    Duet Web Control 2.1.1 released
    Duet Web Control
    19
    51
    3.5k
    • insertnamehereundefined
      insertnamehere @smoki3
      @smoki3 said in Duet Web Control 2.1.1 released:
      @insertnamehere I had this also on my duet 2. I now upgraded to RC6 and it is working fine
      Thanks, I just needed to update to RC6 and it works now.
      • PaulHewundefined
        PaulHew
        @chrishamm
        Found this this morning.
        'Turn Everything Off' does not do anything.
        FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2020-01-03b3
        GrodanBundefined 1 Reply Last reply Reply Quote 1
        • chrishammundefined
          chrishamm administrators @garyd9
          @garyd9 @PaulHew Thanks for reporting these issues! I'll fix them in v2.1.2.
          Duet software engineer
          PaulHewundefined 1 Reply Last reply Reply Quote 0
          • mikedahlgrenundefined
            mikedahlgren
            Ever since RC6 I have been getting disconnects and the following error from "Journalctl -f"
            Apr 06 14:34:56 duet3 DuetControlServer[2170]: at DuetControlServer.Model.Updater.Run() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 140
            Apr 06 14:34:56 duet3 DuetControlServer[2170]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux
            Apr 06 14:34:57 duet3 DuetWebServer[551]: info: DuetWebServer.Controllers.WebSocketController[0]
            Apr 06 14:34:57 duet3 DuetWebServer[551]: WebSocket disconnected from ::ffff:127.0.0.1:35260
            Apr 06 14:34:57 duet3 DuetControlServer[2170]: [fatal] Update task faulted
            Apr 06 14:34:57 duet3 DuetControlServer[2170]: System.ArgumentException: Requested value 'fault' was not found.
            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Enum.TryParseByName(RuntimeType enumType, String originalValueString, ReadOnlySpan1 value, Boolean ignoreCase, Boolean throwOnFailure, UInt64& result) Apr 06 14:34:57 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2] Apr 06 14:34:57 duet3 DuetWebServer[551]: Executed action DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer) in 535.3719ms ^CApr 06 14:34:57 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1] Apr 06 14:34:57 duet3 DuetWebServer[551]: Executed endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)' Apr 06 14:34:57 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2] Apr 06 14:34:57 duet3 DuetWebServer[551]: Request finished in 540.9393ms 101 Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Enum.TryParseInt32Enum(RuntimeType enumType, String originalValueString, ReadOnlySpan1 value, Int32 minInclusive, Int32 maxInclusive, Boolean ignoreCase, Boolean throwOnFailure, TypeCode type, Int32& result)
            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Enum.TryParse(Type enumType, String value, Boolean ignoreCase, Boolean throwOnFailure, Object& result)
            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Enum.Parse(Type enumType, String value, Boolean ignoreCase)
            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Utility.JsonLowerCaseStringEnumConverter.JsonLowerCaseStringEnumConverterInner1.Read(Utf8JsonReader& reader, Type typeToConvert, JsonSerializerOptions options) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Utility/JsonLowerCaseStringEnumConverter.cs:line 62 Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Text.Json.JsonPropertyInfoNullable2.OnRead(ReadStack& state, Utf8JsonReader& reader)
            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Text.Json.JsonPropertyInfo.Read(JsonTokenType tokenType, ReadStack& state, Utf8JsonReader& reader)
            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Text.Json.JsonSerializer.ReadCore(JsonSerializerOptions options, Utf8JsonReader& reader, ReadStack& readStack)
            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Text.Json.JsonSerializer.ReadCore(Type returnType, JsonSerializerOptions options, Utf8JsonReader& reader)
            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Text.Json.JsonSerializer.Deserialize(String json, Type returnType, JsonSerializerOptions options)
            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 282
            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Machine.ModelCollectionHelper.UpdateFromJson(IList list, Type itemType, JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelCollection.cs:line 227
            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 264
            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 248
            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Machine.MachineModel.UpdateFromFirmwareModel(String key, JsonElement jsonElement) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/MachineModel.cs:line 134
            Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetControlServer.Model.Updater.Run() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 140
              mikedahlgren
              Apr 06 14:59:45 duet3 DuetControlServer[7457]: Duet Control Server v1.3.1
              Apr 06 14:59:45 duet3 DuetControlServer[7457]: Written by Christian Hammacher for Duet3D
              Apr 06 14:59:45 duet3 DuetControlServer[7457]: Licensed under the terms of the GNU Public License Version 3
