundefined
                                        anthonym @droftarts
                                        @droftarts Its seem to be working , I see that now thank you for explaining I really appreciate the help.
                                        • anthonymundefined
                                          anthonym @droftarts
                                          so the issue I am having now it’s extruding way too much if I ask for 10mm I get over 100 my steps per mm are 420 on the aero 2.85 mm with a .5 nozzle.
                                          • T3P3Tonyundefined
                                            T3P3Tony administrators @anthonym
                                            @anthonym send M92 and M350 from the command line and see what they report.
                                            www.duet3d.com
                                            anthonymundefined anthony1mundefined 2 Replies Last reply Reply Quote 1
                                            • T3P3Tonyundefined T3P3Tony has marked this topic as unsolved
