    RC Low-Pass Filter for Blower Fan
    57
    9.3k
    • wilrikerundefined
      wilriker @JoergS5
      @joergs5 OK, thanks for confirming. As I already cut my wires to the fan I think I can quite easily insert the multimeter in this circuit using some screw terminals... I need to put ferrules on the wire ends anyway, so that's up next.
      Then again it would be really strange to have the H type when buying the M type that is also labelled as being the M type (including the amperage). I would expect this on a super-cheapo Chinese fan but not from a brand. But let's wait and see. 😀
      Manuel
      My Tool Collection
      JoergS5undefined 1 Reply Last reply Reply Quote 0
      • JoergS5undefined
        JoergS5 @wilriker
        @wilriker maybe labeled by someone who needs better glasses, M and H are similar 😉
        I thought it may be the H type because your 5500 measuring fits exactly to this higher model.
        • wilrikerundefined
          wilriker @JoergS5
          @joergs5 I know it would fit perfectly. Also about 6500 RPM @13.6V would match that quite well.
          Manuel
          My Tool Collection
          • SnowCrashundefined
            SnowCrash
            @phaedrux said in RC Low-Pass Filter for Blower Fan:
            https://www.digikey.ca/short/jrmcdf
            I was reading through this thread and was hoping someone could clarify the value of the inductor in the diagram above? I'm familiar with 1uH (micro-Henry) and 1nH (nano-Henry), but what does 1mH stand for? mili-Henry (1000uH)? for such a small amount of current?
            • wilrikerundefined
              wilriker @SnowCrash
              @snowcrash said in RC Low-Pass Filter for Blower Fan:
              Yes, mH is milli-Henry.
              Manuel
              My Tool Collection
              SnowCrashundefined 1 Reply Last reply Reply Quote 0
                SnowCrash @wilriker
                Thanks @wilriker!
                But that's HUGE just for a fan that draws maybe 0.15mA, no? (ok, the fan will draw more current at startup but still...). Is there some calculation behind this value?
                wilrikerundefined dc42undefined 2 Replies Last reply Reply Quote 0
                • wilrikerundefined
                  wilriker @SnowCrash
                  @snowcrash Actually I have no clue about all this stuff. I just took those numbers for granted (even though I would also like to learn about where they come from).
                  But just as an update: I dropped all this anyway since connecting the signal line showed that the fan actually turns at the speed I set it to, it just feels/sounds a lot lower - but then my ears and fingers are probably the worst way of measuring fan speed in the first place. 😂
                  Manuel
                  My Tool Collection
                    SnowCrash @wilriker
                    @wilriker happy you got your fan working quietly (though perhaps not in the way you were hoping to achieve this 🙂 )
                    Anyway, at another discussion, @dc42 insisted that an inductor-capacitor circuit is necessary for preventing a non-PWM fan from potentially being damaged while being run with a high frequency PWM signal, and just I started looking into the idea of making a little add-on module that would provide this circuitry for all 3 PWM outputs on the Duet (plus the ability to choose between 12V and 24V for each fan which is the main reason for the module).
                    So hopefully @dc42 or someone else familiar with this subject would chime in and clarify this point about the inductor's value.
                      dc42 administrators @SnowCrash
                      Thanks @wilriker!
                      Yes 1mH. The fan draws 0.15A (150mA), not 0.15mA.
                        SnowCrash @dc42
                        Thanks for the confirmation, @dc42! But what's the calculation behind it?
                          The calculation is L = V * t/I where V is the voltage across the inductor, I is the maximum ripple current current you want to allow, and t is the time involved. Or, turning it around, I = V * t/L. If we take the case of a 24V fan running at 50% PWM and 50kHz PWM frequency, then for L=1mH and 12V across the fan, we have I = 12V * 10us/1mh = 120mA. This is around the same as the fan current, so a capacitor is needed after the inductor to reduce the ripple current in the fan. For the capacitor, C=I*t/V where V is the allowed peak ripple voltage. So V=I * t/C and 1uF will give 120mA * 10us/1uF = 1.2V. This is 10% of the 12V average voltage at 50% PWM, so it is likely to be low enough.
                          • fmaundefined
                            fma
                            I recently added a Berd air pump for cooling the part, and I noticed that increasing the PWM frequency increased the efficiency: for the same PWM ratio, the higher was the frequency, the higher was the rotation speed. I went up to 100kHz.
                            Is it normal? Could such low -pass filter improve things?
                            Frédéric
                              That doesn't necessarily mean that the efficiency was increased. The increased rotation speed may have been caused by a EMI suppression capacitor within the motor having a smoothing effect.
                              • fmaundefined
                                fma
                                Yes, efficiency was not the appropriate word (I didn't measure the current).
                                What about the low-pass filter? Could it improve things?
                                BTW, I also noticed that adding the flyback diode increases the speed for the same PWM ratio.
                                Frédéric
                                  if you are driving the brushed DC motor from a heater output, then a flyback diode is essential. Without it, energy from the back EMF of the motor inductance is dissipated in the mosfet by avalanche breakdown, leading to reduced efficiency and maybe eventually a blown mosfet.
                                  • fmaundefined
                                    fma
                                    I was aware of potentially blowing the FET, but I didn't know it changes the efficiency. Thanks for the explanation!
                                    Frédéric
                                    • vfjrundefined
                                      vfjr
                                      I know this is a very old topic, but it is the first one that comes up on Google when searching for fixing fans that do not work with PWM, so I hope to be able to share a solution with people who need help.
                                      I found a good and cheap solution and I made a new topic about it here.
