    1HCL / LDO Closed Loop Stepper Motors
    • BenzinLord3undefined
      BenzinLord3
      Hello, i am new to this Forum and currently working on a project for my apprenticeship.
      I am a bit confused with the documentation for the 1HCL expansion boards and the Steppermotors i am using. Can someone tell me how i have to connect the encoder wires to the Board?Datasheet Stepper.PNG Duet 3 Expansion 1HCL detail.PNG
      • oliofundefined
        oliof
        not sure that that is compatible, usually you would add the Duet3D magnetic encoder https://www.duet3d.com/duet3magneticencoder
        sebkritikelundefined 1 Reply Last reply Reply Quote 0
        • sebkritikelundefined
          sebkritikel @oliof
          @oliof Not sure I follow - the 1HCL is compatible with quadrature encoders like whats used by the OP.
          @BenzinLord3 , read through on connecting quadrature encoders to the 1HCL here: https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Expansion_1HCL
          You'll essentially connect the motor/encoders 5V, GND, A+, and B+ to the 1HCL 'Quadrature Input' +5V, GND, A_INPUT, and B_INPUT. The motor leads would then connect to the 'DRIVER 0' connection.
          Large(ish?) IDEX - 6HC, 1HCL
          Stratasys Dimension 1200es to 6HC Conversion
          samlogan87undefined 1 Reply Last reply Reply Quote 1
          • samlogan87undefined
            samlogan87 @sebkritikel
            @BenzinLord3 i run two of those motors with 2 1HCL boards and my encoder cables came pre terminated. See if they can send you some pre terminated ones
            Custom Core-XY
            • PCRundefined
              PCR
              So for this Motor the C Parameter is 1000?
              Best
