    No movement with any command
    MultiAxis Printing
    4.7k
    • zecretonundefined
      zecreton @Phaedrux
      @Phaedrux i can't access dwc
        Remove the SD card from the Duet and use your computer to read the config.g file.
        zecretonundefined 2 Replies Last reply Reply Quote 0
        • zecretonundefined
          zecreton @Phaedrux
          @Phaedrux oops sorry i forgot that
          • zecretonundefined
            zecreton @Phaedrux
            @Phaedrux ; Configuration file for RepRapFirmware on Duet 3 Main Board 6XD
            ; generated by RepRapFirmware Configuration Tool v3.5.3 on Tue Jun 25 2024 21:16:10 GMT-0400 (Eastern Daylight Time)
            ; General
            G90 ; absolute coordinates
            M83 ; relative extruder moves
            M550 P"Duet 3" ; set hostname
            M551 P"Raphaelbreton2008" ; set machine password
            M552 P0.0.0.0 S1 ; configure Ethernet adapter
            M586 P0 S1 ; configure HTTP
            ; Motor Idle Current Reduction
            M906 I30 ; set motor current idle factor
            M84 S30 ; set motor current idle timeout
            ; External Drivers
            M569 P0.0 S1 R0 T5:5:10:0 ; driver 0.0 goes forwards and requires an active-low enable signal (X axis)
            M569 P0.1 S1 R0 T5:5:10:0 ; driver 0.1 goes forwards and requires an active-low enable signal (Y axis)
            M569 P0.2 S1 R0 T5:5:10:0 ; driver 0.2 goes forwards and requires an active-low enable signal (Z axis)
            ; Axes
            M584 X0.0 Y0.1 Z0.2 ; set axis mapping
            M350 X16 Y16 Z16 I0 ; configure microstepping without interpolation
            M92 X80 Y80 Z400 ; configure steps per mm
            M208 X0:1200 Y0:200 Z0:200 ; set minimum and maximum axis limits
            M566 X900 Y900 Z12 ; set maximum instantaneous speed changes (mm/min)
            M203 X6000 Y6000 Z180 ; set maximum speeds (mm/min)
            M201 X500 Y500 Z20 ; set accelerations (mm/s^2)
            ; Kinematics
            M669 K0 ; configure Cartesian kinematics
            M574 X1 P"io0.in" S1 ; configure X axis endstop
            M574 Y1 P"io1.in" S1 ; configure Y axis endstop
            M574 Z1 P"io2.in" S1 ; configure Z axis endstop
              Are you able to connect to the Duet via USB cable and use terminal software like YAT to send commands to it?
              described here: https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet#h-2-connect-your-duet-via-usb
              zecretonundefined 1 Reply Last reply Reply Quote 0
              • zecretonundefined
                zecreton @Phaedrux
                @Phaedrux yes
                  What happens if you follow along with the rest of that "Getting connected" guide?
                  • zecretonundefined
                    zecreton @Phaedrux
                    @Phaedrux i doesn't work bc when i send M552 S1 P0.0.0.0, it answers with just ok, and when i send M552, i can see that it gave 0.0.0.0 as an ip address
                      How do you have the Duet connected to your network?
                      Does the network cable you have going to the Duet work if you try to connect it to a computer?
                      zecretonundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                      • zecretonundefined
                        zecreton @Phaedrux
                        @Phaedrux it is plugged with a ethernet cable in the router
                          Phaedrux Moderator @Phaedrux
                          @Phaedrux said in No movement with any command:
                          zecretonundefined 3 Replies Last reply Reply Quote 0
                          • zecretonundefined
                            zecreton @Phaedrux
                            @Phaedrux yea sorry i didn't have the time to check, do you have the guide?
                            • zecretonundefined
                              zecreton @Phaedrux
                              @Phaedrux nvm i don't know what was the problem but i just powered it on and thew ethernet works fine
                              • zecretonundefined
                                zecreton @Phaedrux
                                @Phaedrux i tested with a multimeter and i can see that in the driver entry, the pul and dir are receiving power, but not the enable, and on the output i don't know what to test
                                  Enable is low by default. Your drivers seem to require a high signal.
                                  https://docs.duet3d.com/en/User_manual/Connecting_hardware/Motors_connecting_external#configuring-the-enable-polarity
                                  See here for changing the enable polarity.
                                  • zecretonundefined
                                    zecreton @Phaedrux
                                    @Phaedrux yea i already changed it to high
                                      Have you tested the enable pin output with your multimeter at the board side?
                                      Does the cable have continuity?
                                      Have you tried a different driver output?
                                      https://docs.duet3d.com/duet_boards/duet_3_mb6xd/duet3_mb_6xd_v1.0_later_dvr_conn.png
                                      • zecretonundefined
                                        zecreton @Phaedrux
                                        @Phaedrux i can see a 5v signal when no command is sent, but it drops to 0v when i send a signal, is that normal?
                                        • zecretonundefined
                                          zecreton @Phaedrux
                                          @Phaedrux yea,i get the same thing on the driver side
                                            Phaedrux Moderator @zecreton
                                            @zecreton said in No movement with any command:
                                            Then it sounds like the enable pin isn't actually inverted. What command did you use to invert it?
