    Endstop switches doesnt work
    1.6k
    • Vetiundefined
      Veti
      @goodchrhere said in Endstop switches doesnt work:
      M558 P0 H0 F300 T3000 ; disable Z probe but set dive height, probe speed and travel speed
      if you plugged it into the z endstop that would not work because you have disabled it.
      B4138 is the default and most likely wrong for your thermistors.
        A Former User
        Does this type of endstop doesnt work?
        Yes, its a common SPDT switch, that can be used as both normally closed and normally open switch.
        I have wired the right, because when i measure on the plug, its right.
        elaborate? and ref Veti's comment, which axis are you having trouble with?
        Which board do you have, the Duet2 Ethernet and Duet2 Wifi has LEDs to indicate the state of the endstops, makes for easy diagnostic. The Duet2 Maestro does not have these LEDs.
        But M119 will print the status of the endstops, please run M119 before activating the enstop, and again while the endstop is active.
        • goodchrhereundefined
          goodchrhere
          Thermistor are right, the thermistor from bed and the thermistor from extruder 1 are in function.
          i have a normal endstop switch like the first post for all 3 axes. for x and for y and for z.
          it doesn't work on all axes.
          I know about normaly open and normaly closed.
          i tested both, with changes the wires in the plug, and change the firmware from active high to active low.
          I have a Duet 2 Ethernet with firmware version 2.02
          I can test the M119 in yat in the evening, when i'm back at home.
            A Former User
            faster to look at the endstop leds than to use m119, but you can also use m119 in the web interface and g-code console instead of the serial terminal.
            but as veti points out, there are multiple lines configuring the z endstop, ending up with it disabled. so only x and y will work as the config is now.
              goodchrhere
              okay, i will look to the endstops leds.
              okay, i will change the configuring for the z endstop.
              Thanks for your help.
                droftarts administrators
                Check your wiring. See https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Microswitch
                Connect the switch between GND and STP (the outer 2 pins of the 3-pin connector). Note: this is not the same as on RAMPS.
                We recommend you use the normally-closed contacts of the microswitches, which are generally the outside two connections on the microswitch, and set the signal polarity to active high (S1) in the M574 command.`
                See wiring diagram: https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/4k56ZjaaAHrTJI6Z.huge
                As others have pointed out, only X and Y endstops will work with your current config.g
                goodchrhereundefined 1 Reply Last reply Reply Quote 0
                  A Former User @A Former User
                  @bearer said in Endstop switches doesnt work:
                  That only works if you can see the board when you press the switch, some put the boards in boxes and cant see the led's
                  • Vetiundefined
                    Veti @goodchrhere
                    they may be displaying a temperature, but when the temperature is hotter than room temperature it will display incorrect results.
                      goodchrhere @droftarts
                      @droftarts i checked my wiring 3 times. i measured with a multimeter on the plug, and ih have signal or no signal, but the duet doesn't recognize the signal. i know that only work in x and y because my config.
                      But x and y doesn't work.
                      • Vetiundefined
                        Veti
                        M574 X1 Y1 S1
                        can you manually put this command in the console and try again?
                        post the actual output of M119 before and after the closing the endstop
                          goodchrhere @Veti
                          @veti i will do that today or tomorrow evening.
                          • themelleundefined
                            themelle
                            Looking at https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/4k56ZjaaAHrTJI6Z.huge
                            ... where exactly did you plug in the two wires coming from the endstop switches?
                            goodchrhereundefined A Former User? 2 Replies Last reply Reply Quote 2
                              goodchrhere @themelle
                              @themelle i did that, i checked the wiring 3 times.
                                A Former User @themelle
                                @themelle said in Endstop switches doesnt work:
                                This.. we need pictures of where the switches are plugged in to the switches and the duet. And dont take it that we are saying you are wrong we are only trying to help you, so for us to do that we need to see if there is anything wrong you might have missed.
                                goodchrhereundefined 1 Reply Last reply Reply Quote 1
                                  goodchrhere @A Former User
                                  @calvinx okay i will make photos today or tomorrow evening.
                                  thanks for your help
                                    goodchrhere
                                    okay, i dont know, i had new wired and x and y works. i'm an idiot xD
                                    What i have to chance in my config, to active z with the same switch?
                                    themelleundefined 1 Reply Last reply Reply Quote 0
                                    • themelleundefined
                                      themelle @goodchrhere
                                      @goodchrhere I'm glad you got it working!
                                      To have Z axis behaving as X and Y you should just remove the lines
                                      M574 Z1 S3 ; set endstops controlled by motor stall detection
                                      from config.g
                                        goodchrhere
                                        I‘t works fine, thanks for your helps!
