    PanelDue Firmware 3.5.0-rc5 released
    PanelDue
    622
    • mfs12undefined
      mfs12
      Hey,
      a new release candidate is available. No bug fixed but new features.
      Release notes and firmware images can be found on github.
      https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.5.0-rc5
      Visit me on github at https://github.com/mfs12/
      Exerqtorundefined 1 Reply Last reply Reply Quote 4
      • mfs12undefined mfs12 referenced this topic
      • Exerqtorundefined
        Exerqtor @mfs12
        @mfs12 I can't see it being mentioned in the release notes. But will this also address the issue with thumbnails not showing up btw? Or is this a RRF issue and not PD?
        • mfs12undefined
          mfs12
          @Exerqtor sorry, but i don't know what you are referring to. Can you share the forum post or github issue?
          I fixed only things @T3P3Tony scheduled.
          Exerqtorundefined 1 Reply Last reply Reply Quote 0
          • CNCModellerundefined
            CNCModeller
            This post is deleted!
            • Exerqtorundefined
              Exerqtor @mfs12
              @mfs12 Ok that cool, I was refering to this.
              EDIT
              I just had the time to test it, and PD still don't display thumbnails for all jobs.
              Sliced two jobs with PrusaSlicer 2.6.0-b2 (400x000, 160x160 thumbnails) and only one displays the thumbnail ( the one named E3D flowtest).
              I uploaded the files here so you can give it a go yourself.
              This is on a Duet 3 Mini running RRF 3.5.0-beta.3+ and a PanelDue 5" v3 with this fw release.
              marvineerundefined 1 Reply Last reply Reply Quote 0
              • marvineerundefined
                marvineer @Exerqtor
                @Exerqtor Just to add my two cents: I also tried your files and neither of the thumbnails are displayed on my PD
                This is on a Duet 3 6HC 1. RRF 3.5.0-beta.3 and a PanelDue 5i with this fw release.
                • mfs12undefined
                  mfs12
                  @Exerqtor said in PanelDue Firmware 3.5.0-rc5 released:
                  Sliced two jobs with PrusaSlicer 2.6.0-b2 and only one displays the thumbnail ( the one named E3D flowtest).
                  just tested the LGX file... the second thumbnail header is not transferred by RRF. So Paneldue can't do anythung about it. perhaps you can regenerate the file.
                  • Exerqtorundefined
                    Exerqtor @mfs12
                    @mfs12 Hmm okey, in regenerate you mean try to slice it again and see if it gets another outcome?
                    Do you have input on what might be causing this @dc42? (if the issue stems from RRF side of things I mean)
                    • mfs12undefined
                      mfs12
                      @Exerqtor i don't think the gcode part is the problem, but something might be wrong with the thumbnail header and payload.
                      • mfs12undefined
                        mfs12
                        Found another issue and fixed it. In some cases the filename is reset and no thumbnails can be requested.
                        But this is unrelated to @Exerqtor problem. I double checked his file and it still persists.
                        https://github.com/Duet3D/PanelDueFirmware/issues/305
                        So there will be another release soon.
                        mfs12 created this issue in Duet3D/PanelDueFirmware
                        closed Fix filename handling for thumbnails #305
                          dc42 administrators @Exerqtor
                          @Exerqtor there were two issues:
                          1. RRF didn't parse enough of the start of the file to find all the thumbnails, when there was a large thumbnail image. In the RRF 3.5 beta releases the amount of data parsed has been increased.
                          2. PanelDue only considered the last thumbnail that was found, so it it was too large then no thumbnail was displayed even if there was an earlier thumbnail file that was small enough (e.g. 160x160 pixels). I have confirmed that this is fixed in PanelDueFirmware 3.5.0-rc5.
                          • Exerqtorundefined
                            Exerqtor @dc42
                            Okey, but unless I missread something it should be working for me now then? Since the first thumbnail is 400x400 and the second (only have two)160x160, and i'm running RRF 3.5b3+ and PD with 3.5rc5?
                              @Exerqtor the message from @mfs12 indicates that the filename for the second thumbnail may be lost, so maybe that is causing the problem for you. I tested with the thumbnails generated in the opposite order.
                              • mfs12undefined
                                mfs12
                                New release available.
                                https://forum.duet3d.com/topic/32532/paneldue-firmware-3-5-0-rc6-released
                                • mfs12undefined mfs12 locked this topic
