    Unable to start WIFI Module
    226
    • Handiwork7undefined
      Handiwork7
      Following the upgrade tutorial from Ooznest firmware update. The WIFI Module has stopped working.
      Duet 2 Wifi (PCB Version 1.04c)
      Wifi Module ESP 07S
      It claims to be "starting" but never does.
      M115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-06-15 21:45:03
      ok
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
      Board ID: 0JD0M-9P6B2-NJ4S8-6JKF4-3SN6L-9U4AK
      Used output buffers: 1 of 24 (12 max)
      Static ram: 23876
      Dynamic ram: 74172 of which 176 recycled
      Never used RAM 13336, free system stack 185 words
      Tasks: NETWORK(ready,8.0%,517) HEAT(delaying,0.0%,386) Move(notifyWait,0.1%,364) MAIN(running,91.9%,431) IDLE(ready,0.0%,29), total 100.0%
      Owned mutexes: USB(MAIN)
      Last reset 00:07:57 ago, cause: software
      Last software reset at 2025-01-07 13:23, reason: User, GCodes spinning, available RAM 13512, slot 1
      Error status: 0x00
      Step timer max interval 0
      MCU temperature: min 29.7, current 30.2, max 30.4
      Supply voltage: min 0.5, current 0.5, max 0.6, under voltage events: 0, over voltage events: 0, power good: no
      Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/24/0, gc cycles 0
      Driver 0: position 0, ok, SG min/max not available
      Driver 1: position 0, ok, SG min/max not available
      Driver 2: position 0, ok, SG min/max not available
      Driver 3: position 0, ok, SG min/max not available
      Driver 4: position 0, ok, SG min/max not available
      Driver 5: position 0
      Driver 6: position 0
      Driver 7: position 0
      Driver 8: position 0
      Driver 9: position 0
      Driver 10: position 0
      Driver 11: position 0
      Slowest loop: 6.90ms; fastest: 0.13ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.1ms, write time 0.0ms, max retries 0
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is ready with "M122" in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 0.18ms; fastest: 0.00ms
      HTTP sessions: 0 of 8
      - WiFi -
      Network state is starting2
      WiFi module is disabled
      Failed messages: pending 0, notready 0, noresp 1
      ok
      jay_s_ukundefined troydemingundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @Handiwork7
        @Handiwork7 can you try reflashing the wifi firmware?
        M552 S0
        M997 S1
        Handiwork7undefined 1 Reply Last reply Reply Quote 0
          Handiwork7 @jay_s_uk
          @jay_s_uk said in Unable to start WIFI Module:
          M552 S0
          M552 S0
          ok
          M997 S1
          Trying to connect at 230400 baud:  failed
          Trying to connect at 115200 baud:  failed
          Trying to connect at 74880 baud:  failed
          Trying to connect at 9600 baud:  failed
          Error: Installation failed due to comm write error
          ok
          M997 S0
          Shutting down USB interface to update main firmware. Try reconnecting after 30 seconds.
          This did not fix the issue.
          jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
            @Handiwork7 that doesn't look good.
            when and where did you purchase the board?
            one for @Phaedrux or @droftarts
              @jay_s_uk
              This is a Workbee CNC, purchased from a private seller. The unit was working following an upgrade directly from workbee then reboot and all is dead.
                droftarts administrators @Handiwork7
                @Handiwork7 If it was working before, an RRF firmware update should kill the WiFi module, and neither should a WiFi module update.
                Do you have a PanelDue connected? If so, please either switch it to the 'Setup' page or disconnect it while updating the WiFi firmware (the serial communications from the PanelDue can interrupt the update process).
                  Handiwork7 @droftarts
                  @droftarts
                  Sadly, I do not have the PanelDue.
                    @Handiwork7 Try this:
                    • Turn off the Duet, remove the SD card.
                    • Turn on the Duet and connect via USB. This will mean the WiFi never gets initialised.
                    • Put the SD card back in, and send M21 to mount the SD card.
                    • Then try either:
                      • sending M997 S1, or
                      • start again, but send M552 S0 to turn the WiFi on in idle mode, then send M997 S1
                    This was probably caused by a failed WiFi firmware flash during the main firmware update, so the WiFi firmware is only partially there. Possibly the WiFi firmware flash took longer than expected, and the Duet reset before it had finished.
                    When you turn the Duet on, I think the WiFi module gets hung up trying to enable networking with the M552 S1 command in config.g, so removing the SD card means this doesn't happen. Hopefully then the Duet can flash the WiFi module, as it should be off, or idle.
                      @droftarts Thank you!
                      Earlier today I replaced the WIFI Module with the Ethernet module from a faulty board I had years ago (drivers died, I kept the board for spares). (Save make/version etc).
                      The Ethernet module was recognized, I can set the IP etc. Sadly, It's still showing "Link Down" with the Ethernet cable connected.
                      I can only assume at this point one of the traces are damaged on the PCB and the signal is not making it back to the atmel chip.
                      I do have a full re-flow station and microscope. Just not sure if its worth the dive vs go just buy a new one.
                      • T3P3Tonyundefined
                        T3P3Tony administrators @Handiwork7
                        @Handiwork7
                        The schematic for your Duet 2 board is here so you could probe the connections back to the MCU and see if there are any issues there.
                        https://github.com/Duet3D/Duet-2-Hardware/blob/371c656c226417c3ee1e4c78887d536f61ac9edc/Duet2/Duet2v1.04/Duet2_1.04c_Schematic.pdf
                        www.duet3d.com
                        • troydemingundefined
                          troydeming @Handiwork7
                          Did you ever get it working?
                          • T3P3Tonyundefined
                            T3P3Tony administrators @troydeming
                            @troydeming This thread is pretty specific about replacing a WIFI module with an ethernet one. We can discuss your setup in the initial thread you started here:
                            https://forum.duet3d.com/topic/37524/help-with-new-setup-please
                            www.duet3d.com
