    How do I enable MESH leveling for the print?
    25
    3.7k
    • Rat_Patrolundefined
      Rat_Patrol
      Previously using Marlin, I would manually probe the bed and keep that in EEPROM. I would simply run a command in my print starting script (G29 S1 IIRC) to use it. Tried the same script now using a Maestro, and it doesn't work.
      How is MESH used on this platform? I have a BLTouch sensor on my carriage.
      • jens55undefined
        jens55
        https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
          Rat_Patrol
          So I need to probe the bed for every print?
          SteveYYCundefined 1 Reply Last reply Reply Quote 0
          • jens55undefined
            jens55
            No, once a bed mesh has been built, it is loaded automatically (if so enabled in config.g) on startup and is used as a default for every print.
            The Duet can take just over 400 mesh bed data points and in my case it takes about 3 hours to run a full (automated) scan. It would be a real bummer if I had to do that before every print ๐Ÿ™‚
            You can also build multiple mesh beds (say for different bed temperatures) and load a different bed if you want. In my case I decided to probe the bed at my most commonly used temperature and live with the slight differences at other temperatures.
            • SteveYYCundefined
              SteveYYC @Rat_Patrol
              @Rat_Patrol
              Once you have probed the bed with the command
              G29 S0
              the result of the mesh probe is saved to /sys/heightmap.csv
              Without probing the bed again, you can load the saved result from an earlier mesh probe using the command
              G29 S1   ; this loads the contents of /sys/heightmap.csv
                @Rat_Patrol said in How do I enable MESH leveling for the print?:
                If you used G29 S1 and it didn't work, what exactly didn't work about it?
                Typically you'd put G29 S1 in the slicer start gcode. Or even at the end of homeall.g (called by G28) if you wanted it to be active at all times to protect the nozzle from contacting the bed surface if you happen to have a less than perfectly flat bed.
                  Rat_Patrol
                  My slicer start code:
                  M572 D0 S0.045
                  G28
                  G29 S1
                  When the print starts, the Z rods visibly aren't running MESH, and the uneven first layer confirms it. I have run MESH probing, can view the map, but MESH is strangely absent during a print.
                    jay_s_uk
                    M122 shows you whether mesh levelling has been activated or not
                      Rat_Patrol
                      10:24:26 AMM122
                      RepRapFirmware for Duet 2 Maestro version 2.05 running on Duet Maestro 1.0
                      Board ID: 08DAM-9F9GA-J24TD-6J9F0-3SW6R-K51QV
                      Used output buffers: 1 of 24 (14 max)
                      Static ram: 19804
                      Dynamic ram: 91164 of which 0 recycled
                      Exception stack ram used: 336
                      Never used ram: 19768
                      Tasks: NETWORK(ready,716) HEAT(blocked,1272) MAIN(running,3896) IDLE(ready,160)
                      Owned mutexes:
                      Last reset 17:18:54 ago, cause: power up
                      Last software reset at 2020-01-20 16:37, reason: User, spinning module GCodes, available RAM 19780 bytes (slot 2)
                      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                      Error status: 0
                      Free file entries: 10
                      SD card 0 detected, interface speed: 15.0MBytes/sec
                      SD card longest block write time: 53.1ms, max retries 0
                      MCU temperature: min 21.1, current 34.8, max 41.8
                      Supply voltage: min 0.0, current 24.2, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                      Driver 0: standstill, read errors 0, write errors 0, ifcount 16, reads 2962, timeouts 0
                      Driver 1: standstill, read errors 0, write errors 0, ifcount 16, reads 2949, timeouts 13
                      Driver 2: standstill, read errors 0, write errors 0, ifcount 16, reads 2962, timeouts 0
                      Driver 3: standstill, read errors 0, write errors 0, ifcount 14, reads 2948, timeouts 16
                      Driver 4: standstill, read errors 0, write errors 0, ifcount 6, reads 2972, timeouts 0
                      Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 2977
                      Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 2977
                      Date/time: 2020-01-21 10:24:21
                      Slowest loop: 147.95ms; fastest: 0.05ms
                      Hiccups: 0, FreeDm: 160, MinFreeDm: 130, MaxWait: 56660031ms
                      Bed compensation in use: mesh, comp offset 0.073
                      === DDARing ===
                      Scheduled moves: 12, completed moves: 12, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                      Bed heaters = 0, chamberHeaters = -1 -1
                      Heater 0 is on, I-accum = 0.0
                      Segments left: 0
                      Movement lock held by null
                      http is idle in state(s) 0
                      telnet is idle in state(s) 0
                      file is idle in state(s) 0
                      serial is idle in state(s) 0
                      aux is idle in state(s) 0
                      daemon is idle in state(s) 0
                      queue is idle in state(s) 0
                      lcd is idle in state(s) 0
                      Code queue is empty.
                      === Network ===
                      Slowest loop: 135.62ms; fastest: 0.02ms
                      HTTP sessions: 1 of 8
                      Interface state 5, link 100Mbps full duplex
                        jay_s_uk
                        It shows as being active.
                        Do you have a picture of your bed mesh?
                        How many probe points do you have?
                        Do you probe it hot or cold?
                          Rat_Patrol
                          Pic of probing results:
                          Ran MESH at PETG temps.
                            Rat_Patrol
                            My bed is very uneven at this point: I'm running a temporary Y carriage setup until I get some hardware in to manually level it out.
