    Web interface AJAX timeouts
    40
    6.0k
    • RCarlyleundefined
      RCarlyle
      I am getting a significant number of web interface disconnects. It was intermittent while tooling around in files, but is happening repeatedly while printing. I'm printing a Benchy and am 10 minutes in and I've had three AJAX timeouts. Nope, four, another just happened while typing. The first was while probing at the start of the print. Then they've been every few minutes after that. The print continues without issue, but sometimes I have to wait a little bit (10-20 sec? haven't timed it) before it will successfully reconnect. And there's timeout #5 during minute 13. And there's #6 at minute 16. So this is a pretty consistent "every 2-4 minutes" thing.
      I have my AJAX timeout set to 20 seconds. That seems pretty long to me. Should I try making it longer?
      Are there any diagnostics I can do to help troubleshoot this?
      On that note, is there any way to post screenshots on this forum without having to upload them somewhere else first?
      M122 dump after 7 AJAX timeouts:
      [[language]]
      10:28:57 PM
      M122
      Diagnostics
      Used output buffers: 1 of 32 (5 max)
      Platform Diagnostics:
      Memory usage:
      Program static ram used: 13012
      Dynamic ram used: 57876
      Recycled dynamic ram: 2840
      Current stack ram used: 2736
      Maximum stack ram used: 7760
      Never used ram: 49584
      Last reset 00:19:28 ago, cause: software
      Error status: 0
      Bed probe heights: -0.034 -1.068 -0.589 0.149 0.554 0.314 -0.174 -0.324 0.405 0.178 0.208 -0.545 -0.049 0.000 0.000 0.000
      Free file entries: 9
      SD card interface speed: 20.0MBytes/sec
      SD card longest block write time: 8.8ms
      MCU temperature: min 45.1, current 48.9, max 52.8
      Supply voltage: min 24.0, current 24.3, max 24.7
      Slowest main loop (seconds): 0.088455; fastest: 0.000000
      Move Diagnostics:
      MaxReps: 9, StepErrors: 0\. Underruns: 32
      Heat Diagnostics:
      Bed heater = 0, chamber heater = -1
      Heater 0 is on, I-accum = 0.0
      Heater 1 is on, I-accum = 141.9
      GCodes Diagnostics:
      Move available? yes
      Stack pointer: 0 of 5
      macro is idle
      http is ready with "M122"
      telnet is idle
      serial is idle
      aux is idle
      file is idle
      Network Diagnostics:
      WiFiServer is running
      SPI underruns 0, overruns 0
      Webserver Diagnostics:
      HTTP sessions: 1 of 8
      • curieosundefined
        curieos
        I'm getting them too, but not while doing anything (not have it in printer yet, haven't had time). I got the gcode output log from when mine dced but DC said it just looked like a regular disconnect request. My thread I have opened is about the same issue I think, the latest dc I've had the error message just said it timed out.
        She/Her
        I work at a local 3D printing shop.
        Printers: Micron+ w/Duet 3 Mini, in-progress adaptation of the Jubilee REL onto an E3D MS, Prusa i3 MK3S.
        • koko76undefined
          koko76
          Happening to me as well. I get a stretch of a bunch of them in a row, and then nothing for a while. Had a print finish last night, and no timeout since then, but last night there were many.
            As these disconnects are so sporadic, my guess is that they may be caused by temporary loss of the wireless connection. DWC doesn't allow for that, so it's on my list to allow at least one retry after a timeout.
            • elmoretundefined
              elmoret
              Same here, about one timeout related disconnect every 15 minutes. AJAX timeout set to 20s.
              • RCarlyleundefined
                RCarlyle
                Haven't had any timeouts yet tonight. Currently 36 minutes into a print.
                • RCarlyleundefined
                  RCarlyle
                  It's really weird that some nights I get the timeouts constantly, and some nights I make it 4+ hours without one.
                  • elmoretundefined
                    elmoret
                    I'm seeing the same behavior here.
                    • RCarlyleundefined
                      RCarlyle
                      Not sure what just happened, but I had an AJAX timeout in the middle of uploading a file, and the web interface lost the ability to upload files until I reloaded the interface page (in Chrome). When I clicked Upload & Print, it would open the file selection dialog, and then upon selecting the file nothing would happen. Persisted through power cycling the printer. Reloading the web page (which took ~20+ seconds) fixed it.
                      • briangilbertundefined
                        briangilbert
                        This has just happened to me as well, except I was unable to reload the web interface without power cycling the duet
                        Co-creator of the Zesty Nimble direct drive extruder
                        • elmoretundefined
                          elmoret
                          The AJAX errors are really my only complaint at this point, everything else has been smooth sailing.
                          • roboduetundefined
                            roboduet
                            @RCarlyle:
                            Not sure that I'm right, but it seems like such long times with page reload caused by this: https://www.duet3d.com/forum/thread.php?pid=402#p402
                            • curieosundefined
                              curieos
                              I'm printing now but I keep getting timeouts. I got two in a row after restarting the same print (had to power cycle the printer both times) and then this one got a ways in before it timed out. The print is still going, but I need to reconnect to increase the temp by 5 degrees. Its been 25 minutes since the DC and I still can't connect.
                              She/Her
                              • T3P3Tonyundefined
                                T3P3Tony administrators
                                Nyl0cke, check out the resolution on this thread:
                                https://www.duet3d.com/forum/thread.php?id=38&p=2
                                It will be interesting to see what effect this has
                                www.duet3d.com
                                • roboduetundefined
                                  roboduet
                                  Seems like this fix is only for static files (css/html/js) coming from Duet to browser. But not for dynamic ajax responses.
                                  • curieosundefined
                                    curieos
                                    Yeah I'm also still getting a lot of errors. About the same amount, maybe more but its a small sample size so it might be coincidence.
                                    She/Her
                                      1. Those of you who are getting Ajax disconnects: is the Error Reason at the bottom of the box always given as timeout?
                                      2. If you ever find that you can't reconnect after a disconnect, please try the following if possible:
                                      A. Close the browser tab, open a new one and try to connect in that.
                                      B. If that doesn't work, use Pronterface or PanelDue to send M552 S0 followed by M552 S1 to restart the wifi module. Then try to connect.
                                      C. If that doesn't work, run M122 from Pronterface and see what the number of free buffers is.
                                      • curieosundefined
                                        curieos
                                        Yes for me. I canceled the print I had going (had a mechanical problem I had to fix) and I updated the web server and now I can't keep connected for more than a couple minutes it seems. its been anywhere between 30 seconds to 8 minutes right now.
                                        I'll try what you said when it happens again
                                        She/Her
                                        • pjr3Dundefined
                                          pjr3D
                                          1. It certainly is for me.
                                            • A. Connect from another browser instance (machine) works but is slow
                                          B. Hasn't been necessary yet and I have no paneldue on this machine
                                          C. Will try next time if I can't reconnect
                                          Seems to be worse after I went from wired-wifi connection to wifi-wifi after I moved my laptop. Upload speeds dropped to ~250k (even seen 30-40k on smallish files!).
                                          Hope you can find a fix for timeouts as well as speed.
                                          • curieosundefined
                                            curieos
                                            Okay, If it disconnects I can not reconnect by opening a new tab and trying to connect. If I connect to the board via serial I can turn off the server and turn it back on and I can connect.
                                            I can leave it connected but I can't test while printing for a while, the mount I used for my hotend isn't working very well, the hotend is moving around in its mount (flying extruder) a good 3mm or so.
                                            I also tried reconnecting on a different computer to no avail.
                                            She/Her
