    Z motor on expansion board not moving
    1.9k
    • wdenkerundefined
      wdenker
      I have a config I have used on other machines and all of my z motors are moving as expected and x and y with the exception of one z motor which I have 4. The one that happens to not be moving is on my expansion board. I also have a filament error that pops up saying no filament every 30 seconds it seems for no odd reason.config (2).g
      www.bd3dcustoms.com | BD3DCUSTOMS Supercube
      wdenkerundefined 1 Reply Last reply Reply Quote 0
        Can you gather a M122 report for the mainboard and the expansion board?
        Can you also send M98 P"config.g" and report any errors?
        So you have your Z axis split between the mainboard and expansion board? Would make more sense to try and keep all of Z on a single board.
        M584 X0.1 Y0.2 Z0.3:0.4:0.5:1.2 E0.1
        You also appear to be trying to map 0.1 driver to both X and E
        • wdenkerundefined
          wdenker @Phaedrux
          @Phaedrux said in Z motor on expansion board not moving:
          M98 P"config.g"
          • wdenkerundefined
            wdenker @wdenker
            @Phaedrux almost looks like it isn't recognizing the expansion board driver. Since it isn't showing any of those drivers.
            M122
            RepRapFirmware for Duet 3 MB6HC version 3.4.6 (2023-07-21 14:11:38) running on Duet 3 MB6HC v1.02 or later (standalone mode)
            Board ID: 08DJM-9P63L-DJ3T8-6J1DA-3SN6J-KV7VA
            Used output buffers: 2 of 40 (25 max)
            Static ram: 153252
            Dynamic ram: 98808 of which 44 recycled
            Never used RAM 98496, free system stack 154 words
            Tasks: NETWORK(ready,79.2%,172) ETHERNET(notifyWait,0.4%,400) HEAT(notifyWait,0.0%,321) Move(notifyWait,0.0%,261) CanReceiv(notifyWait,0.0%,773) CanSender(notifyWait,0.0%,335) CanClock(delaying,0.0%,347) TMC(notifyWait,18.9%,90) MAIN(running,1.5%,925) IDLE(ready,0.0%,30), total 100.0%
            Owned mutexes:
            Last reset 02:43:12 ago, cause: software
            Last software reset at 2023-12-20 12:26, reason: User, GCodes spinning, available RAM 98572, slot 2
            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
            Error status: 0x00
            Step timer max interval 662
            MCU temperature: min 32.4, current 33.8, max 34.0
            Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
            12V rail voltage: min 12.1, current 12.3, max 12.5, under voltage events: 0
            Events: 750 queued, 750 completed
            Driver 0: standstill, SG min 0, mspos 880, reads 364, writes 17 timeouts 0
            Driver 1: standstill, SG min 0, mspos 536, reads 333, writes 48 timeouts 0
            Driver 2: standstill, SG min 0, mspos 200, reads 334, writes 48 timeouts 0
            Driver 3: standstill, SG min 0, mspos 752, reads 350, writes 32 timeouts 0
            Driver 4: standstill, SG min 0, mspos 752, reads 350, writes 32 timeouts 0
            Driver 5: standstill, SG min 0, mspos 752, reads 350, writes 32 timeouts 0
            Date/time: 2023-12-20 15:10:08
            Slowest loop: 8.18ms; fastest: 0.05ms
            === Storage ===
            Free file entries: 10
            SD card 0 detected, interface speed: 25.0MBytes/sec
            SD card longest read time 2.5ms, write time 0.0ms, max retries 0
            DMs created 125, segments created 3, maxWait 133200ms, bed compensation in use: none, comp offset 0.000
            === MainDDARing ===
            Scheduled moves 22, completed 22, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
            === AuxDDARing ===
            Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
            Segments left: 0
            Movement lock held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            SBC is idle in state(s) 0
            Daemon is idle in state(s) 0
            Aux2 is idle in state(s) 0
            Code queue is empty
            === Filament sensors ===
            Extruder 0 sensor: ok
            === CAN ===
            Messages queued 88159, received 117537, lost 0, boc 0
