    Duet Web Control 2.1.1 released
    Duet Web Control
    19
    51
    3.6k
    • mloidlundefined
      mloidl
      Just updated to DWC 2.1.1 and found out that the "Turn everything iff" - Button is not working. The following error is shown in the browser console.
      vue.runtime.esm.js:1888 TypeError: Cannot read property 'forEach' of undefined
          at ToolsPanel.vue:407
          at c (runtime.js:45)
          at Generator._invoke (runtime.js:274)
          at Generator.forEach.e.<computed> [as next] (runtime.js:97)
          at Dt (asyncToGenerator.js:3)
          at o (asyncToGenerator.js:25)
          at asyncToGenerator.js:32
          at new Promise (<anonymous>)
          at asyncToGenerator.js:21
          at o.turnEverythingOff (ToolsPanel.vue:399)
      Board: Duet WiFi 1.02 or later (duetwifi102)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.0 (2020-01-03b3)
      Duet WiFi Server Version: 1.23
      Regards,
      Martin
      • garyd9undefined
        garyd9
        @dc42 @chrishamm
        I'm not familiar with the object model, so I don't know if this is a bug with DWC 2.1.1 or a bug with RRF 3.0.1RC6 (on the duet3 board.)
        My part cooling fan is configured as:
        M950 F0 C"out3" Q15000
        M106 P0 C"berd-air" S0 H-1 L0.25 X0.6 B0
        The "X" parameter seems to be breaking something with DWC. It specifies that the max speed of the fan is 60%, and RRF (properly) modifies any S parameter to fit within that value. (So S128 would set an actual speed of 30%, S255 would set an actual speed of 60%)
        When the fan is turned on to "100%" (M106 S255 - which is actually 60%), my PanelDue properly shows that the fan is at 100% and I can change the value (which is properly scaled as described above.) However, when the fan set to 100% (S255), DWC's fan slider is showing 60%, and won't allow me to change the value. Neither the slider nor +/- buttons work. If gcode sets the fan to half power, the PanelDue properly shows "50%", but PanelDue is showing 30%.
        If it helps, M409 k"fans" has the following (partial) result when the fan is set to 100% (but limited via a X0.6 param)
        {"actualValue":0.60,"blip":0,"max":0.60,"min":0.25,"name":"berd-air","requestedValue":1.00,"rpm":-1,"thermostatic":{"heaters":[]}}
        So, my guess is that DWC is displaying the 'actualValue' instead of the 'requestedValue'. As for why I can't change the value from DWC, I have no clue.
        This worked properly with DWC 2.0.7.
        • smoki3undefined
          smoki3
          @chrishamm
          I noticed that M122 is broken in the Console. If I type a M122 nothing is displayed.
          On 2.0.7 it is working fine.
          • insertnamehereundefined
            insertnamehere
            I'm having a problem with the parts fan slider not being displayed on the Status page.
            I'm using a Berd-air pump as a parts fan connected to the E1 heater output. Previous versions showed the fan slider on the Status page. With with 2.1.1 it is no longer displayed.
            The config.sys line is:
            M950 F0 C"E1_HEAT" Q15000
            However, if I change M950 in config.sys to:
            M950 F0 C"FAN3" Q15000
            the fan slider is displayed correctly in 2.1.1
            smoki3undefined 1 Reply Last reply Reply Quote 0
            • smoki3undefined
              smoki3 @insertnamehere
              @insertnamehere I had this also on my duet 2. I now upgraded to RC6 and it is working fine
              insertnamehereundefined 1 Reply Last reply Reply Quote 0
              • hypnolobsterundefined
                hypnolobster
                I'm another with a fan thing happening. Using the laser/servo pwm with a blower on a Duet 3 for part cooling and the blower works as intended, but displays as 0 speed in DWC during a print.
                M950 F1 C"out9" Q25000
                M106 P1 C"Partcooling" S0 H-1 B0 X0.3
                • OwenDundefined
                  OwenD
                  With regard to the fan being missing form the DWC, I too found that initially.