              Apr 06 14:59:46 duet3 DuetControlServer[7457]: [info] Settings loaded
              Apr 06 14:59:46 duet3 DuetControlServer[7457]: [info] Environment initialized
              Apr 06 14:59:46 duet3 DuetControlServer[7457]: [info] Connection to Duet established
              Apr 06 14:59:46 duet3 DuetControlServer[7457]: [info] IPC socket created at /var/run/dsf/dcs.sock
              Apr 06 14:59:47 duet3 DuetControlServer[7457]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux
              Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Hosting.Diagnostics[1]
              Apr 06 14:59:47 duet3 DuetWebServer[551]: Request starting HTTP/1.1 GET http://duet3/machine
              Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[0]
              Apr 06 14:59:47 duet3 DuetWebServer[551]: Executing endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)'
              Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[3]
              Apr 06 14:59:47 duet3 DuetWebServer[551]: Route matched with {action = "Get", controller = "WebSocket"}. Executing controller action with signature System.Threading.Tasks.Task Get() on controller DuetWebServer.Controllers.WebSocketController (DuetWebServer).
              Apr 06 14:59:47 duet3 DuetControlServer[7457]: [fatal] Abnormal program termination
              Apr 06 14:59:47 duet3 DuetWebServer[551]: info: DuetWebServer.Controllers.WebSocketController[0]
              Apr 06 14:59:47 duet3 DuetWebServer[551]: WebSocket connected from ::ffff:127.0.0.1:36822
              Apr 06 14:59:47 duet3 DuetControlServer[7457]: [fatal] Update task faulted
              Apr 06 14:59:47 duet3 DuetControlServer[7457]: System.ArgumentException: Requested value 'fault' was not found.
              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Enum.TryParseByName(RuntimeType enumType, String originalValueString, ReadOnlySpan1 value, Boolean ignoreCase, Boolean throwOnFailure, UInt64& result) Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Enum.TryParseInt32Enum(RuntimeType enumType, String originalValueString, ReadOnlySpan1 value, Int32 minInclusive, Int32 maxInclusive, Boolean ignoreCase, Boolean throwOnFailure, TypeCode type, Int32& result)
              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Enum.TryParse(Type enumType, String value, Boolean ignoreCase, Boolean throwOnFailure, Object& result)
              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Enum.Parse(Type enumType, String value, Boolean ignoreCase)
              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Utility.JsonLowerCaseStringEnumConverter.JsonLowerCaseStringEnumConverterInner1.Read(Utf8JsonReader& reader, Type typeToConvert, JsonSerializerOptions options) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Utility/JsonLowerCaseStringEnumConverter.cs:line 62 Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Text.Json.JsonPropertyInfoNullable2.OnRead(ReadStack& state, Utf8JsonReader& reader)
              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Text.Json.JsonPropertyInfo.Read(JsonTokenType tokenType, ReadStack& state, Utf8JsonReader& reader)
              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Text.Json.JsonSerializer.ReadCore(JsonSerializerOptions options, Utf8JsonReader& reader, ReadStack& readStack)
              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Text.Json.JsonSerializer.ReadCore(Type returnType, JsonSerializerOptions options, Utf8JsonReader& reader)
              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Text.Json.JsonSerializer.Deserialize(String json, Type returnType, JsonSerializerOptions options)
              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 282
              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Machine.ModelCollectionHelper.UpdateFromJson(IList list, Type itemType, JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelCollection.cs:line 227
              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 264
              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 248
              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Machine.MachineModel.UpdateFromFirmwareModel(String key, JsonElement jsonElement) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/MachineModel.cs:line 134
              Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetControlServer.Model.Updater.Run() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 140
              Apr 06 14:59:47 duet3 DuetWebServer[551]: WebSocket disconnected from ::ffff:127.0.0.1:36822
              Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2]
              Apr 06 14:59:47 duet3 DuetWebServer[551]: Executed action DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer) in 374.0239ms
              Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1]
              Apr 06 14:59:47 duet3 DuetWebServer[551]: Executed endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)'
              Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2]
              Apr 06 14:59:47 duet3 DuetWebServer[551]: Request finished in 374.9353ms 101
              • PaulHewundefined
                PaulHew @chrishamm
                @chrishamm And fan sliders do not work or indicate current speed.
