    Endstop switches doesnt work
    1.6k
      droftarts administrators
      Check your wiring. See https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Microswitch
      Connect the switch between GND and STP (the outer 2 pins of the 3-pin connector). Note: this is not the same as on RAMPS.
      We recommend you use the normally-closed contacts of the microswitches, which are generally the outside two connections on the microswitch, and set the signal polarity to active high (S1) in the M574 command.`
      See wiring diagram: https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/4k56ZjaaAHrTJI6Z.huge
      As others have pointed out, only X and Y endstops will work with your current config.g
      goodchrhereundefined 1 Reply Last reply Reply Quote 0
        A Former User @A Former User
        @bearer said in Endstop switches doesnt work:
        faster to look at the endstop leds than to use m119,
        That only works if you can see the board when you press the switch, some put the boards in boxes and cant see the led's
        • Vetiundefined
          Veti @goodchrhere
          @goodchrhere said in Endstop switches doesnt work:
          Thermistor are right, the thermistor from bed and the thermistor from extruder 1 are in function.
          they may be displaying a temperature, but when the temperature is hotter than room temperature it will display incorrect results.
          • goodchrhereundefined
            goodchrhere @droftarts
            @droftarts i checked my wiring 3 times. i measured with a multimeter on the plug, and ih have signal or no signal, but the duet doesn't recognize the signal. i know that only work in x and y because my config.
            But x and y doesn't work.
            • Vetiundefined
              Veti
              M574 X1 Y1 S1
              can you manually put this command in the console and try again?
              post the actual output of M119 before and after the closing the endstop
                goodchrhere @Veti
                @veti i will do that today or tomorrow evening.
                • themelleundefined
                  themelle
                  Looking at https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/4k56ZjaaAHrTJI6Z.huge
                  ... where exactly did you plug in the two wires coming from the endstop switches?
                  goodchrhereundefined A Former User? 2 Replies Last reply Reply Quote 2
                    goodchrhere @themelle
                    @themelle i did that, i checked the wiring 3 times.
                      A Former User @themelle
                      @themelle said in Endstop switches doesnt work:
                      This.. we need pictures of where the switches are plugged in to the switches and the duet. And dont take it that we are saying you are wrong we are only trying to help you, so for us to do that we need to see if there is anything wrong you might have missed.
                      goodchrhereundefined 1 Reply Last reply Reply Quote 1
                        goodchrhere @A Former User
                        @calvinx okay i will make photos today or tomorrow evening.
                        thanks for your help
                          goodchrhere
                          okay, i dont know, i had new wired and x and y works. i'm an idiot xD
                          What i have to chance in my config, to active z with the same switch?
                          themelleundefined 1 Reply Last reply Reply Quote 0
                          • themelleundefined
                            themelle @goodchrhere
                            @goodchrhere I'm glad you got it working!
                            To have Z axis behaving as X and Y you should just remove the lines
                            M574 Z1 S3 ; set endstops controlled by motor stall detection
                            from config.g
                              goodchrhere
                              I‘t works fine, thanks for your helps!
