    Endstop switches doesnt work
    1.6k
      A Former User
      @goodchrhere said in Endstop switches doesnt work:
      Does this type of endstop doesnt work?
      Yes, its a common SPDT switch, that can be used as both normally closed and normally open switch.
      I have wired the right, because when i measure on the plug, its right.
      elaborate? and ref Veti's comment, which axis are you having trouble with?
      Which board do you have, the Duet2 Ethernet and Duet2 Wifi has LEDs to indicate the state of the endstops, makes for easy diagnostic. The Duet2 Maestro does not have these LEDs.
      But M119 will print the status of the endstops, please run M119 before activating the enstop, and again while the endstop is active.
      • goodchrhereundefined
        goodchrhere
        Thermistor are right, the thermistor from bed and the thermistor from extruder 1 are in function.
        i have a normal endstop switch like the first post for all 3 axes. for x and for y and for z.
        it doesn't work on all axes.
        I know about normaly open and normaly closed.
        i tested both, with changes the wires in the plug, and change the firmware from active high to active low.
        I have a Duet 2 Ethernet with firmware version 2.02
        I can test the M119 in yat in the evening, when i'm back at home.
          A Former User
          faster to look at the endstop leds than to use m119, but you can also use m119 in the web interface and g-code console instead of the serial terminal.
          but as veti points out, there are multiple lines configuring the z endstop, ending up with it disabled. so only x and y will work as the config is now.
            goodchrhere
            okay, i will look to the endstops leds.
            okay, i will change the configuring for the z endstop.
            Thanks for your help.
              droftarts administrators
              Check your wiring. See https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Microswitch
              Connect the switch between GND and STP (the outer 2 pins of the 3-pin connector). Note: this is not the same as on RAMPS.
              We recommend you use the normally-closed contacts of the microswitches, which are generally the outside two connections on the microswitch, and set the signal polarity to active high (S1) in the M574 command.`
              See wiring diagram: https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/4k56ZjaaAHrTJI6Z.huge
              As others have pointed out, only X and Y endstops will work with your current config.g
              goodchrhereundefined 1 Reply Last reply Reply Quote 0
                A Former User @A Former User
                @bearer said in Endstop switches doesnt work:
                That only works if you can see the board when you press the switch, some put the boards in boxes and cant see the led's
                • Vetiundefined
                  Veti @goodchrhere
                  they may be displaying a temperature, but when the temperature is hotter than room temperature it will display incorrect results.
                    goodchrhere @droftarts
                    @droftarts i checked my wiring 3 times. i measured with a multimeter on the plug, and ih have signal or no signal, but the duet doesn't recognize the signal. i know that only work in x and y because my config.
                    But x and y doesn't work.
                    • Vetiundefined
                      Veti
                      M574 X1 Y1 S1
                      can you manually put this command in the console and try again?
                      post the actual output of M119 before and after the closing the endstop
                        goodchrhere @Veti
                        @veti i will do that today or tomorrow evening.
                        • themelleundefined
                          themelle
                          Looking at https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/4k56ZjaaAHrTJI6Z.huge
                          ... where exactly did you plug in the two wires coming from the endstop switches?
                          goodchrhereundefined A Former User? 2 Replies Last reply Reply Quote 2
                            goodchrhere @themelle
                            @themelle i did that, i checked the wiring 3 times.
                              A Former User @themelle
                              @themelle said in Endstop switches doesnt work:
                              This.. we need pictures of where the switches are plugged in to the switches and the duet. And dont take it that we are saying you are wrong we are only trying to help you, so for us to do that we need to see if there is anything wrong you might have missed.
                              goodchrhereundefined 1 Reply Last reply Reply Quote 1
                                goodchrhere @A Former User
                                @calvinx okay i will make photos today or tomorrow evening.
                                thanks for your help
                                  goodchrhere
                                  okay, i dont know, i had new wired and x and y works. i'm an idiot xD
                                  What i have to chance in my config, to active z with the same switch?
                                  themelleundefined 1 Reply Last reply Reply Quote 0
                                  • themelleundefined
                                    themelle @goodchrhere
                                    @goodchrhere I'm glad you got it working!
                                    To have Z axis behaving as X and Y you should just remove the lines
                                    M574 Z1 S3 ; set endstops controlled by motor stall detection
                                    from config.g
                                      goodchrhere
                                      I‘t works fine, thanks for your helps!
