    Duet 3 Mainboard 6HC - initial production run.
    243
    32.8k
    • DocTruckerundefined
      DocTrucker @Phaedrux
      @phaedrux think this is more like to be a problem if the DWC solution on the computer does some heavy background processing like simulation.
      • JoergS5undefined
        JoergS5 @LeonMF
        @leonmf so maybe it's better to setup the operating system as read-only, similar to http://hallard.me/raspberry-pi-read-only/
        and held the non volatile data in a separate storage.
          T3P3Tony administrators
          Good points. One way to go is to have the power configured so the Raspi does not shut down, or at least is in charge of the shutdown. So power off just sets the printer into a low power sleep mode where the 24V is off and only a little 5V is used to keep the Pi idling... When you turn a modern TV or whatever that is what happens...
            dc42 administrators @Knaudler
            @knaudler said in Duet 3 Mainboard 6HC - initial production run.:
            screws for Power ?
            something like this would be nice:
            https://www.wago.com/de/leiterplattenanschluss/klemmenleiste-fuer-leiterplatten/p/2716-102
            I've taken a look at the Wago range of push-in connectors. Many of them are either too large or very expensive. The most suitable 6-way one I found was this one https://uk.farnell.com/wago/2092-1376/terminal-block-wire-to-brd-6pos/dp/2352417. Like most push-in terminals blocks, it's only suitable for use with solid core wire or stranded wire that has been terminated with ferrules already. So if you need to use stranded core wire, it doesn't avoid the need for crimping, and it's hard to justify the additional cost.
            For the home user, an advantage of the barrier strips we currently use is that crimping tools for automotive-style fork receptacles are very cheap. But I can see that some OEMs might prefer push-in terminals to speed up wiring.
              A Former User
              Back in the day, we ended up with a compromise and used pluggable terminals where phoenix contacts had both screw and push-in female connectors, the boards used the same male header (but that was only up to about 10A iirc)
              Also found that you could use stranded wire without ferrules, but then you loose the tool-less advantage as you need to press the release spring to insert the stranded wire. And something like Radox 125 is wound so tight it can be inserted without ferrules in a pinch, but for production you'll want ferrules anyways.
              But yes, quite significant savings on wiring time with push-in terminals when wiring is prepared by machines automatically cutting, stripping, labeling and crimping ferrules. However unless you have the machines I doubt its worth the investment for a single 6-pin terminal.
              • JoergS5undefined
                JoergS5 @LeonMF
                @leonmf I bought a Pi 3+, but will buy a Pi 4 also, because he has a lot more I2C and SPI interfaces (about 5 each, 3 + has only one useable SPI, which will be used to communicate to Duet), so if one wants to use Pi4 for additional tasks like using cameras (e.g. Arducam with SPI/I2C interface), additional I2C and SPI are useful.
                • KP0005undefined
                  KP0005
                  Regarding the SPI connection, would it in theory be possible to connect a Maestro to the SBC in a similar way?
                    dc42 administrators @KP0005
                    @matej101 said in Duet 3 Mainboard 6HC - initial production run.:
                    In theory yes, with a lot of firmware changes. Ideally the W5500 Ethernet chip would be removed to free up the fast SPI connection. I guess the daughter board SPI could be used instead, at a lower speed and by dropping support for external SD card sockets and temperature daughter boards.
                    KP0005undefined 1 Reply Last reply Reply Quote 0
                    • KP0005undefined
                      KP0005 @dc42
                      @dc42 thank you for the quick reply! I'm not really experienced with programming so redoing part of the firmware seems to be a bit of a stretch for my use case. Guess I'll just hack something together instead.
                        A Former User @KP0005
                        No hacking needed just buy a Duet 3..............
                        • KP0005undefined
                          KP0005 @A Former User
                          @calvinx but money...
                          • mundsenundefined
                            mundsen
                            Order one today, plan to use it in my Corexy project 🥰
                              It's occurred to me that a Duet Ethernet without the Ethernet daughter board should be relatively straightforward to connect to a RPi. Maybe I'll add support for this in the future.
                              gtj0undefined denkeundefined KP0005undefined 3 Replies Last reply Reply Quote 2
                              • gtj0undefined
                                gtj0 @dc42
                                @dc42 said in Duet 3 Mainboard 6HC - initial production run.:
                                That could be VERY handy!
                                • denkeundefined
                                  denke @dc42
                                  As I remember the wifi can also be converted to ethernet. So, Is it possible for that too?
                                    dc42 administrators @denke
                                    @denke said in Duet 3 Mainboard 6HC - initial production run.:
                                    Yes, if you removed the WiFi module.
                                      The tests on the first Duet 3 main board have passed over the weekend, so assembly of the first batch is now under way.
                                      Vetiundefined 1 Reply Last reply Reply Quote 4
                                      • Vetiundefined
                                        Veti @dc42
                                        congratulations. nice to be able to follow the development cycle as is progresses to the final product.
                                        • mundsenundefined
                                          mundsen
                                          I have order a Duet 3 - is it possible to get a 3D model? I`m designing my own railcore based corexy printer - hope to spend the time while waiting for the controller to arrive designing a housing for Duet + PI
                                            A Former User @mundsen
                                            @mundsen
                                            the pcb size and major component location is already available on the duet website. that's what I used to allow me to design a suitable holder