                            Or until I cut up some soda cans ๐Ÿ˜„
                              Rat_Patrol
                              Well, I re-sliced and uploaded, and MESH appears to be working now.
                              Not doing a great job though, its like my nozzle-to-probe offset is wrong.
                              I got the numbers for the offset from Fusion where I modeled all the parts, does my config look good?
                              ; Configuration file for Duet Maestro (firmware version 2.03)
                              ; generated by RepRapFirmware Configuration Tool v2.1.5 on Thu Jan 09 2020 17:14:50 GMT-0600 (Central Standard Time)
                              G90                                      ; send absolute coordinates...
                              M83                                      ; ...but relative extruder moves
                              M550 P"Robo R1++"                        ; set printer name
                              M918 P1 E4 F2000000                      ; configure direct-connect display
                              M551 P"xxxxx"                         ; set password
                              M552 P0.0.0.0 S1                         ; enable network and acquire dynamic address via DHCP
                              M586 P0 S1                               ; enable HTTP
                              M586 P1 S0                               ; disable FTP
                              M586 P2 S0                               ; disable Telnet
                              M569 P0 S1                               ; physical drive 0 goes forwards
                              M569 P1 S1                               ; physical drive 1 goes forwards
                              M569 P2 S1                               ; physical drive 2 goes forwards
                              M569 P3 S1                               ; physical drive 3 goes forwards
                              M584 X0 Y1 Z2 E3                         ; set drive mapping
                              M350 X16 Y16 Z16 E16 I1                  ; configure microstepping with interpolation
                              M92 X80.00 Y80.00 Z400.00 E813.65        ; set steps per mm
                              M566 X100.00 Y100.00 Z100 E100      ; set maximum instantaneous speed changes (mm/min)
                              M203 X9000.00 Y9000.00 Z720.00 E2100.00  ; set maximum speeds (mm/min)
                              M201 X1100.00 Y1100.00 Z1100.00 E3000.00  ; set accelerations (mm/s^2)
                              M906 X1500 Y1500 Z1000 E1500 I50          ; set motor currents (mA) and motor idle factor in per cent
                              M84 S30                                  ; Set idle timeout
                              M208 X0 Y0 Z0 S1                         ; set axis minima
                              M208 X210 Y210 Z250 S0                   ; set axis maxima
                              M574 X1 Y1 S1                            ; set active high endstops
                              M574 Z1 S2                               ; set endstops controlled by probe
                              M558 P9 H5 F300 T6000                   ; set Z probe type to bltouch and the dive height + speeds
                              G31 P500 X-32.201 Y-26.389 Z3.00                ; set Z probe trigger value, offset and trigger height
                              M557 X0:210 Y0:210 S40                   ; define mesh grid
                              M305 P0 T100000 B4138 R2200              ; set thermistor + ADC parameters for heater 0
                              M143 H0 S120                             ; set temperature limit for heater 0 to 120C
                              M305 P1 T100000 B4725 C7.060000e-8 R2200 ; set thermistor + ADC parameters for heater 1
                              M143 H1 S280                             ; set temperature limit for heater 1 to 280C
                              M106 P0 S0 I0 F500 H-1                   ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                              M106 P1 T45 S1 H1                  ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                              M563 P0 S"Extruder" D0 H1 F0           ; define tool 0
                              G10 P0 X0 Y0 Z0                          ; set tool 0 axis offsets
                              G10 P0 R0 S0                             ; set initial tool 0 active and standby temperatures to 0C
                              devleonundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                              • PaulHewundefined
                                PaulHew
                                In my experience I manually level the bed using to 4 screws on my ender3.
                                I try and make it as level as possible using paper gauge between nozzle and bed.
                                Not teaching sucking eggs, I release the x/y steppers so I can move the gantry. Z is jogged down to grip paper, but stepper is engaged.
                                The I run the mesh after heating the nozzle to 160 and bed to 60
                                I also have 2 mirrors I use. I rename each heightmap to mirror 1 or 2 and call each mirror from curaโ€™s start code.
                                • devleonundefined
                                  devleon @Rat_Patrol
                                  @Rat_Patrol
                                  I too had my offset from CAD, but turns out, it's not correct, since tolerances make things imperfect. Put a paper on the Heatbed, and slowly and manually run the nozzle into it, leaving a tiny mark, and also mark where your bed Probe is. Now measure everything and use that.
                                  I had the same issue of thinking that mesh bed leveling was doing a bad job, until I remeasured my offset and realized I was off my 10mm.
                                    Phaedrux Moderator @Rat_Patrol
                                    You can increase the accuracy and repeatability of the BLTouch by tweaking those settings a bit.
                                    M558 P5 H5 F100 T6000 R0.5 A5
                                    G31 P25
                                    Then use this link to calibrate the trigger height and measure the X Y offset for the rest of G31.
                                    https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
                                      droftarts administrators @Phaedrux
                                      @Phaedrux said in How do I enable MESH leveling for the print?:
                                      G31 P25
                                      Donโ€™t you mean M558 P9 H5 F100 T6000 R0.5 A5 ?
                                        Phaedrux Moderator @droftarts
                                        @droftarts absolutely I did!
                                          Rat_Patrol
                                          Its not that the initial layer height is just wrong everywhere, some parts of the print have major squish and others are just fine.
                                            Rat_Patrol
                                            I did run through the BLTouch probe calibration procedure (ended up at 2.95mm IIRC). I designed my extruder carriage, so I just took the probe offset from the nozzle from Fusion, so it should be darned accurate.
