    RepRapFirmware 3.01-RC3 released
    Beta Firmware
    22
    68
    4.3k
      droftarts administrators @imrj
      @imrj Did you see my post about fixing bossa on Mac OS? https://forum.duet3d.com/topic/11445/flashing-firmware-on-mac-os-x
      imrjundefined 1 Reply Last reply Reply Quote 0
      • imrjundefined
        imrj @droftarts
        @droftarts yea i did thanks, but by then i had already setup the DuetPi and got it working....but yea i will do this to my Macbook, but interestingly enough I did have brew already installed and using it for other things
          @imrj it's not just brew, you need to 'brew install wxwidgets'.
          • TurtlePrintundefined
            TurtlePrint
            When sending the M112 command the printer turns off and then starts the hot end fan "fan1" at full speed. I'm hoping to use the new daemon.g file to monitor a rotor stuck alarm wire on the hot end fan and send an M112 if its detected. So the fan continuing to spin after M112 is problematic if it's in a known stuck position.
            Printer is running:
            Duet2Wifi w/Duex5 running RRF RC3
            config.g snippet
            M950 F0 C"Fan0"						;Define the Parts Blower Fan connected to Fan0
            M106 P0 S0 C"Parts Blower" H-1 		;Name the fan, turn off thermistic control and turn the fan off if it was running
            M950 F1 C"Fan1"						;Define the Tool Fan connected to Fan1
            M106 P1 T40 H1						;Enable Thermostatic Control to turn fan on 40 degrees
            Edit: After some experimentation it appears that any fan with thermostatic control enabled is set to 100% after an M112 command. Is this the intended behavior?
            dc42undefined c310undefined 2 Replies Last reply Reply Quote 0
            • imrjundefined
              imrj @droftarts
              @droftarts ah ok got it, will do that
              • JuKuundefined
                JuKu
                M203 is set by mm/min, but reported back in mm/sec. (not a problem and as documented, just a bit odd. ?.)
                  dc42 administrators @TurtlePrint
                  @TurtlePrint said in RepRapFirmware 3.01-RC3 released:
                  If readings from the sensor that control the thermostatic fan are not available, the firmware assumes that whatever it is supposed to cool might be hot, so it turns the fan on.
                    There is a bug in the 3.01-RC3 firmware on Tool Boards. The symptom of this bug is that the motor doesn't move and M122 reports a large number of timeouts for Driver 0. I have put a fixed version of Duet3Firmware-TOOL1LC.bin at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0. Tool board users, please use this version until I release 3.01-RC4.
                    • arhiundefined
                      arhi
                      so far so good, duet2eth, one 6h print done flawlesly, second is 4h-38% in doing ok another 60% and change to go
                      • c310undefined
                        c310 @Danal
                        @Danal said in RepRapFirmware 3.01-RC3 released:
                        emergency stop
                        on duetwifi i have upgraded from 3.0 and emergency stop now does not work at all (was buggy in 3.0: printer stopped but did not reload itself, i was cycling power off-on to finish emergency stop cycle 🙂
                        current config
                        M950 J1 C"e1stop"
                        M581 P"e1stop" T0 C0
                        3.0 config was
                        M581 P"e1stop" T0
                        what should i fix ?
                          https://duet3d.dozuki.com/Wiki/Gcode#Section_M581_RepRapFirmware_3_01RC2_and_later
                          P is now the GPin pin number, so 1 in your case
                          c310undefined 1 Reply Last reply Reply Quote 0
                          • tobias_munichundefined
                            tobias_munich
                            strange behaviour with M505 alternative configuration folder
                            DUET3, SBC & RRF3 last release:
                            1. i made a alternative config folder M505 P"experimental". which is in /sys/experimental/ and worked with it
                            2. i stepped back to the normal /sys config
                            3. reset of the board only, no reboot of the sbc
                            4. I changed some values in /sys/bed.g
                            5. wondering because it didn't took the new values, the board uses still the file /sys/experimental/bed.g
                            is it necessary rebooting the sbc or restarting de DSF processes after changing the config path?