                Sorry.
                • DocTruckerundefined
                  DocTrucker
                  Version 2.0.7 ran fine on v0.6 and v0.8.5 boards. Is version 2.1+ dependant on using RepRapFirmware 2+ or 3+?
                    jay_s_uk @DocTrucker
                    @DocTrucker
                    Its dependant on RRF3.01+ as it uses the object model
                      DocTrucker @jay_s_uk
                      @jay_s_uk cheers, that's what I expected but I wasn't sure if it used the object model it available, or exclusively. From what you say it is the latter.
                      • GrodanBundefined
                        GrodanB @PaulHew
                        @PaulHew said in Duet Web Control 2.1.1 released:
                        @chrishamm
                        Also strange is that with a dual set-up the loaded filament is moved from T1 to T0 and cannot be unloaded.
                        (To be clear, T1 has a filament loaded, I do a pause, then immediately a cancel and suddenly T0 is loaded with T1 filament and that cannot be loaded to T1 again and T0 does not what to unload it. Temp settings is still on as espected on T1 (old temp) and t0 also as before...)
                        I had to delete the file "filaments.csv" and do a "EMERGENCY STOP" to get T0 to relese the T1 filament...
                        I think this happen when I cancel a print...
                        Which I do a lot since I try to get my filament to stick.
                        Would be nice to be able to cancel directly and not need to pause and then cancel...
                        This time I do not see the "filament.csv" so I pray to god that a power on of cycle get my printer back...
                        I did... the file was not shown until I made a power on/off cycle.
                        That would be nice if it did.
                        I also do not understand why the file "filament.csv" kept after a power cycle? At least a forced unload feature would be useful...
                        • GrodanBundefined
                          GrodanB
                          For some reason I cannot change the wording mistake I did above (someServer.com identified post as spam)
                          So a power OFF/ON did work...
                          • smoki3undefined
                            smoki3
                            Is M122 working for someone?
                            SIamundefined 1 Reply Last reply Reply Quote 0
                              Thanks, I've already fixed the crash that occurs when a heater fault occurs and I'll fix the filament assignment next. Both fixes will be available when RRF 3.01 is released. Likewise the "Turn off all" button has been fixed and a new DWC version will be released among the next DSF version.
