    Piezo20 probe and piezo kit now available
    423
    98.9k
    • Moriquendiundefined
      Moriquendi
      The other two pins next to the piezo input are designed for a remote LED, I found it useful so I included it. The three pins at the other end of the board are meant to be the connection to the controller, V+, Signal and GND. On my Smoothieboard endstop headers are these three pins so thats what was convenient for me. However the only difference is that the LED output has a 1k series resistor on board. The resistor in series with the piezo element doesn't appear to be critical.
      Moriquendi
      • Sakeyundefined
        Sakey
        Set mine up today ( thanks Moriquendi for the board) but having a problem with it outputting a signal to the duet I think. The led triggers fine by the looks of it when I tap the Nozzle ( on board and the external ) but i'm not getting a trigger. Is this something to do with the way i set up the Potentiometers or Duet?
          Moriquendi
          If the LED is flashing you should have a signal going to the duet. Check what kind of signal the Duet is expecting, active low or active high. I'm afraid I have no experience with the Duet so I can't help you with that but I'm sure someone else on here can.
          One other thing to mention is that a trigger event is very brief, on the order of miliseconds, you won't be able to check the output of the board with a g-code to report z-probe state. Have you tried asking for a z-probe and then tapping the sensor to see if the Duet registers the trigger?
          Moriquendi
          PS. I've just had a look at the Duet documentation and I think people may be configuring it incorrectly for this type of z-probe. The output of the piezo sensor board is digital, not analogue. It appears from DjDemonDs config above that he has configured the Duet to expect an analog signal. Does this make a difference? I don't know but it's worth a shot.
          • DjDemonDundefined
            DjDemonD
            Have been probing away and changing things for the last few hours now.
            Setting it as digital M558 P5 for me anyway is not working. If I leave it set to analogue M558 P1 I1, inverted output and set the piezo board by turning VR2 until the LED is just on with sensitivity fairly high (VR1), but use a trigger value of 600 it works. Its also worth setting a probing speed of 500mm/min M558 F500 so that the nozzle gives the bed a fairly sharp tap rather than descends very slowly which sometimes doesn't trigger.
            My probe settings currently are
            M558 P1 I1 F500 X0 Y0 Z0 ;analogue piezo sensor output falls on contact, probing speed, not used to home axes
            G31 X0 Y0 Z0 P600 ;sensor is nozzle and trigger value.
            You can monitor the "analogue" output on web interface. Setup as I have mine the value shows approx 215 when head is stationary, during normal travel moves it goes up to 400-500, on a sharp tap with the bed it goes above 600 often to 1000 (max - essentially digital ON). At this setting on the piezo board I can get reliable and sensitive triggers.
            Of course having faster probing speed is risky its harder to pull the power in case of a head crash there is less time to do so, suggest setting your stepper motor current to as low as you can go whilst still moving, so that these are less severe if they happen. However faster probing speed will show false triggers requiring slightly less sensitivity (VR1), so its useful in that respect.
