    Duet 3 Mainboard 6HC - initial production run.
    243
    33.7k
      A Former User
      I was actually thinking about that the other day, most of the issues can be mitigated by having the system run with the majority of the operating system as read-only under normal operations. I don't know what is planned, but it quite doable to make the Duet 3 image fairly resilient with respect to unexcpected shutdowns.
        Phaedrux Moderator @LeonMF
        @leonmf said in Duet 3 Mainboard 6HC - initial production run.:
        My experience with Raspberry Pis were that they are a full OS and don't particularly love being shut down without going through a clean shutdown.
        I may be lucky, but I have never shut down a pi cleanly. Always just pulled the power on the poor little things. Never had any ill effects.
        DocTruckerundefined 1 Reply Last reply Reply Quote 1
        • DocTruckerundefined
          DocTrucker @Phaedrux
          @phaedrux think this is more like to be a problem if the DWC solution on the computer does some heavy background processing like simulation.
          • JoergS5undefined
            JoergS5 @LeonMF
            @leonmf so maybe it's better to setup the operating system as read-only, similar to http://hallard.me/raspberry-pi-read-only/
            and held the non volatile data in a separate storage.
              T3P3Tony administrators
              Good points. One way to go is to have the power configured so the Raspi does not shut down, or at least is in charge of the shutdown. So power off just sets the printer into a low power sleep mode where the 24V is off and only a little 5V is used to keep the Pi idling... When you turn a modern TV or whatever that is what happens...
                dc42 administrators @Knaudler
                @knaudler said in Duet 3 Mainboard 6HC - initial production run.:
                screws for Power ?
                something like this would be nice:
                https://www.wago.com/de/leiterplattenanschluss/klemmenleiste-fuer-leiterplatten/p/2716-102
                I've taken a look at the Wago range of push-in connectors. Many of them are either too large or very expensive. The most suitable 6-way one I found was this one https://uk.farnell.com/wago/2092-1376/terminal-block-wire-to-brd-6pos/dp/2352417. Like most push-in terminals blocks, it's only suitable for use with solid core wire or stranded wire that has been terminated with ferrules already. So if you need to use stranded core wire, it doesn't avoid the need for crimping, and it's hard to justify the additional cost.
                For the home user, an advantage of the barrier strips we currently use is that crimping tools for automotive-style fork receptacles are very cheap. But I can see that some OEMs might prefer push-in terminals to speed up wiring.
                  A Former User
                  Back in the day, we ended up with a compromise and used pluggable terminals where phoenix contacts had both screw and push-in female connectors, the boards used the same male header (but that was only up to about 10A iirc)
                  Also found that you could use stranded wire without ferrules, but then you loose the tool-less advantage as you need to press the release spring to insert the stranded wire. And something like Radox 125 is wound so tight it can be inserted without ferrules in a pinch, but for production you'll want ferrules anyways.
                  But yes, quite significant savings on wiring time with push-in terminals when wiring is prepared by machines automatically cutting, stripping, labeling and crimping ferrules. However unless you have the machines I doubt its worth the investment for a single 6-pin terminal.
                  • JoergS5undefined
                    JoergS5 @LeonMF
                    @leonmf I bought a Pi 3+, but will buy a Pi 4 also, because he has a lot more I2C and SPI interfaces (about 5 each, 3 + has only one useable SPI, which will be used to communicate to Duet), so if one wants to use Pi4 for additional tasks like using cameras (e.g. Arducam with SPI/I2C interface), additional I2C and SPI are useful.
                    • KP0005undefined
                      KP0005
                      Regarding the SPI connection, would it in theory be possible to connect a Maestro to the SBC in a similar way?
                        dc42 administrators @KP0005
                        @matej101 said in Duet 3 Mainboard 6HC - initial production run.:
                        In theory yes, with a lot of firmware changes. Ideally the W5500 Ethernet chip would be removed to free up the fast SPI connection. I guess the daughter board SPI could be used instead, at a lower speed and by dropping support for external SD card sockets and temperature daughter boards.
                        KP0005undefined 1 Reply Last reply Reply Quote 0
                        • KP0005undefined
                          KP0005 @dc42
                          @dc42 thank you for the quick reply! I'm not really experienced with programming so redoing part of the firmware seems to be a bit of a stretch for my use case. Guess I'll just hack something together instead.
                            A Former User @KP0005
                            No hacking needed just buy a Duet 3..............
                            • KP0005undefined
                              KP0005 @A Former User
                              @calvinx but money...
                              • mundsenundefined
                                mundsen
                                Order one today, plan to use it in my Corexy project 🥰
                                  It's occurred to me that a Duet Ethernet without the Ethernet daughter board should be relatively straightforward to connect to a RPi. Maybe I'll add support for this in the future.
                                  gtj0undefined denkeundefined KP0005undefined 3 Replies Last reply Reply Quote 2
                                  • gtj0undefined
                                    gtj0 @dc42
                                    @dc42 said in Duet 3 Mainboard 6HC - initial production run.:
                                    That could be VERY handy!
                                    • denkeundefined
                                      denke @dc42
                                      As I remember the wifi can also be converted to ethernet. So, Is it possible for that too?
                                        dc42 administrators @denke
                                        @denke said in Duet 3 Mainboard 6HC - initial production run.:
                                        Yes, if you removed the WiFi module.
                                          The tests on the first Duet 3 main board have passed over the weekend, so assembly of the first batch is now under way.
                                          Vetiundefined 1 Reply Last reply Reply Quote 4
                                          • Vetiundefined
                                            Veti @dc42
                                            congratulations. nice to be able to follow the development cycle as is progresses to the final product.