                  However it was simply hidden and had to be re-selected for display.
                  It functions normally.
                  See progression shots.
                  Initial install
                  Click on "Change visibility"
                  Voila
                  hypnolobsterundefined 1 Reply Last reply Reply Quote 0
                    hypnolobster @OwenD
                    @OwenD Unfortunately that's not the issue, at least with those of using using slightly odder part cooling.
                    More information in general for what's happening specifically for me;
                    When I call a fan name in M106, the slider is in DWC while not printing, but doesn't actually do anything. When printing, the part cooling fan works as it should, but the slider sits at zero unless I touch it (and I do then have control), until the gcode changes the fan setting (at which point the slider stays where I put it and the fan changes to the speed the gcode called for). In this instance, the option for Tool Fan and the same fan as the name I've set in M106 are available.
                    If I remove the fan name from M106, it is not available while not printing at all (and neither is Tool Fan), but it otherwise functions the same during a print (Tool Fan becomes available).
                    If I run M106 P1 S0.5 while not in a print, it does work.
                    edit:
                    After updating to RC6, the functioning slider is back while not printing, but it's displaying the pre- X value set in M106. In my case, X0.3 and setting the fan slider at 50% will cause it to snap back to 15. Using the + and - buttons is sort of fruitless unless you click really fast.
                      insertnamehere @smoki3
                      @smoki3 said in Duet Web Control 2.1.1 released:
                      Thanks, I just needed to update to RC6 and it works now.
                      • PaulHewundefined
                        PaulHew
                        @chrishamm
                        Found this this morning.
                        'Turn Everything Off' does not do anything.
                        FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2020-01-03b3
                        GrodanBundefined 1 Reply Last reply Reply Quote 1
                        • chrishammundefined
                          chrishamm administrators @garyd9
                          @garyd9 @PaulHew Thanks for reporting these issues! I'll fix them in v2.1.2.
                          Duet software engineer
                          PaulHewundefined 1 Reply Last reply Reply Quote 0
                          • mikedahlgrenundefined
                            mikedahlgren
                            Ever since RC6 I have been getting disconnects and the following error from "Journalctl -f"
                            Apr 06 14:34:56 duet3 DuetControlServer[2170]: at DuetControlServer.Model.Updater.Run() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 140
                            Apr 06 14:34:56 duet3 DuetControlServer[2170]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux
                            Apr 06 14:34:57 duet3 DuetWebServer[551]: info: DuetWebServer.Controllers.WebSocketController[0]
                            Apr 06 14:34:57 duet3 DuetWebServer[551]: WebSocket disconnected from ::ffff:127.0.0.1:35260
                            Apr 06 14:34:57 duet3 DuetControlServer[2170]: [fatal] Update task faulted
                            Apr 06 14:34:57 duet3 DuetControlServer[2170]: System.ArgumentException: Requested value 'fault' was not found.
