    Endstop switches doesnt work
    1.6k
      A Former User
      faster to look at the endstop leds than to use m119, but you can also use m119 in the web interface and g-code console instead of the serial terminal.
      but as veti points out, there are multiple lines configuring the z endstop, ending up with it disabled. so only x and y will work as the config is now.
      • goodchrhereundefined
        goodchrhere
        okay, i will look to the endstops leds.
        okay, i will change the configuring for the z endstop.
        Thanks for your help.
          droftarts administrators
          Check your wiring. See https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Microswitch
          Connect the switch between GND and STP (the outer 2 pins of the 3-pin connector). Note: this is not the same as on RAMPS.
          We recommend you use the normally-closed contacts of the microswitches, which are generally the outside two connections on the microswitch, and set the signal polarity to active high (S1) in the M574 command.`
          See wiring diagram: https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/4k56ZjaaAHrTJI6Z.huge
          As others have pointed out, only X and Y endstops will work with your current config.g
          goodchrhereundefined 1 Reply Last reply Reply Quote 0
            A Former User @A Former User
            @bearer said in Endstop switches doesnt work:
            That only works if you can see the board when you press the switch, some put the boards in boxes and cant see the led's
            • Vetiundefined
              Veti @goodchrhere
              @goodchrhere said in Endstop switches doesnt work:
              Thermistor are right, the thermistor from bed and the thermistor from extruder 1 are in function.
              they may be displaying a temperature, but when the temperature is hotter than room temperature it will display incorrect results.
                goodchrhere @droftarts
                @droftarts i checked my wiring 3 times. i measured with a multimeter on the plug, and ih have signal or no signal, but the duet doesn't recognize the signal. i know that only work in x and y because my config.
                But x and y doesn't work.
                • Vetiundefined
                  Veti
                  M574 X1 Y1 S1
                  can you manually put this command in the console and try again?
                  post the actual output of M119 before and after the closing the endstop
                    goodchrhere @Veti
                    @veti i will do that today or tomorrow evening.
                    • themelleundefined
                      themelle
                      Looking at https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/4k56ZjaaAHrTJI6Z.huge
                      ... where exactly did you plug in the two wires coming from the endstop switches?
                      goodchrhereundefined A Former User? 2 Replies Last reply Reply Quote 2
                        goodchrhere @themelle
                        @themelle i did that, i checked the wiring 3 times.
                          A Former User @themelle
                          @themelle said in Endstop switches doesnt work:
                          This.. we need pictures of where the switches are plugged in to the switches and the duet. And dont take it that we are saying you are wrong we are only trying to help you, so for us to do that we need to see if there is anything wrong you might have missed.
                          goodchrhereundefined 1 Reply Last reply Reply Quote 1
                            goodchrhere @A Former User
                            @calvinx okay i will make photos today or tomorrow evening.
                            thanks for your help
                              goodchrhere
                              okay, i dont know, i had new wired and x and y works. i'm an idiot xD
                              What i have to chance in my config, to active z with the same switch?
                              themelleundefined 1 Reply Last reply Reply Quote 0
                              • themelleundefined
                                themelle @goodchrhere
                                @goodchrhere I'm glad you got it working!
                                To have Z axis behaving as X and Y you should just remove the lines
                                M574 Z1 S3 ; set endstops controlled by motor stall detection
                                from config.g
                                  goodchrhere
                                  I‘t works fine, thanks for your helps!
