    Scanning Z probe support in RRF 3.5
    Beta Firmware
    23
    128
    10.3k
      Here's a teaser: https://www.youtube.com/watch?v=969s3J8EEyM
      matej1006undefined TLASundefined o_lampeundefined 3 Replies Last reply Reply Quote 9
      • Diamondbackundefined
        Diamondback
        Wow, I need that 😄
        • matej1006undefined
          matej1006 @dc42
          @dc42 wow any bed surface?
            dc42 administrators @matej1006
            @matej1006 it's an inductive probe so the usual caveats apply: bed surface must be metallic and uniform, and the sensor is likely to be sensitive to temperature. In fact I am using a flex steel bed with magnets holding it down, but the magnets don't appear to be causing a problem because they are not obvious in the height map. The sensing IC (LDC1612) is the same one that is used in the Beacon.
            appjawsundefined 1 Reply Last reply Reply Quote 0
            • appjawsundefined
              appjaws @dc42
              @dc42 that's fantastic.
              Will we be able to have something similar using your original ir probe?
              appjaws - Core XYUV Duet Ethernet Duex5
              firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
              Ormerod 1-converted to laser engraver, Duet wifi
              OpenSCAD version 2024.03.18
              Simplify3D 5.1.2
              • samlogan87undefined
                samlogan87
                Very cool. Would this still work with a garolite sheet on top of aluminium?
                Custom Core-XY
                1 Reply Last reply Reply Quote -1
                  dc42 administrators @appjaws
                  @appjaws said in Scanning Z probe support in RRF 3.5:
                  Yes, in principle. It will need modified firmware on the IR sensor to reduce the amount of filtering and provide a true analog output.
                  @samlogan87 said in Scanning Z probe support in RRF 3.5:
                  If the garolite sheet is thin enough, then yes. Currently I am using the 20mm diameter coil that came with the breakout board and I have the coil about 8mm above the bed; so plenty of room for a sheet. It will measure the distance to the aluminium, so obviously the garolite sheet must be of uniform thickness and in contact with the aluminium over the whole bed, in order that the top surface of the garolite matches what the sensor is measuring.
                  CNCModellerundefined samlogan87undefined brunofportoundefined 3 Replies Last reply Reply Quote 0
                  • CNCModellerundefined
                    CNCModeller @dc42
                    @dc42 said in Scanning Z probe support in RRF 3.5:
                    So can we use any analogue sensor input, for instance a linear hall effect sensor measuring the location of a ball rolling over the bed surface?
                    Polar Duet3 Mini + 1HCL
                    https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
                    Wanhao D4S: Duet2
                    https://forum.duet3d.com/post/296755
                    K40 Laser, Duet2
                    https://forum.duet3d.com/post/312082
                    Wanhao D5S
                    https://www.youtube.com/CNCModellerUK
                      samlogan87 @dc42
                      @dc42 ok cool. My sheet is 3.5 mm thick and seems pretty flat
                      Custom Core-XY
                      • gringoundefined
                        gringo
                        Looks like the Beacon Probe. Good Job 🤗
                        When will it be available to the public and what is neededÜ
                        • oliofundefined
                          oliof @gringo
                          @gringo new firmware, an LPC1612 sensor, and a (modified for now) toolboard.
                          • TLASundefined
                            TLAS @dc42
                            Wow, kudos. It’s been a while since I’ve been like “that’s awesome” when reading about a firmware update.
                            I have a laser sensor I’m upgrading to that has an analog output and trigger - shouldn’t have a problem in a similar setup I think.
                            Now, this begs the question… when can I use this to audit a print? It would be awesome to scan the print during any travel moves (or a deliberate linear pass) to make sure the print hasn’t pulled off or anything.
                            • o_lampeundefined
                              o_lampe
                              Good bye BLtouch 🙂
                              My favourite sensor would be the IR-probe, too.
                              Maybe I'm seeing problems, but inductive or capacitve sensors are reacting slower than light sensors. Because they store energy and may have a filtering/smoothing behaviour?
                              Plus, the IR sensor is much smaller and lighter.
                              • o_lampeundefined
                                o_lampe @dc42
                                @dc42 Is there a way to store probe points only when the probed height has changed? That would compress the heightmap a lot and we can use a finer probe grid. Or do the probed polygons have to have the same size/shape?
                                • JoergS5undefined
                                  JoergS5
                                  That's impressive speed and I can think of multiple use cases, like non-planar. I'd wish there is a comparable solution for non-metalic objects, to 3D scan the already printed object.
                                  • brunofportoundefined
                                    brunofporto @dc42
                                    @dc42 One can always use a mall single beam LIDAR as those small ones used by drones..... Those are not tailored for small distances but something similar for short distances may exist.
                                    JoergS5undefined 1 Reply Last reply Reply Quote 0
                                    • JoergS5undefined
                                      JoergS5 @brunofporto
                                      @brunofporto maybe it's possible to gather the different types in a future RRF version.
                                        dc42 administrators @o_lampe
                                        @o_lampe said in Scanning Z probe support in RRF 3.5:
                                        The prototype that I put together reacts very quickly, even faster than the IR sensor does because the IR sensor has some filtering. Currently I use the 20mm diameter x 1.5mm thick sense coil supplied with the breakout board, but I intend to try a smaller one.
                                        @brunofporto said in Scanning Z probe support in RRF 3.5:
                                        I look at LIDAR sensors occasionally but so far they don't have sufficient precision or reproducibility to be good enough to use as a Z probe. Even if we accept a precision and reproducibility as large as 10um (so 20um round trip for the laser), that would require measuring the laser round trip time to within an accuracy of about 0.07 picosecond.
                                        CNCModellerundefined brunofportoundefined o_lampeundefined 3 Replies Last reply Reply Quote 1
                                          CNCModeller @dc42
                                          @dc42 could we use the analogue output from a linear hall effect sensor measuring the location of a ball rolling across the bed surface as an input for this?
                                          I assume there is already a need to for some form of analogue input to distance calibration routine?
                                          Many thanks
                                          Barry M
                                          Wanhao D4S: Duet2
                                          K40 Laser, Duet2
                                          Wanhao D5S
                                            brunofporto @dc42
                                            @dc42 plus the issue with different types of surfaces...... Still have my laser filament sensor 😄
                                            I like @CNCModeller idea of the indirect measurement with a ball but then there is the dynamic problem of a ball "jumping" on small defects or residual first layers.