                              GrodanBundefined 1 Reply Last reply Reply Quote 0
                              • SIamundefined
                                SIam @smoki3
                                @smoki3
                                M122 is working here
                                6.4.2020, 20:32:50 	m122
                                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC6 running on Duet WiFi 1.02 or later + DueX5
                                Board ID: 08DGM-95BNL-MGPSJ-6J9FD-3SJ6N-K1W3Y
                                Used output buffers: 4 of 24 (22 max)
                                Static ram: 28052
                                Dynamic ram: 94208 of which 24 recycled
                                Exception stack ram used: 576
                                Never used ram: 8212
                                Tasks: NETWORK(ready,116) HEAT(blocked,1244) DUEX(suspended,136) MAIN(running,1608) IDLE(ready,80)
                                Owned mutexes: WiFi(NETWORK)
                                Last reset 11:14:43 ago, cause: software
                                Last software reset at 2020-04-06 09:18, reason: User, spinning module GCodes, available RAM 8532 bytes (slot 3)
                                Error status: 0
                                Free file entries: 10
                                SD card longest block write time: 133.8ms, max retries 0
                                MCU temperature: min 21.7, current 39.7, max 41.7
                                Supply voltage: min 24.0, current 24.3, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
                                Driver 0: standstill, SG min/max 0/981
                                Driver 1: standstill, SG min/max 0/1023
                                Driver 2: standstill, SG min/max 0/1023
                                Driver 3: standstill, SG min/max 0/1023
                                Driver 4: standstill, SG min/max 0/1023
                                Driver 5: standstill, SG min/max not available
                                Driver 6: standstill, SG min/max not available
                                Driver 7: standstill, SG min/max not available
                                Driver 9: standstill, SG min/max 0/1023
                                Date/time: 2020-04-06 20:32:48
                                Slowest loop: 312.35ms; fastest: 0.12ms
                                Hiccups: 0(0), FreeDm: 169, MinFreeDm: 107, MaxWait: 5922743ms
                                === MainDDARing ===
                                === AuxDDARing ===
                                Heater 0 is on, I-accum = 0.0
                                Heater 1 is on, I-accum = 0.7
                                Segments left: 0
                                Movement lock held by null
                                HTTP is idle in state(s) 0
                                Telnet is idle in state(s) 0
                                File is idle in state(s) 0
                                USB is idle in state(s) 0
                                Aux is idle in state(s) 0
                                Trigger is idle in state(s) 0
                                Queue is idle in state(s) 0
                                Daemon is idle in state(s) 0
                                Code queue is empty.
                                === Network ===
                                Slowest loop: 789.12ms; fastest: 0.00ms
                                Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(2) FTP(0) Telnet(0)
                                HTTP sessions: 2 of 8
                                - WiFi -
                                Network state is active
                                WiFi firmware version 1.23
                                WiFi MAC address 2c:3a:e8:0b:06:33
                                WiFi Vcc 3.44, reset reason Unknown
                                WiFi flash size 4194304, free heap 15424
                                WiFi IP address 192.168.188.36
                                WiFi signal strength -49dBm, reconnections 0, sleep mode modem
                                Socket states: 4 0 0 4 0 0 0 0
                                === Filament sensors ===
                                Extruder 0 sensor: ok
                                Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                                RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                                Duet WiFi Server: 1.26
                                Duet Web Control 3.4.0beta4 (2021-09-27)
                                smoki3undefined 1 Reply Last reply Reply Quote 0
                                • GrodanBundefined
                                  GrodanB @chrishamm
                                  @chrishamm said in Duet Web Control 2.1.1 released:
                                  Great, by the way, great work. Much appreciated.
                                  Do you require me to upgrade to RRF 3.01? Do not see the benefit to me until new functions are added at the moment I understand that soon it will be at the same function level as latest 2.x.
                                  Again thanks.
                                    DocTrucker @GrodanB
                                    @GrodanB said in Duet Web Control 2.1.1 released:
                                    @jay_s_uk said in Duet Web Control 2.1.1 released:
                                    • smoki3undefined
                                      smoki3 @SIam
                                      @SIam said in Duet Web Control 2.1.1 released:
                                      @smoki3
                                      Static ram: 28052
                                      Error status: 0
                                      === MainDDARing ===
                                      === AuxDDARing ===
                                      Segments left: 0
                                      === Network ===
                                      - WiFi -
                                      I just get this without an output. Are you on Duet 2 Wifi?
                                      jay_s_ukundefined SIamundefined smoki3undefined 3 Replies Last reply Reply Quote 0
                                        jay_s_uk @smoki3
                                        @smoki3
                                        i get full M122 output on a duet 3 + pi and a duet 2 ethernet
                                        • wilrikerundefined
                                          wilriker
                                          @jay_s_uk @DocTrucker @GrodanB DWC 2.1.1 is supposed to work with RRF versions pre-ObjectModel. Unfortunately, currently there is a bug in the code that prevents it to get into legacy-mode.
                                          Manuel
                                          My Tool Collection
                                          jay_s_ukundefined chrishammundefined GrodanBundefined 3 Replies Last reply Reply Quote 1
                                          • SIamundefined
                                            SIam @smoki3
                                            @smoki3
                                            Yes i use duet wifi