            Longest wait 1ms for reply type 6018, peak Tx sync delay 385, free buffers 50 (min 49), ts 48961/48960/0
            Tx timeouts 0,0,0,0,0,0
            === Network ===
            Slowest loop: 3.23ms; fastest: 0.03ms
            Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
            HTTP sessions: 1 of 8
            = Ethernet =
            State: active
            Error counts: 0 0 0 1 0 0
            Socket states: 5 2 2 2 2 2 0 2
            = WiFi =
            Interface state: disabled
            Module is disabled
            === Multicast handler ===
            Responder is inactive, messages received 0, responses 0
              jay_s_uk @wdenker
              @wdenker send M122 Box where X is the CAN address of the expansion board
              • wdenkerundefined
                wdenker @jay_s_uk
                @jay_s_uk said in Z motor on expansion board not moving:
                M122 Box
                M122 B1
                Diagnostics for board 1:
                Duet EXP3HC rev 1.02 or later firmware version 3.4.6 (2023-07-21 14:15:46)
                Bootloader ID: SAME5x bootloader version 2.4 (2021-12-10)
                All averaging filters OK
                Never used RAM 158600, free system stack 192 words
                Tasks: Move(notifyWait,0.0%,162) HEAT(notifyWait,0.0%,88) CanAsync(notifyWait,0.0%,69) CanRecv(notifyWait,0.0%,82) CanClock(notifyWait,0.0%,71) TMC(notifyWait,7.3%,99) MAIN(running,91.4%,411) IDLE(ready,0.0%,40) AIN(delaying,1.3%,263), total 100.0%
                Last reset 03:19:24 ago, cause: software
                Last software reset data not available
                Driver 0: pos 0, 80.0 steps/mm,standstill, SG min n/a, mspos 8, reads 63513, writes 0 timeouts 0, steps req 0 done 0
                Driver 1: pos 0, 80.0 steps/mm,standstill, SG min n/a, mspos 8, reads 63513, writes 0 timeouts 0, steps req 0 done 0
                Driver 2: pos 0, 160.0 steps/mm,standstill, SG min n/a, mspos 16, reads 63513, writes 0 timeouts 0, steps req 0 done 0
                Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                Peak sync jitter -4/7, peak Rx sync delay 181, resyncs 2/1, no step interrupt scheduled
                VIN voltage: min 24.3, current 24.3, max 24.4
                V12 voltage: min 12.3, current 12.3, max 12.3
                MCU temperature: min 29.8C, current 30.7C, max 31.3C
                Last sensors broadcast 0x00000000 found 0 105 ticks ago, 0 ordering errs, loop time 0
                CAN messages queued 24829, send timeouts 14, received 18460, lost 0, free buffers 37, min 37, error reg 320000
                Last cancelled message type 4519 dest 0
                dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
                  jay_s_uk @wdenker
                  @wdenker I can see the error in your config for M584. For z on the expansion board you should use the address and driver number which in this case would be Z1.0:1.1:1.2 (assuming you're using all 3)
                  • wdenkerundefined
                    wdenker @jay_s_uk
                    @jay_s_uk I don't see any error in my M584 I also just ran another M98 P"config.g"
                    M584 X0.1 Y0.2 Z0.3:0.4:0.5:1.2 E0.0
                    M98 P"config.g"
                    HTTP is enabled on port 80
                    FTP is enabled on port 21
                    TELNET is enabled on port 23
                    Error: Driver 1.2 does not exist
                    Error: Sensor number out of range
                      jay_s_uk @wdenker
                      @wdenker so a couple of things. You need to have something like G4 S2 in your config before any CAN boards are referenced to give them time to connect. So put it before the M584.
                      You have M584 twice in your config.
                      • wdenkerundefined
                        wdenker @jay_s_uk
                        @jay_s_uk G4 S2 is at the very first of the config.g M584 is called twice as we were having some issues and testing a theory. I can remove those no problem. Doesn't explain why it says driver 1.2 doesn't exist even though it is definitely there.
