New beta firmware 2.01beta1/1.21.2beta1 available
I have just released this at https://github.com/dc42/RepRapFirmware/releases/tag/2.01beta1. This fixes a bunch of mostly minor bugs in the 2.0 release:
- When using a mixing extruder, the feed rate for extruder-only moves was incorrect
- If additional axes were not created in the order UVWABC then incorrect homing files might be run (thanks chrishamm)
- On the Duet Maestro, the 7th stepper step/dir pin numbers were swapped
- If you paused a print during a G2/G3 arc move, on resuming it the arc centre was at the wrong place. This release defers the pause until the arc move is completed.
- If a command that interrogated the network (e.g. M122 on the Duet WiFi) was sent from USB, PanelDue or another non-network channel, the network subsystem could be accessed by multiple tasks concurrently, causing network disconnections or other errors
- When using a bltouch, between probe points the pin retracted, deployed and retracted again
- M206 with no parameters didn't report the current axis offsets
- During heating, the firmware returned M408 S0 responses to the PanelDue port even if the last request was M408 S2
- Fixed VBUS detection (thanks chrishamm)
- If the resume threshold in the M911 command was set higher than the supply voltage then the save-on-power-off mechanism never got primed. It will now prime at the auto-save threshold plus 0.5V or the resume threshold, whichever is lower.
- Fixed "2dtstc2diva=u" in debug printout
- Where a G- or M-code command parameter was supposed to accept unsigned values only, if a negative value was supplied then it was accepted and converted to a large unsigned value
New features and changed behaviour:
- If the firmware gets stuck in a spin loop, the RTOS builds now discard LR and 16 stack dwords in order to get more useful information from the stack trace
- Increased M999 delay to 1 second
- The report generated by M122 now includes a list of mutexes and their owners
- Added SW_ENC pin on CONN_SD to available GPIO ports (thanks chrishamm)
Please note, although I have done test prints with this release, I have not had time to test all the changes. So if you were affected by one of the issues that I have attempted to fix, please report whether the fix has worked for you.
@dc42 said in New beta firmware 2.01beta1/1.21.2beta1 available:
I'm just imagining the situation while machining some larger part and looking at the spindle going to hit some material holding fixture during a long arc move! This shouldn't happen very often, but it may be a lot more expensive when compared to the original bug (BTW I saw it happening once and couldn't tell what hit me! Luckily I was machining some POM and the end mill survived the wrong re-entry point!).
In that situation, I think emergency stop would be more appropriate.
Should this change avoid this mistake?
Appears every time trigger "T0"
(M581 E0 S0 T0 C0
Possibly.
@dc42 were you able to reproduce/fix the issue I had with the Duex5 not being recognized after a reset?
https://forum.duet3d.com/topic/5713/duet2-with-2-0-rtos-looses-duex5-on-reset -
@gtj0 said in New beta firmware 2.01beta1/1.21.2beta1 available:
https://forum.duet3d.com/topic/5713/duet2-with-2-0-rtos-looses-duex5-on-resetI didn't have time to try that, because I needed to get the beta released before I go on vacation. It's on my list to try.
Oddly enough, it seems to be working now. Anyway have a good holiday!
Updated and started printing last night with this new version. No issues at all so far.
I spoke too soon, about the Duex5 not your holiday :). It seems I'm back to losing it after a reset.
The Web Interface of this version is junk.
Why publish an untested Version as beta? This is early alpha. -
@autsch, please explain what problems you are having with the web interface. You can revert to Duet Web Control 1.21 or 1.21.1 if necessary.
@dc42, Java script error, if you save settings in the web interface.
I use windows 10, error was in Firefox developer.
Z moved in -Y. -
@dc42, if you want, I could install it this night and write down the errors.
John had the same problem with a Delta in Z axis
https://forum.duet3d.com/topic/5842/weird-z-behavior-with-first-attempt-with-rtos-firmware-on-delta/2
When I tried to open the js.gz, I got an error from Microsoft Scripting host:
just installed the beta 2 today and the Script errors are gone if i want to add a new temp button
hi! i did not find a link to b2 and now using b1 .
in webUI it showsError: Can't open 0:/sys/oem.json to read, error code 4
There is no b2 - @Barracuda72 is this a typo?
@c310 the oem.json error is normal - only OEM vendors ship this file. "Normal" users can ignore the error.
There is a b2 of DWC 1.21.2, it's in chrishamm's github repo.
As David stated...no typo
I am getting an error that I know I am making happen. I currently have V2.0 and I tried to upgrade to 2.01. I downloaded "Duet2CombinedFirmware.bin, loaded it to my DuetWifi, try to update, and I get an error,
'Error: M997: In-application programming binary "iap4e.bin not found'I know this has to be something I am missing, but I dont have any idea where to start looking to fix the problem. Hopefully someone can point me in the direction I need to go to fix this problem.
Thanks
TC -
Maybe try updating the IAP files again?
@iamturbo1978, download iap4e.bin from https://github.com/dc42/RepRapFirmware/releases/tag/2.0 and upload it through the Settings General page of DWC.
@dc42, Wonderful. Thank you so much for the help.