                            Hypercube-Evolution, Dual-Z, Nimble v2, Orion Piezo
                            Duet3, DuetWifi, Raspberry Pi 4, 7 inch HDMI Display, Panel-Due
                            Firmware: RepRapFirmware for Duet 3 MB6HC 'always the latest release'
                            • Schmartundefined
                              Schmart
                              Hi @dc42, I upgraded my firmware from 2.05 to 3.0 to 3.01-RC3 yesterday without any issues. The breaking changes are fortunately very manageable for me and I think this major update makes the configuration concept much more logical and consistent. Thanks for the huge effort you're putting in! I did notice though, that increasing the speed factor (e.g. M220 S150 or increasing the 'speed factor' slider in DWC) no longer works properly. After a few moves have passed, the speed seems to only change briefly (for one move if I have to guess) and intermittently; sometimes there's no observable change at all. It seems that the speed changes back nearly immediately to 100% again.
                              Creality CR-20 Pro with a Duet 2 Maestro, 3Dfused X+Z-axis rail kit, HIWIN-based DIY solution for the Y-axis, E3D Hemera, working ST7565 MiniPanel and various other small hardware improvements.
                              Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                Phaedrux Moderator @Schmart
                                @Schmart As of 3.01 RC2:
                                The speed factor (M220) is no longer applied to extruder-only moves or to movement commands in system or user macro files
                                Is that perhaps what you're seeing?
                                Schmartundefined 1 Reply Last reply Reply Quote 0
                                • Schmartundefined
                                  Schmart @Phaedrux
                                  Hi @Phaedrux, I indeed saw that comment in the release notes as well, and now wondering what 'extruder-only moves' actually constitutes. I'd expect that this would not include regular print moves such as G1 X3 Y3 E0.8 F1800 but retraction or derectract moves such as G10/G11 or G1 E-0.5. I'm definitely seeing this with regular print moves as well. I also noticed that when I set the speed factor to 150%, a reset to 100% slows the print speed down to 50-60% for one move only. I guess something's not adding up with the changes made to M220 recently.
                                    dc42 administrators @Schmart
                                    @Schmart said in RepRapFirmware 3.01-RC3 released:
                                    Seem odd. I ran several prints yesterday with the speed factor set at 50% or 65% and it was definitely working. But I set the speed factor with PanelDue, not DWC.
                                    If you run into this again, send M220 without parameters to see what speed factor is reported.
                                    Having thought about it, one instance where I think there is a problem is if the F parameter for a printing move just happens to match the F parameter for the preceding extruder-only move, and the slicer notices that and leave it out. In other words, if the slicer generated this:
                                    G1 E-5 F3000
                                    G1 X50 Y60 F3000 E1.0
                                    but the slicer noticed that the feed rate was the same for both moves and left out the F3000 on the second move, then the speed factor won't get applied to the second move. I'll fix this in RC4. You might like to check your GCode file to see if this situation is occurring.
                                    • c310undefined
                                      c310 @dc42
                                      @dc42 said in RepRapFirmware 3.01-RC3 released:
                                      i have tried for my emergency mushroom button
                                      M581 P1 T0 C0
                                      ..no luck... what should exact string be?
                                        dc42 administrators @c310
                                        @c310 said in RepRapFirmware 3.01-RC3 released:
                                        M581 P1 T0 C0
                                        That should work, provided that you still have this command before the M581:
                                        M950 J1 C"e1stop"
                                        The S0 or S1 option is still available in the M581 command.
                                        • Schmartundefined
                                          Schmart @dc42
                                          G1 E-5 F3000
                                          Hi @dc42, I've included the gcode of a full single layer of a test cube I've been printing. My slicer (both Supermerill's Slic3r++ and PrusaSlicer) generate code such as the following:
                                          ; Layer 6 at 1.4mm
                                          G10 ; retract
                                          G1 Z1.400 F9000.000
                                          ; printing object Shape-Box id:0 copy 0
                                          G1 X15.500 Y27.775
                                          G11 ; unretract
                                          G1 F1800.000
                                          G1 X3.225 Y27.775 E0.39472
                                          G1 X3.225 Y3.225 E0.78944
                                          G1 X27.775 Y3.225 E0.78944
                                          G1 X27.775 Y27.775 E0.78944
                                          G1 X15.560 Y27.775 E0.39279
                                          I'm doing print quality experiments with PETG and all print speeds consistently at 30mm/s. I don't know if the latter is a factor, but the slicer indeed decides to set a default feedrate for print moves and does not specify feed rates explicitly on every single G1. So I guess this fully corresponds with the scenario you've described where M220 wouldn't work properly yet?
                                          I'll also try to print something today and see what M220 is reporting back when I set a speed factor. Thanks!
                                            Thanks @Schmart, that explains it. I've made a change in RC4 that should fix it.
