slant lines
@matt3o Have you got Pressure Advance enabled, or using volumetric extrusion? Try turning it off if you do.
This must be frustrating for you. I'm as puzzled as you. It seems you have taken great care in designing all aspects of your machine, and used good components.
Crazy stab in the dark question: are you using the same filament for all these prints that show this behaviour?
I guess, I don't know if it has been mentioned, you could look at temperature consistency, too.
@droftarts said in slant lines:
for all the tests I disabled PA and DA (not using volumetric extrusion)
@bot said in slant lines:
you can say it twice. Apart from that the printer is amazing and the dimensional accuracy is incredible, but this thing is driving me crazy. I'm going to reprint some parts with a tougher filament, see if that changes anything but I still believe the problem is in the extruder. I think I'm also gonna test a standard bondtech extruder.
nah, I tried 3 different PLA filaments, ABS and PETg. Doesn't seem to change much
Is your filament tensioner preloaded with a spring? I recently changed from spring tension to a fixed distance rigid mount for my hobbed gears (also bondtech) and the performance is dramatically better (more consistent).
my extruder has a spring, yes, but the flex3drive I started with is fixed and doesn't seem to change much. Thanks for your feedback anyway, it's something that I will certainly explore. I don't think it would solve this specific issue, but it's an easy enough mod to try
With flex3drive G5 + mellow -> got exactly the same lines. I changed 3 different extruder motors lines persist. Removed mellow and put e3dv6 and slant lines are gone. No clue why they were there, I never seen them before and I hope never to see them again.
It looks very much like the issue I had with my Nimble, periodic uneven extrusion. Something about the worm gear not engaging at the right angle.
If you print a cone or pyramid you should see some funny patterns instead of diagonal lines.
In my case it was probably related to that my mount was very slightly twisting the body of the extruder.
Have a look at https://drmrehorst.blogspot.com/2018/04/designing-low-cost-printable-worm-gear.html, or google "worm gear, periodic error, telescope" for more info on the topic.
@arhi said in slant lines:
I can certainly try with an e3d, but I'm on mosquito now... I hope it's not that with all that I spent for it
Thanks @bondus I'll check that too
@bondus it is gone now, that mellow is totally useless for PLA and that particular printer (ender5) I purchased to use mostly (only) for PLA. Thermal images I took show that it will never print PLA properly so I moved it to a drawer, will use it on some other printer for ABS/PC/Nylon, it did print those pretty nicely. So, I can't test the cone. Good idea none the less. I did have a failure right after I removed the mellow nf crazy hotend, the flex shaft broke, it is possible I had issues with flex shaft and that fix was that I replaced the flex shaft (luckily I have dual flex3shaft that I split into 2 single G5) and not that I replaced the hotend, but I'm not returning mellow back in to test that theory. I was using the 1st ever shaft flex3drive was testing, waiting for the replacement one to arrive that is supposed to be custom made, thicker and in many ways better than this old pre-release one I have, we'll see. It would be very hard for worm on G5 to not fully engage the drive gear, the part is very sturdy (I printed from PETG) and has bearings everywhere, but since shaft failed few cm from the gear I assume there was issue where shaft was bending so I designed a "tower" on my carriage to grab the flex shaft again few cm after the G5 .. lemme illustrate (ignore the mess of wires, that's still work in progress)
@matt3o said in slant lines:
Do not mistake mellow nf crazy hotend (that I used in this test) with mosquito, the only similarity between them is visual! Friend is using original with way worse setup than mine without a single issue with PLA and even without cooling My mellow experience got him scared so he added cooling but it worked even before forced cooling (you just can't go too crazy with retraction as with any all metal) so if you are rocking original mosquito don't worry. Also check out the vent from @smece (my neigbor who introduced me to duet2eth btw) about his mellow https://forum.duet3d.com/topic/14161/mellow-nf-crazy-hotend?_=1582807022109 again, none of those issues are visible on the original mosquito.
I recall similar issues with the zesty nimble being solved by changing the lubricant, I only looked into it since I recall some reports of flexible shaft having bad short lifespan on delta machines.
@lord-binky said in slant lines:
Do not get me started on the issues with zesty
I am using this dual flex3drive for a couple of years. It was designed together with the first flex3drive system, and I never had issues. I used 1.75 and 3.0 hexagon hotends with the dual flex3drive system. I dismantled that and made two single G5 ones as I'm going to use toolchanger for the multimaterial print. No need for complexities of leveling 2 hotends any more. No idea if this slanted lines came from failing flex shaft, mellow or something else. But replaced flex shaft (old thin one, new sturdier one is in post) and the hotend and lines are gone. I did replace also (but before the lines) stepper motor I wanted to use as I put there a 400steps/revolution stepper that had too much inductance so could not rotate fast enough. I'm not lubricating my flex3drive at all that is probably a mistake too.
@matt3o mhh, gates belt and pulleys should be fine, I use them too. Do you use gates pulleys as idler's. I do, maybe normal bearings could be responsible.
the problem is that I get those even when driving the g5 directly...
@CaiJonas said in slant lines:
yeah sorry, I use gates idlers and pulleys
Did you try different flow rates (different speeds, different layer height) that do not change the slanted lines?
I was so worried when I got them, and then they went away, now I fear they will come back if I don't know what exactly caused them.
yeah the slanted lines change based on speed and layer height, also steps/mm on the extruder.
@matt3o, I had once exact same pattern of slanted lines. That was when I was trying the Zesty Nimble (also a flex drive extruder). I ended up switching to a direct drive extruder (BMG + 150g motor + V6 hotend) and am very happy with the results.
YMMV.
Having looked at the links to worm gears, I am inclined to think that the slant lines are caused by uneven motion of the gear driven by the worm. In which case, the horizontal period of the lines should correspond to 1 rotation of the worm.
I am still convinced your slant lines are from the worm gear.
It is very similar to the z-wobble you can get when using a lead screw, but it acts on extrusion instead of z layer height.
If anything is mounted even very slightly off-angle or out of position you will get periodic small errors.
A long lead screw mounted too poorly will bind up and warn us, the small worm in our case will not. -
@dc42 @bondus how can you guy's explain then that they are gone on my printer and I did not change the worm gear? Exactly the same G5 is on my printer, I replaced the flex shaft (old one broke) and the hotend?
p.s. I'm digging through my plastic trash to find those pieces with slanted lines so I can measure them, I keep all my plastic trash so not an easy task but I'll get back when I do.
