    Latching magnetic tool changer
    My Duet controlled machine
    11
    31
    5.3k
    • pawPrinterundefined
      pawPrinter @fma
      @fma Thanks. Yes, your idea would make a lot of sense. I might wait to see what you do, before I re-design mine.
      • fmaundefined
        fma
        Don't hold your breath, as I need to re-design all my CoreXY gantry to be able to implement a tool changer 😉
        Frédéric
        pawPrinterundefined 1 Reply Last reply Reply Quote 0
          pawPrinter @fma
          @fma Ha ha - Yeah, I know how it is!!
          • Red Sand Robotundefined
            Red Sand Robot
            @pawPrinter Have you seen any issues with the magnets causing interference with the stepper motor driving the Bondtech extruder? I want to make a version of a magnetic parking extruder system on a Prusa style machine, but am concerned about the electromagnet interfering with the operation of the stepper motor.
            almost an engineer
            • fmaundefined
              fma
              A magnet does not generate electromagnetic interference, as it is a pure static magnetic field.
              It can influence a stepper motor in 2 ways:
              • if the stepper and the magnet move relatively of each other (Foucault currents, Faraday effect...). But you need to move them fast to have an effect!
              • if the static field is high enough to reduce/cancel the magnetic field of the stepper. Unless the magnet is very big and touches the stepper, it should not happen.
              Frédéric
                As @fma implies, the chances of magnets interfering with stepper drivers is very small. However, strong magnets can prevent brushless fans from working, and even weak magnets can affect a BLTouch.
                  Red Sand Robot
                  @fma @dc42 Thanks for the info! I'll probably have the Bondtech/Titan in between the electromagnet and the stepper motor just to be safe. I'm planning on using a small M3 screw, spring and printed flag with an optical endstop switch (and homing without the electromagnets on) so there shouldn't be any issues there as might happen with a BLTouch.
                  almost an engineer
                    pawPrinter @Red Sand Robot
                    @red-sand-robot No, I've not noticed any problems with the Bondtech being affected by the magnets (which are permanent magnets in my case, not electromagnets - I found electromagnets a bit heavy).
                    Interestingly, I have had one occasion when a fan didn't start up properly. I didn't think much of it at the time, because fans can be annoying, but it could have been related to the magnets as @dc42 predicts.
                    psychotik2k3undefined 1 Reply Last reply Reply Quote 0
                    • juan74undefined
                      juan74
                      @pawPrinter Nice work! I'll be inspiration for me. Could you please share your config file?
                      • psychotik2k3undefined
                        psychotik2k3 @fma
                        @fma kinda like mmu2 but once the filament is feeded it would go into free mode or another channel
                          psychotik2k3 @pawPrinter
                          @pawPrinter do you have link about the magnets you use ?
                          and do you think an external counter weight can replace the spring mecanism ?
                          thanks
