    Endstop switches doesnt work
    1.6k
    • Vetiundefined
      Veti @goodchrhere
      @goodchrhere said in Endstop switches doesnt work:
      Thermistor are right, the thermistor from bed and the thermistor from extruder 1 are in function.
      they may be displaying a temperature, but when the temperature is hotter than room temperature it will display incorrect results.
      • goodchrhereundefined
        goodchrhere @droftarts
        @droftarts i checked my wiring 3 times. i measured with a multimeter on the plug, and ih have signal or no signal, but the duet doesn't recognize the signal. i know that only work in x and y because my config.
        But x and y doesn't work.
        • Vetiundefined
          Veti
          M574 X1 Y1 S1
          can you manually put this command in the console and try again?
          post the actual output of M119 before and after the closing the endstop
          goodchrhereundefined 1 Reply Last reply Reply Quote 0
            goodchrhere @Veti
            @veti i will do that today or tomorrow evening.
            • themelleundefined
              themelle
              Looking at https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/4k56ZjaaAHrTJI6Z.huge
              ... where exactly did you plug in the two wires coming from the endstop switches?
              goodchrhereundefined A Former User? 2 Replies Last reply Reply Quote 2
                goodchrhere @themelle
                @themelle i did that, i checked the wiring 3 times.
                  A Former User @themelle
                  @themelle said in Endstop switches doesnt work:
                  This.. we need pictures of where the switches are plugged in to the switches and the duet. And dont take it that we are saying you are wrong we are only trying to help you, so for us to do that we need to see if there is anything wrong you might have missed.
                  goodchrhereundefined 1 Reply Last reply Reply Quote 1
                    goodchrhere @A Former User
                    @calvinx okay i will make photos today or tomorrow evening.
                    thanks for your help
                      goodchrhere
                      okay, i dont know, i had new wired and x and y works. i'm an idiot xD
                      What i have to chance in my config, to active z with the same switch?
                      themelleundefined 1 Reply Last reply Reply Quote 0
                      • themelleundefined
                        themelle @goodchrhere
                        @goodchrhere I'm glad you got it working!
                        To have Z axis behaving as X and Y you should just remove the lines
                        M574 Z1 S3 ; set endstops controlled by motor stall detection
                        from config.g
                          goodchrhere
                          I‘t works fine, thanks for your helps!