                          jay_s_uk @wdenker
                          @wdenker G4 S2 isn't in the config you posted in the first post. In which case repost your config please ideally as code like your M122 outputs so I don't have to download it to look at it
                          • wdenkerundefined
                            wdenker @jay_s_uk
                            @jay_s_uk
                            ; generated by RepRapFirmware Configuration Tool v3.4.5 on Thu Jun 18 2020 20:04:02 GMT-0600 (Mountain Daylight Time)
                            G4 S2
                            G90                                                  ; send absolute coordinates...
                            M83                                                  ; ...but relative extruder moves
                            M550 P"Fabricator by IOFX"                               ; set printer name
                            M669 K1                                              ; select CoreXY mode
                            M552 P192.168.1.14 S1                                     ; enable network and acquire dynamic address via DHCP
                            M586 P0 S1                                           ; enable HTTP
                            M586 P1 S1                                           ; enable FTP
                            M586 P2 S1                                           ; enable Telnet
                            M584 X0.1 Y0.2 Z0.3:0.4:0.5:1.2 E0.0                 ; set drive mapping
                            M569 P0.0 S1                                         ; physical drive 0.0 goes backwards
                            M569 P0.1 S0                                         ; physical drive 0.1 goes backwards
                            M569 P0.2 S1                                         ; physical drive 0.2 goes backwards
                            M569 P0.3 S1                                         ; physical drive 0.3 goes forwards
                            M569 P0.4 S1                                         ; physical drive 0.3 goes forwards
                            M569 P0.5 S1                                         ; physical drive 0.3 goes forwards
                            M569 P1.0 S1                                         ; physical drive 1.0 goes backwards
                            M569 P1.1 S1                                         ; physical drive 1.1 goes backwards
                            M569 P1.2 S1                                        ; physical drive 1.2 goes backwards
                            M915 P0.1:0.2 F0 S2
                            M350 X16 Y16 Z8 E8 I1                              ; configure microstepping with interpolation
                            M92 X160.00 Y160.00 Z160.00 E420.00                    ; set steps per mm
                            M205 X20.00 Y20.00 Z3.00 E120.00                  ; set maximum instantaneous speed changes (mm/min)
                            M203 X12000.00 Y12000.00 Z300.00 E6000.00              ; set maximum speeds (mm/min)
                            M201 X2500.00 Y2500.00 Z100.00 E10000.00             ; set accelerations (mm/s^2)
                            M906 X1600 Y1600 Z1800 E1600 I30                         ; set motor currents (mA) and motor idle factor in per cent
                            M84 S30                                              ; Set idle timeout
                            M671 X-125:-125:1125:1125 Y100:900:900:100 S7            ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                            M208 X0 Y0 Z0 S1                                     ; set axis minima
                            M208 X1000 Y1000 Z1100 S0                               ; set axis maxima
                            M574 X1 S3 F0 R0                                          ; configure sensorless endstop for low end on X
                            M574 Y1 S3 F0 R0                                          ; configure sensorless endstop for low end on Y
                            M574 X1 Y1 S3                               ; Set endstops controlled by motor load detection
                            M574 Z1 S2                                           ; configure Z-probe endstop for low end on Z
                            M915 X Y S2 R0 F0 	                    ; set X and Y to sensitivity 7, do nothing when stall, unfiltered
                            M950 S0 C"io7.out"                           ; create servo pin 0 for BLTouch
                            M558 P9 C"^io7.in" H5 F120 T6000             ; set Z probe type to bltouch and the dive height + speeds
                            G31 P500 X0 Y0 Z2.65                          ; set Z probe trigger value, offset and trigger height
                            M557 X25:955 Y25:955 S150                             ; define mesh grid
                            M308 S0 P"temp1" Y"thermistor" T100000 B4725          ; configure sensor 0 as thermistor on pin temp1
                            M950 H0 C"out1" T0                                   ; create bed heater output on out1 and map it to sensor 0
                            M307 H0 B1 S1.00                                     ; enable bang-bang mode for the bed heater and set PWM limit