            www.precisionpiezo.co.uk
            • DjDemonDundefined
              DjDemonD
              My bed.g if it helps:
              [[language]]
              ; Auto calibration routine for delta printers
              M906 X500 Y500 Z500 E800 I60		; Set low motor currents (mA) and increase idle current to 60%
              M561					; clear any bed transform, otherwise homing may be at the wrong height
              G28					; home the printer
              G28					;home again in case of endstop problem
              ;slow down movement to delineate bed touch from travel moves
              M201 X250 Y250 Z250 E1000		; Accelerations (mm/s^2)
              M203 X15000 Y15000 Z15000 E3600		; Maximum speeds (mm/min)
              M566 X100 Y100 Z100 E1200		; Maximum instant speed changes mm/minute
              G30 P0 X0.00 Y120.00 Z-99999 H0
              G30 P1 X75.20 Y89.63 Z-99999 H0
              G30 P2 X109.80 Y19.36 Z-99999 H0
              G30 P3 X95.08 Y-54.89 Z-99999 H0
              G30 P4 X38.37 Y-105.43 Z-99999 H0
              G30 P5 X-40.44 Y-111.11 Z-99999 H0
              G30 P6 X-103.92 Y-60.00 Z-99999 H0
              G30 P7 X-118.18 Y20.84 Z-99999 H0
              G30 P8 X-77.13 Y91.93 Z-99999 H0
              G30 P9 X0.00 Y60.00 Z-99999 H0
              G30 P10 X46.66 Y26.94 Z-99999 H0
              G30 P11 X43.81 Y-25.29 Z-99999 H0
              G30 P12 X0.00 Y-54.74 Z-99999 H0
              G30 P13 X-51.96 Y-30.00 Z-99999 H0
              G30 P14 X-51.96 Y30.00 Z-99999 H0
              G30 P15 X0 Y0 Z-99999 S6
              ;restore speed settings to normal printing speeds
              M201 X3000 Y3000 Z3000 E1000		; Accelerations (mm/s^2)
              M566 X1200 Y1200 Z1200 E1200		; Maximum instant speed changes mm/minute
              G29 S1					;load grid levelling mesh
              M376 H10				;taper off compensation after 10mm
              M906 X1100 Y1100 Z1100 E800 I60		; Set normal motor currents (mA) and increase idle current to 60%
              G1 X0 Y0 Z75 F3000			; get the head out of the way of the bed
              M500					;save calibration to config_override.g
              Remove the G29 if you aren't using grid levelling, and the M500 unless you want auto-save of results to config_override.g and obviously replace the G30 points with your preferred probing locations and number of factors.
              • Sakeyundefined
                Sakey
                Its weird. Both P1 and P5 do more a less the same thing for me but get slightly less crashed heads with P5. When I send the command to probe and it tap the nozzle it will register the tap .
                It's like seems to be a delay between the trigger of the sensor and duet reading the probe point before it pushes though the bed. I don't think its a sensitivity problem because sometimes it will trigger from just the movement of the effector.
                • DjDemonDundefined
                  DjDemonD
                  Sounds like you've got everything there, its just a case of finding the sweet spot where it triggers well. I might do a few videos later showing how I have it setup. You might have the clamp/piezo assembly tightened too much, try loosening it off a tiny bit. There is a zone where you find the optimum between a tight assembly/less sensitivity/firm nozzle, and a loose assembly/high sensitivity/wobbly nozzle. I say this as there is no delay as I have it setup the lightest touch of the nozzle gives an above threshold trigger.
                  • Boyan Silyavskiundefined
                    Boyan Silyavski
                    A question. Why all this trouble and not use a simple conductive touch plate with an known thickness? Same like most DIY CNCs use? Hot end could be wired constantly , led could be implemented for visual check if working, prior to test. Costs absolutely nothing. Plate could be moved sequentially manually to predefined places on heat bed. Is this possible with the Duet board?
                      Moriquendi
                      Because the end of a hot end nozzle is not a good contact, it's frequently coated in a layer of gunky/charred plastic.
                      Moriquendi
                      • T3P3Tonyundefined
                        T3P3Tony administrators
                        Boytan
                        It would be possible as it could be setup as a switch, and the firmware will accept any sort of trigger as an endstop. (The signal needs to be within the 3.3V range however that is manageable).
                        One issue is as Moriquendi described - inconsistant conductivity due to plastic buildup on the nozzle. The other issue is that many(most) bed surfaces are non conductive to you have to have the manual intervention of applying a conductive sheet to the bed.
                        www.duet3d.com
                        • DjDemonDundefined
                          DjDemonD
                          Yes I'd love to use a electrified nozzle and at one point I used to print onto aluminium and considered it. Plastic on the nozzle isn't really an issue if you probe hot. But now I print onto printbite which is super convenient and permanent and about as conductive as ceramic. I'd say most people are using glass or polymer surfaces of some sort.
