big box madness
@ryan-lock thanks for the advice. I have tried moving around the x axis motor to other ports, with and without the same wire. And using that working X wire on other motors. Still the same errors unfortunately. Even got some new wires and the same issue
Let's start with getting the X motor working when it is connected to the Y motor output. Please add the following command to the start of config.g:
M584 X1 Y0
That will swap the X and Y motor outputs over. Also connect the X motor to the Y motor output, and vice versa. Then try moving X and Y again. If the X motor (connected to the Y motor output) moves correctly when you command X movement, but the Y motor (connected to the X motor output) doesn't, then it is a configuration problem. If the X motor stops working but the Y motor starts working, then it is a problem with the Y driver.
@dc42 said in big box madness:
M584 X1 Y0
right i have tried what you have advised. problem still persists with the Y driver, driving the x axis.
Thanks. Please ask your supplier to replace your Duet.
@dc42 so new board, new problems.
I cant seem to get the end stops to now work.
motors are moving fine but the end stops aren't doing their bit.have a 2 wire endstop so ive wired them on both ends of the endstop. (light starts off as red and then when the stops are engaged turns off) . have tried both X1 Y1 and X0 Y0 and the current code also on my endstop in config.g
M574 X2 Y2 S1 ; Set active high endstops
also i have an E3d hot end and am a bit confused about using the pt1000 amps? ive connected them currently straight to the duet but temps are like 2000c.
@magdi right i have made stuff do things.
problem now is when i press to 'home y' it homes y a little and also homes x.
so both axis move not just one. But then they also dont move all of the way to homing. hopefully that makes sense. -
@magdi said in big box madness:
do you mean pt100?
did you configure the m305 correctly?
@veti yes pt100 i think.
heres what i have atm but in all honesty im not sure what to configure here.M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
M305 P2 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 2
M143 H2 S280 ; Set temperature limit for heater 2 to 280C -
none of those are for pt100 or pt1000 thermistors
check the configurator for the sensor channel to set it correctly
https://configurator.reprapfirmware.org/Heaters -
@veti cheers for the help, i have changed to the pt100, but still have the same issue. where should i then pin the two wires into the board,
to the external RTD interface board
https://duet3d.dozuki.com/Wiki/Connecting_PT100_temperature_sensors
@veti i have tried it and still cant connect the bloody thing. so ive found the daugherboard connection point on the duet. that has 10 pins. i only have 4 wires (dual extruders' with two sets of black and red wires connected together) I just dont know where to put the bloody things. the images on the page you supplied are not very helpful and i cant crack the schematic. i think im just being stupid.
@magdi Do you have a PT100 daughterboard?
@phaedrux i have a pt100 board but it came with my e3d v6 not the same as the duet one.
@magdi So you got this? https://e3d-online.com/pt100-amplifier-board
@phaedrux yep two of those badboys,
Alright, sorry to say, but I don't think that will work. You'll need the daughterboard.
https://e3d-online.dozuki.com/Wiki/E3D_PT100_Amplifier_Documentation
https://e3d-online.dozuki.com/Wiki/Temperature_Sensor_Documentation#Section_PT100 -
@phaedrux right is there not way just just bypass the pt100 and just connect the thermistor to the duet board?
Well if the sensor is a PT100 sensor, then no, it needs the daughterboard to interface with the duet. If you have a seperate regular thermistor, then yes, it could be connected to the thermistor input.
@phaedrux i have a separate thermistor sorry i should of said that, the thermistor fist into the pt100 but i dont understand why i cant just put it in the motherboard. temps are still wrong when i do that