                            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Enum.TryParseByName(RuntimeType enumType, String originalValueString, ReadOnlySpan1 value, Boolean ignoreCase, Boolean throwOnFailure, UInt64& result) Apr 06 14:34:57 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2] Apr 06 14:34:57 duet3 DuetWebServer[551]: Executed action DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer) in 535.3719ms ^CApr 06 14:34:57 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1] Apr 06 14:34:57 duet3 DuetWebServer[551]: Executed endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)' Apr 06 14:34:57 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2] Apr 06 14:34:57 duet3 DuetWebServer[551]: Request finished in 540.9393ms 101 Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Enum.TryParseInt32Enum(RuntimeType enumType, String originalValueString, ReadOnlySpan1 value, Int32 minInclusive, Int32 maxInclusive, Boolean ignoreCase, Boolean throwOnFailure, TypeCode type, Int32& result)
                            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Enum.TryParse(Type enumType, String value, Boolean ignoreCase, Boolean throwOnFailure, Object& result)
                            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Enum.Parse(Type enumType, String value, Boolean ignoreCase)
                            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Utility.JsonLowerCaseStringEnumConverter.JsonLowerCaseStringEnumConverterInner1.Read(Utf8JsonReader& reader, Type typeToConvert, JsonSerializerOptions options) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Utility/JsonLowerCaseStringEnumConverter.cs:line 62 Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Text.Json.JsonPropertyInfoNullable2.OnRead(ReadStack& state, Utf8JsonReader& reader)
                            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Text.Json.JsonPropertyInfo.Read(JsonTokenType tokenType, ReadStack& state, Utf8JsonReader& reader)
                            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Text.Json.JsonSerializer.ReadCore(JsonSerializerOptions options, Utf8JsonReader& reader, ReadStack& readStack)
                            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Text.Json.JsonSerializer.ReadCore(Type returnType, JsonSerializerOptions options, Utf8JsonReader& reader)
                            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Text.Json.JsonSerializer.Deserialize(String json, Type returnType, JsonSerializerOptions options)
                            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 282
                            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Machine.ModelCollectionHelper.UpdateFromJson(IList list, Type itemType, JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelCollection.cs:line 227
                            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 264
                            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 248
                            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Machine.MachineModel.UpdateFromFirmwareModel(String key, JsonElement jsonElement) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/MachineModel.cs:line 134
                            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetControlServer.Model.Updater.Run() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 140
                              mikedahlgren
                              Apr 06 14:59:45 duet3 DuetControlServer[7457]: Duet Control Server v1.3.1
                              Apr 06 14:59:45 duet3 DuetControlServer[7457]: Written by Christian Hammacher for Duet3D
                              Apr 06 14:59:45 duet3 DuetControlServer[7457]: Licensed under the terms of the GNU Public License Version 3
                              Apr 06 14:59:46 duet3 DuetControlServer[7457]: [info] Settings loaded
                              Apr 06 14:59:46 duet3 DuetControlServer[7457]: [info] Environment initialized
                              Apr 06 14:59:46 duet3 DuetControlServer[7457]: [info] Connection to Duet established
                              Apr 06 14:59:46 duet3 DuetControlServer[7457]: [info] IPC socket created at /var/run/dsf/dcs.sock
                              Apr 06 14:59:47 duet3 DuetControlServer[7457]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux
                              Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Hosting.Diagnostics[1]
                              Apr 06 14:59:47 duet3 DuetWebServer[551]: Request starting HTTP/1.1 GET http://duet3/machine
                              Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[0]
                              Apr 06 14:59:47 duet3 DuetWebServer[551]: Executing endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)'
                              Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[3]
                              Apr 06 14:59:47 duet3 DuetWebServer[551]: Route matched with {action = "Get", controller = "WebSocket"}. Executing controller action with signature System.Threading.Tasks.Task Get() on controller DuetWebServer.Controllers.WebSocketController (DuetWebServer).
                              Apr 06 14:59:47 duet3 DuetControlServer[7457]: [fatal] Abnormal program termination
                              Apr 06 14:59:47 duet3 DuetWebServer[551]: info: DuetWebServer.Controllers.WebSocketController[0]
                              Apr 06 14:59:47 duet3 DuetWebServer[551]: WebSocket connected from ::ffff:127.0.0.1:36822
                              Apr 06 14:59:47 duet3 DuetControlServer[7457]: [fatal] Update task faulted
                              Apr 06 14:59:47 duet3 DuetControlServer[7457]: System.ArgumentException: Requested value 'fault' was not found.
