    Problems with the E3D-V6 Temperature
    1.6k
    • lui2004undefined
      lui2004
      Hi
      i have installed today the E3D-V6 all wired correct.
      now if i set in active the temperature of 195 Celsius the Temperature goes up to 220 celsius
      i got this error:
      Error: Heating fault on heater 1,temperature excursion exceeded 15.0 Calsius
      this is my config.g:
      ; generated by RepRapFirmware Configuration Tool on Sat Dec 15 2018 20:53:32 GMT+0100 (Mitteleuropäische Normalzeit)
      M550 PAM8 ; Set machine name
      M552 S1 ; Enable network
      M587 S"WLAN-363335" P"luigello20101984" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M92 X100 Y100 Z400 E100 ; Set steps per mm
      M203 X24000 Y24000 Z480 E3000 ; Set maximum speeds (mm/min)
      M201 X2000 Y2000 Z100 E10000 ; Set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X-34 Y-1,5 Z0 S1 ; Set axis minima
      M208 X220 Y216 Z220 S0 ; Set axis maxima
      M574 X1 Y1 Z1 S0 ; Set active low endstops
      M558 P5 H5 F0 T6000 ; Set Z probe type to switch and the dive height + speeds
      M557 X5:215 Y20:195 S42:35 ; Define mesh grid
      M305 P0 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 0
      M305 P1 B4725 C7.060000e-8 ; Set thermistor + ADC parameters for heater 1
      M143 H1 S28 0 ; Set temperature limit for heater 1 to 280C
      M106 P0 S0 I0 F100 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P2 S0.75 I0 F500 H0 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 S"Hotend" D0 H1 ; Define tool 0
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      ;M671 X3:2017:217 Y108:3:2013 P0.5
      M404 N1.75 D0.4
      M376 H10
      M207 S3.5 F1920 Z0.0
      ;Miscellanous
      T0
      please i need some help since 3 hours and no results
      thanks a lot
      sigxcpuundefined 1 Reply Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt
        Did you run the heater tuning procedure (see M303) ?
        • lui2004undefined
          lui2004
          @fcwilt said in Problems with the E3D-V6 Temperature:
          yes but my english is not the best to understand the procedure
          can you help me a bit ?
          • tjschweizerundefined
            tjschweizer
            In the GCODE terminal type:
            "M303 H1 S200"
            Then when finished type
            "M500"
            • lui2004undefined
              lui2004
              @tjschweizer said in Problems with the E3D-V6 Temperature:
              M303 H1 S200
              i try
              • lui2004undefined
                lui2004
                i got this
                23:13:25Auto tune phase 3, peak temperature was 221.4
                23:13:19Auto tune phase 2, heater off
                23:10:11Auto tune phase 1, heater on
                23:10:05M303 H1 P0.5 S240
                Auto tuning heater 1 using target temperature 240.0°C and PWM 0.50 - do not leave printer unattended
                • sigxcpuundefined
                  sigxcpu @lui2004
                  @lui2004 said in Problems with the E3D-V6 Temperature:
                  You have multiple mistakes in your config file:
                  • lui2004undefined
                    lui2004
                    @sigxcpu said in Problems with the E3D-V6 Temperature:
                    whats wrong here ?
                      Phaedrux Moderator @lui2004
                      @lui2004 Possibly the comma instead of a period. , versus .
                      • lui2004undefined
                        lui2004
                        Now i See my mistake.
                        And for E3d-v6 What i can do to solve my problem any idea?
                          If it really is an authentic E3D hotend and thermistor I think your M305 settings are off.
                          You have M305 P1 B4725 C7.060000e-8
                          But should have M305 P1 T100000 B4388 C7.060000e-8 R4700 Or at least that's what the configurator gives for the semitek thermistor E3D uses.
                          • lui2004undefined
                            lui2004
                            @phaedrux said in Problems with the E3D-V6 Temperature:
                            ok i have change it
                            send this gcode for autotuning:
                            M303 H1 S240
                            result:
                            Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 472C.
                            Auto tune heater 1 completed in 223 sec
                            Use M307 H1 to see the result, or M500 to save the result in config-override.g
                            Gcode M307 H1 Result is:
                            M307 H1
                            Heater 1 model: gain 447.7, time constant 133.2, dead time 13.0, max PWM 1.00, calibration voltage 12.3, mode PID, inverted no, frequency default
                            Computed PID parameters for setpoint change: P4.1, I0.098, D37.2
                            Computed PID parameters for load change: P4.1
                            • peirofundefined
                              peirof
                              Have you double check voltage of termopar/PSU printer?
                                That looks like a normal warning. Is the temp stable now or does it still fault?
                                • lui2004undefined
                                  lui2004
                                  till 5 minutes 235C stable
                                  i will make a test print
                                  • lui2004undefined
                                    lui2004
                                    seems to be ok still print the calibration cube
                                    other thin my print is not in the center of my bed
                                      @lui2004 https://duet3d.dozuki.com/Wiki/Centering_the_bed_or_setting_the_bed_origin
                                      • sigxcpuundefined
                                        sigxcpu @lui2004
                                        I assume you fixed this one too?
                                        • lui2004undefined
                                          lui2004
                                          Yes i fix it
