    Software bundle 3.5.0-beta.3 now available
    Beta Firmware
    11
    28
    2.0k
      On behalf of the Duet3D team I am please to announce the availability of the latest 3.5 beta software release. This release provides pressure advance synchronised to input shaping, which should make pressure advance tuning more or less independent of any input shaping that is configured. Additionally, input shaping is supported on axes whose motors are driven by CAN-connected expansion boards, for example our Expansion 1HCL closed loop stepper driver board.
      Also included in RepRapFirmware are several minor feature improvements, bug fixes, and a preview of the forthcoming support for scanning Z probes. Duet Web Control now displays and checks its own version and the versions of firmware on any expansion boards against the main board firmware version, and warns if there are any discrepancies.
      Please read at least the Upgrade Notes section of the release noted before updating your software; and if you are upgrading from a version older than 3.5beta2, the upgrade notes for releases you have skipped too.
      RRF release notes: https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-Beta#reprapfirmware-350beta3
      DWC release notes: https://github.com/Duet3D/DuetWebControl/wiki/Changelog-DWC-3.x-Beta#version-350-beta3
      DSF release notes: https://github.com/Duet3D/DuetSoftwareFramework/wiki/Changelog-DSF-3.x-Beta#version-350-beta3
      Users running in standalone mode can find the new files at https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.0-beta.3. Users running with attached SBC should upgrade from the unstable feed on the Duet3D package server,
      If you encounter any new problems with this release, please report them in a new thread with [3.5.0-beta.3] included in the title, or in an existing thread with that tag that describes a similar problem.
      Argoundefined lparnell34undefined 2 Replies Last reply Reply Quote 10
      • sebkritikelundefined
        sebkritikel
        Fortuitous timing! just finished commissioning and running a print with a new 1HCL. Looking forward to testing input shaping with the expansion board!
        Large(ish?) IDEX - 6HC, 1HCL
        Stratasys Dimension 1200es to 6HC Conversion
        • CCS86undefined
          CCS86
          Thank you!
          Any headway on input shaping during short segments?
          ctilley79undefined 1 Reply Last reply Reply Quote 0
            jay_s_uk
            Don't forget that ReleaseMgr can be used to help identify any config changes required etc!
            • ctilley79undefined
              ctilley79 @CCS86
              @CCS86 said in Software bundle 3.5.0-beta.3 now available:
              Thank you!
              What's the shortest segment right now?
              CCS86undefined 1 Reply Last reply Reply Quote 0
              • CCS86undefined
                CCS86 @ctilley79
                @ctilley79 said in Software bundle 3.5.0-beta.3 now available:
                Thank you!
                There no specific "shortest segment". It can vary depending on a number of different settings. But, if the input shaping cannot be applied completely on a single segment, it is not applied at all.
                This means that for any curves, including tiny filleted corners no input shaping is applied.
                ctilley79undefined o_lampeundefined 2 Replies Last reply Reply Quote 0
                • mikeabuilderundefined
                  mikeabuilder
                  Excellent. Thanks for all the effort, RRF-ers/Dueters.
                    ctilley79 @CCS86
                    Thank you!
                    How does klipper handle it? Same limitation?
                    • o_lampeundefined
                      o_lampe @CCS86
                      Is it the same with G2/G3 arcs? I'm using arcwelder to convert to arcs...
                      Do you have ringing in those filleted corners? I'd think, the tool ist too slow there to show resonance.
                      • CCS86undefined
                        CCS86 @o_lampe
                        @o_lampe said in Software bundle 3.5.0-beta.3 now available:
                        Big time ringing on sharpish filleted corners.
                        Yes, should be the same on G2 / G3. RRF doesn't truly support arcs, they just get decomposed to linear segments, which in my experience are more coarse then the segments I get with high res STLs and my slicer settings.
                        • Argoundefined
                          Argo @dc42
                          Pressure advance / corners have been vastly improved! Corners are crisp and infill lines are strong even with input shaping enabled.
                          Edit:
                          I take my below reporting back. The printer was behaving very odd today. The extruder changed it's direction and changed it back after pausing. I decided to format the SD card + Reset the board with the button + Flashed the firmware via the boot loader / mounted the board directly to the PC.
                          Now the printer is behaving as expected and the extrusion issue is also gone. I don't know what went wrong there. Maybe the countless flashes with RRF and Klipper I did in the past did leave some left overs.
                          I had something similar back in the Duet 2 days after several beta flashes where I also had a bug which I could not reproduce after resetting the board.
                          But another thing is new and I've just checked my e-steps to rule that out: My slicer extrusion multiplier decreased from 0.91 to 0.89 for PLA.
                          Is anyone else noticing that? As long as PA is working fine I can live with that but it's odd that after the update I had to re-calibrate my EM.
                          Edit:
                          I've had to decrease EM to 0.868 in order to have a mechanical fit of two parts without much friction.
                          But you can see that the layers have gaps which indicates under extrusion. My old calibrated EM was 0.91.
                          Something seems off I guess?
                          • CCS86undefined
                            CCS86 @Argo
                            @Argo
                            You shouldn't be tuning flow rate to achieve a fitment.
                            Tune flow rate to achieve proper bonding of adjacent lines. Then tune X/Y steps, and CAD geometry for fit.
                            Argoundefined 1 Reply Last reply Reply Quote 0
                            • Argoundefined
                              Argo @CCS86
                              @CCS86
                              Worked flawlessly for the past 6 years on several printers.
                              • CCS86undefined
                                CCS86 @Argo
                                @Argo
                                That doesn't mean it is the correct approach.
                                Flow has a very direct relationship to under/over extrusion and much less effect on part size. So, tuning flow to adjust part size and causing under/over extrusion should be no surprise.
                                Tuning XY steps or shrinkage/scale in your slicer has a perfectly direct relationship on part size and no effect on extrusion accuracy.
                                So, first get your flow tuned right.
                                Second, get your parts printing geometrically accurately.
                                Third, tune your CAD clearance/allowance for the fit you want.
                                • Argoundefined
                                  Argo @CCS86
                                  @CCS86
                                  Thanks but Flow is tuned right but it won’t work this this beta release. Flashing to previous build or Klipper and the problem is gone.
                                  • lparnell34undefined
                                    lparnell34 @dc42
                                    @dc42 Is there a scanning z probe that you have tried or could recommend?
                                      dc42 administrators @lparnell34
                                      @lparnell34 I am looking at two scanning Z probe solutions. One is a version of our IR sensor, with modified firmware to produce an output related to the height of the sensor above the bed plate. This may work if we can find a suitable consistent surface to use with the sensor. Some of the modern flex plates may be suitable. The second is a small inductive sensor add-on to our tool board.
                                      tecnoundefined 1 Reply Last reply Reply Quote 0
                                      • tecnoundefined
                                        tecno @dc42
                                        @dc42 said in Software bundle 3.5.0-beta.3 now available:
                                        This sounds very good in my ears as I can not get Smart Effector to work properly.
                                        Been planing to do this on my Big Delta.
                                          dc42 administrators @tecno
                                          @tecno said in Software bundle 3.5.0-beta.3 now available:
                                          Which version Smart Effector do you have, and what is the problem you are having?
                                          • tecnoundefined
                                            tecno @dc42
                                            It is 3.0
                                            Not same sensitivity on print area that is approx 450mm in diameter = No reliable mesh.
                                            Also I suspect the mounting of the extruder /adapter may cause issues as well.
                                            dc42undefined weed2allundefined 2 Replies Last reply Reply Quote 0