                              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Enum.TryParseByName(RuntimeType enumType, String originalValueString, ReadOnlySpan1 value, Boolean ignoreCase, Boolean throwOnFailure, UInt64& result) Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Enum.TryParseInt32Enum(RuntimeType enumType, String originalValueString, ReadOnlySpan1 value, Int32 minInclusive, Int32 maxInclusive, Boolean ignoreCase, Boolean throwOnFailure, TypeCode type, Int32& result)
                              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Enum.TryParse(Type enumType, String value, Boolean ignoreCase, Boolean throwOnFailure, Object& result)
                              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Enum.Parse(Type enumType, String value, Boolean ignoreCase)
                              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Utility.JsonLowerCaseStringEnumConverter.JsonLowerCaseStringEnumConverterInner1.Read(Utf8JsonReader& reader, Type typeToConvert, JsonSerializerOptions options) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Utility/JsonLowerCaseStringEnumConverter.cs:line 62 Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Text.Json.JsonPropertyInfoNullable2.OnRead(ReadStack& state, Utf8JsonReader& reader)
                              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Text.Json.JsonPropertyInfo.Read(JsonTokenType tokenType, ReadStack& state, Utf8JsonReader& reader)
                              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Text.Json.JsonSerializer.ReadCore(JsonSerializerOptions options, Utf8JsonReader& reader, ReadStack& readStack)
                              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Text.Json.JsonSerializer.ReadCore(Type returnType, JsonSerializerOptions options, Utf8JsonReader& reader)
                              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Text.Json.JsonSerializer.Deserialize(String json, Type returnType, JsonSerializerOptions options)
                              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 282
                              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Machine.ModelCollectionHelper.UpdateFromJson(IList list, Type itemType, JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelCollection.cs:line 227
                              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 264
                              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 248
                              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Machine.MachineModel.UpdateFromFirmwareModel(String key, JsonElement jsonElement) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/MachineModel.cs:line 134
                              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetControlServer.Model.Updater.Run() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 140
                              Apr 06 14:59:47 duet3 DuetWebServer[551]: WebSocket disconnected from ::ffff:127.0.0.1:36822
                              Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2]
                              Apr 06 14:59:47 duet3 DuetWebServer[551]: Executed action DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer) in 374.0239ms
                              Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1]
                              Apr 06 14:59:47 duet3 DuetWebServer[551]: Executed endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)'
                              Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2]
                              Apr 06 14:59:47 duet3 DuetWebServer[551]: Request finished in 374.9353ms 101
                              • PaulHewundefined
                                PaulHew @chrishamm
                                @chrishamm And fan sliders do not work or indicate current speed.
                                Sorry.
                                • DocTruckerundefined
                                  DocTrucker
                                  Version 2.0.7 ran fine on v0.6 and v0.8.5 boards. Is version 2.1+ dependant on using RepRapFirmware 2+ or 3+?
                                    jay_s_uk @DocTrucker
                                    @DocTrucker
                                    Its dependant on RRF3.01+ as it uses the object model
                                      DocTrucker @jay_s_uk
                                      @jay_s_uk cheers, that's what I expected but I wasn't sure if it used the object model it available, or exclusively. From what you say it is the latter.
                                      • GrodanBundefined
                                        GrodanB @PaulHew
                                        @PaulHew said in Duet Web Control 2.1.1 released:
                                        @chrishamm
                                        Also strange is that with a dual set-up the loaded filament is moved from T1 to T0 and cannot be unloaded.
                                        (To be clear, T1 has a filament loaded, I do a pause, then immediately a cancel and suddenly T0 is loaded with T1 filament and that cannot be loaded to T1 again and T0 does not what to unload it. Temp settings is still on as espected on T1 (old temp) and t0 also as before...)
                                        I had to delete the file "filaments.csv" and do a "EMERGENCY STOP" to get T0 to relese the T1 filament...
                                        I think this happen when I cancel a print...
                                        Which I do a lot since I try to get my filament to stick.
                                        Would be nice to be able to cancel directly and not need to pause and then cancel...
                                        This time I do not see the "filament.csv" so I pray to god that a power on of cycle get my printer back...
                                        I did... the file was not shown until I made a power on/off cycle.
                                        That would be nice if it did.
                                        I also do not understand why the file "filament.csv" kept after a power cycle? At least a forced unload feature would be useful...
                                        • GrodanBundefined
                                          GrodanB
                                          For some reason I cannot change the wording mistake I did above (someServer.com identified post as spam)
                                          So a power OFF/ON did work...
                                          • smoki3undefined
                                            smoki3
                                            Is M122 working for someone?
                                            SIamundefined 1 Reply Last reply Reply Quote 0