                            M140 H0                                              ; map heated bed to heater 0
                            M143 H0 S120                                         ; set temperature limit for heater 0 to 120C
                            M308 S1 P"temp2" Y"pt1000"                           ; configure sensor 1 as thermistor on pin temp0
                            M950 H1 C"out2+out3" T1                                   ; create nozzle heater output on out0 and map it to sensor 1
                            M307 H1 B0 S1.00                                     ; disable bang-bang mode for heater  and set PWM limit
                            M950 F0 C"out8" Q500                               ; create fan 0 on pin out6 and set its frequency
                            M106 P0 S0 H-1 C"Part Cooling"                                       ; set fan 0 value. Thermostatic control is turned off
                            M950 F1 C"out9" Q500                               ; create fan 0 on pin out6 and set its frequency
                            M106 P1 S0 H-1 C"Part Cooling"                                       ; set fan 0 value. Thermostatic control is turned off
                            M950 F2 C"out7" Q500                                ; create fan 1 on pin out7 and set its frequency
                            M106 P2 S1 H1 T45                                    ; set fan 1 value. Thermostatic control is turned on
                            M950 F5 C"1.out6" Q500                                 ; create fan 1 on pin out7 and set its frequency
                            M106 P5 S1 H100 T15                                    ; set fan 1 value. Thermostatic control is turned on
                            M950 F3 C"1.out7" Q500                                 ; create fan 1 on pin out7 and set its frequency
                            M106 P3 S1 H100 T15                                    ; set fan 1 value. Thermostatic control is turned on
                            M950 F4 C"1.out8" Q500                                 ; create fan 1 on pin out7 and set its frequency
                            M106 P4 S1 H100 T15                                    ; set fan 1 value. Thermostatic control is turned on
                            M563 P0 D0 H1 F0:1                                     ; define tool 0
                            G10 P0 X0 Y0 Z0                                      ; set tool 0 axis offsets
                            G10 P0 R0 S0                                         ; set initial tool 0 active and standby temperatures to 0C
                            M591 D0 P2 C"io1.out" S1 ; filament monitor connected to E0 endstop
                            M911 S22 R23.5 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                            M570 H1 P10 T15 S999
                            M501;
                              jay_s_uk @wdenker
                              @wdenker I guess it doesn't like the Z drivers being spread across the mainboard and CAN board. Best move all Z drivers on to one and move Z or Y onto the 3HC
                              • wdenkerundefined
                                wdenker @jay_s_uk
                                @jay_s_uk any ideas on the filament error I get literally every 30 seconds no matter no filament movement?
                                • wdenkerundefined
                                  wdenker @wdenker
                                  @wdenker can't even get it to report 3 out of 4 times.
                                  12/20/2023, 4:25:15 PM	M591 D0
                                  12/20/2023, 4:25:12 PM	M591 D0
                                  Simple filament sensor on pin (io1.out,serial1.tx), enabled, output high when no filament, filament present: no
                                  12/20/2023, 4:25:00 PM	M591 D0
                                  12/20/2023, 4:24:59 PM	M591 D0
                                  12/20/2023, 4:24:41 PM	M591 D0
                                    jay_s_uk @wdenker
                                    @wdenker it probably needs connecting to a .in rather than a .out
                                    • wdenkerundefined
                                      wdenker @jay_s_uk
                                      @jay_s_uk we've tried both in and out.
                                        jay_s_uk @wdenker
                                        @wdenker can you confirm your wiring, ideally with pictures , and what type of filament sensor it is?
                                        wdenkerundefined 2 Replies Last reply Reply Quote 0
                                        • wdenkerundefined
                                          wdenker @jay_s_uk
                                          @jay_s_uk ah you were right. We had to switch it to 5v vs 3.3 and didn't have it on in after we swapped to the 5v. So all of my issues are resolved at this point.
                                          wdenkerundefined 1 Reply Last reply Reply Quote 1
                                          • wdenkerundefined
                                            wdenker @wdenker
                                            @wdenker Well I got ahead of myself still getting the error just not as often.