                          • DjDemonDundefined
                            DjDemonD
                            Updated the tuning guide (long post) above and included a video of how I have it setup which might make it easier to see what I'm on about. https://www.youtube.com/watch?v=F3vi6BOi6sA
                            • T3P3Tonyundefined
                              Awesome! I linked your post and the video from the Tutorials page:
                              https://duet3d.com/wiki/Tutorials#Experimental_Features
                              Although at the rate this is progressing it wont be experimental for much longer.
                              www.duet3d.com
                              • DjDemonDundefined
                                DjDemonD
                                Next iteration is to make the nozzle wobble disappear almost completely, I had in mind attaching the upper part of the piezo sensor module to the lower with small smooth rods (or delrin rods?) which would slide into the lower clamp part, and if metal, could be greased. This would result in a very firm nozzle constrained laterally but free to move upwards by a small amount to flex the piezo disc.
                                • Dougal1957undefined
                                  Dougal1957
                                  DJ
                                  PTFE rod is quite cheap and would probably be a better choice than Delrin or steel (Has self Lubricating properties IIRC).
                                  a 500mm length of say 10mm Diam is about £2.50 from one of my local suppliers it is available in 4,5,6,8,10 mm diam plus a lot bigger as well.
                                  https://www.directplastics.co.uk/ptfe-rod
                                  Look forward to seeing your design for it lol
                                  Doug
                                  • DjDemonDundefined
                                    DjDemonD
                                    Well here's a preview:
                                    I've modded Lykles version as he did his in proper CAD with all the holes geometrically correct etc..
                                    Its pretty simple just 4 rods (in the only places they can go without redesigning the clamp (which is a bit beyond my cad skills TBH). Bonded at the top piece or interference fit, and then initially adapted to the clamp by manually filing the holes in the clamp lightly to achieve a fit that allows vertical movement but not lateral movement. Either that or drill the top holes to 4mm and the lower ones to 4.2mm or something like that. I'd grease them if it were steel but maybe won't need to with PTFE. My concern is maybe the PTFE will flex a little and reduce the stiffening effect I'm hoping for, which is why I was thinking delrin if not steel, which is also self-lubricating (although much more expensive and harder to get hold of).
                                    What do you think? Very much open to ideas for a better way to do this.
                                    • Zesty_Lykleundefined
                                      Zesty_Lykle
                                      Hmm, would the wobble be decreased if we used a bigger peizo sensor?
                                      In other words, have a wider base where the hot end is pressed into.
                                      Related, how big is the wobble and how does it show up in your printing quality?
                                      Lykle
                                      Design, make and enjoy life
                                      Co Creator of the Zesty Nimble
                                        Dougal1957
                                        Problem with Delrin is getting anything smaller than 10 mm Diam.
                                        a 500mm long piece of 10mm delrin is about £1.25 so is about half the price of PTFE but I can pop in and get it of the shelf so to speak
                                        Would it help if I went and got a length of each and sent you say 100mm of each to try.
                                        I would be tempted to drill the top at 10 but the bottom at 10.1.
                                        Doug
                                        • DjDemonDundefined
                                          DjDemonD
                                          Doug. Thanks for the offer but 10mm is way too big for what I've got in mind. The whole assembly shown above is only 40mm in diameter and its convenient that it is, it fits inside an effector quite easily. It could be a little bigger but not to accommodate 10mm dia. rods. I'd also be concerned the friction would be quite high with that much surface area to try to slide on. I take your point about the drilling this is why I'd hand file it its easier to control the fit.
                                          Lykle no the wobble would be less with a smaller piezo sensor, but then the sensor would flex less and be less sensitive. This might work with an FSR if there is one with a 4-5mm hole in the middle?
                                          My first attempt at this version is going to be steel as Im sure I've got some thin rod lying around, doesn't need to be very stiff as they are only 15-20mm long.
                                            Dougal1957
                                            OK So would you like me to get some 4mm PTFE rod it could be stiffened with some bigger stuff round it maybe
                                            Doug
                                            Tell you what I need to print the parts so if you could send me the files (If you haven't put them on TV Yet) I will get some 4mm PTFE Rod and give it a try?
