    Duet controlled micro mill
    My Duet controlled machine
    8
    32
    5.6k
    • 3DPMicroundefined
      3DPMicro
      Triskele charm for my lovely wife. Machined on the Duet Micro Mill of course
      Duet controlled Jet Lathe, scratch built micro mill and 3d printer. 1992 Haas VF2 VMC retrofit
      • JoergS5undefined
        JoergS5 @3DPMicro
        @3DPMicro said in Duet controlled micro mill:
        ...not to until the Stratasys patent has expired. That was supposed to happen this year but could be extended. I am uncertain of the current status.
        You have a great mill, you motivate me to build one too. Very nice!
        The patent you mentioned expires Feb 2021 and was discussed in https://www.reddit.com/r/3Dprinting/comments/d1bxy4/did_the_heated_build_chamber_patent_just_get_a/
        3DPMicroundefined 1 Reply Last reply Reply Quote 0
        • 3DPMicroundefined
          3DPMicro @JoergS5
          JoergS5,
          Thanks for the info on the patent.
          How big are you going to build your mill?
          JoergS5undefined 2 Replies Last reply Reply Quote 0
          • JoergS5undefined
            JoergS5 @3DPMicro
            @3DPMicro It's in the idea project phase, so no detailed plans yet. But my highest priority will be precision with a small build space (maybe 50 mm in each direction).
            • JoergS5undefined
              JoergS5 @3DPMicro
              @3DPMicro My special interest would be to mill small parts like
              • nozzles like matchless nozzles or SuperVolcano and hotends/heatbreaks for them
              • milling tools/cutters for bigger wood or metal CNC spindles
              • bigger parts like harmonic drive splines
              • producing ball bearing DIY would be nice too (just for fun)
              • parts for my Märklin Z trains (they are 1:220 train models)
              My general tought is to combine addititive with subtractive manufacturing and make a quality iteration: e.g. 3D print/metal casting/injection molding, then finish by routing/honing/sandblasting. Control product by comparing with the original model and iterate until the goal is reached.
              • 3DPMicroundefined
                3DPMicro @JoergS5
                @JoergS5 it's ,for sure, a good thing we have the Duet along with the work of David and Tony (and whoever else contributes). Now our imaginations aren't so much constrained by money. With the 2 and now the Duet 3 the sky is the limit on functions. Sounds like many of your projects will require turning as well as 4th axis milling. I'm in the process of retrofitting a pretty good-sized manual lathe to CNC using a Duet 2.
                • JoergS5undefined
                  JoergS5 @3DPMicro
                  @3DPMicro Would be nice if you create threads about your lathe rebuild here also, as I am sure you have a lot of experience with precision production.
                  I agree that the Duets are great. I bought them primarily not because of the properties of the board, but because of the good support of firmware and nice, friendly, helpful forum.
                  • 3DPMicroundefined
                    3DPMicro @JoergS5
                    @JoergS5 said in Duet controlled micro mill:
                    I will probably do something similar with the lathe as I have done here with the mill. There doesn't appear to be much in the way of Duet controlled lathes so maybe I will be a bit more thorough with the steps involved. Should be relatively simple since it's only 2 axis but live tooling and/or tool changes will be something I want to incorporate
                    • kzamaniundefined
                      kzamani
                      @3DPMicro This build looks really great! Is there any chance I could take a peak at a BOM or exploded view? I've been wanting to build something like this for machining watch cases / main plates but I haven't found the time.
                      Thanks!
                      -k
                      • 3DPMicroundefined
                        3DPMicro @kzamani
                        @kzamani said in Duet controlled micro mill:
                        Thanks!
                        -k
                        I didnt create a BOM because it was fairly simple. Each axis is a self contained Misumi linear actuator. They are designed to stack to create a cartesian motion system. Mine are LX2001-100 (38mm travel) for the Y axis and LX2001-150 (88mm travel) for X, Z axis'. All are 1mm lead ball screws "P" precision grade for no backlash. The LX2005 would still provide high resolution (5mm lead ball screws) with .9 nema 17 steppers and afford faster rapids. Mine are 1.8 nema 14's on the X and Y and a .9 nema 17 on the Z. LX25's or 30's would also be a good choice as well as THK/NSK equivalents. The frame is made from 3" square steel bar machined to 75mm square. There is a decent amount of machine work to get them in a suitable state for a square and accurate CNC machine. I surface ground the critical surfaces but that isnt totally necessary. I also designed in some versatility to allow longer Y travel and separate linear rails and ball screw for the Z axis. End stops are OMRON E2EC-CR5C1 proximity switches which are deadly accurate.
                        If you want to duplicate exactly what I did I will put the CAD model up.
                        This temporary solution for keeping the machine clean has worked well so I doubt I'll change it
                        • mark92undefined
                          mark92 @3DPMicro
                          @3dpmicro Sorry to reply to this old thread but I find this build to be awesome, so simple yet super high precision, I wonder if is posible to see a video of it in action? I am a watchmaker student doing research for building a cnc mill and this one has to be the best approach I have ever seen, thanks in advance!
                          • 3DPMicroundefined
                            3DPMicro
                            The Duet 2, with regularily updated FW has been flawless through many projects over the last few years guiding this little mill. I have the same confidence in it as any of the professional grade machines I run at work.
                            I thought if it could be tripped up the g code for 3d maching the .5mm radii on this part would do it. Resolving moves as small as 100nm for the inside corners there was no indication of lost steps or rounding errors (the floating point goes that low?) over the 8 parts that were made. Pretty cool
                            https://youtu.be/27_E8RawCyQ
                            There were 0 hiccups and 0 errors but underruns showed 0,0,4. What does that mean?
                            JoergS5undefined 1 Reply Last reply Reply Quote 3
                            • JoergS5undefined
                              JoergS5 @3DPMicro
                              float is built by three parts: the sign, then the digits with 7 to 8 digits precision (the 7 to 8 digits of the 10 base decimal system) and an exponent with high range (1e-38 to 1e38), so it doesn't make a difference between mm or nm. Most values will be rounded.
                              For your 0,0,4 underrun message, I searched the code. in DDARing.cpp Diagnostics() is the code, the three variables are
                              numLookaheadUnderruns, numPrepareUnderruns, numNoMoveUnderruns
                              In DDARing.h are some explanations about the meaning:
                              unsigned int numNoMoveUnderruns; // How many times we wanted a new move but there were none
                              so this seems to be not a serious error. I am not sure about the reason, but I can think of rounding errors or queue not being filled fast enough.
                              • 3DPMicroundefined
                                3DPMicro @JoergS5
                                @JoergS5 thanks for the explanation and feedback. I wont concern myself with it but will monitor it for the sake of better understanding what might effect it
                                • 3DPMicroundefined
                                  3DPMicro
                                  ![20230205_220659.jpg](/assets/uploads/files/1701318298445-20230205_22020230108_134220.jpg 659-resized.jpg) !20230205_220941.jpg
                                  • 3DPMicroundefined
                                    3DPMicro
                                      very nice! ...what is it?
                                      • 3DPMicroundefined
                                        3DPMicro @Phaedrux
                                        @Phaedrux Its a retractable ID badge holder that goes on your belt with places to attach a zip drive and random number generator dongle. Grade 5 Titanium, Delrin and spring steel
                                        Made on a wire EDM, Duet 2 controlled Lathe and my Duet 2 controlled micro mill
                                          I was going to guess fishing reel. 🤣
                                          • JoergS5undefined
                                            JoergS5
                                            I thought that it is an accurate scale, with compliant parts left and right, the big wheel being the indicator.
                                            Nice quality!!
