    Duet Web Control 2.1.1 released
    Duet Web Control
    19
    51
    3.6k
    • smoki3undefined
      smoki3
      @chrishamm
      I noticed that M122 is broken in the Console. If I type a M122 nothing is displayed.
      On 2.0.7 it is working fine.
      • insertnamehereundefined
        insertnamehere
        I'm having a problem with the parts fan slider not being displayed on the Status page.
        I'm using a Berd-air pump as a parts fan connected to the E1 heater output. Previous versions showed the fan slider on the Status page. With with 2.1.1 it is no longer displayed.
        The config.sys line is:
        M950 F0 C"E1_HEAT" Q15000
        However, if I change M950 in config.sys to:
        M950 F0 C"FAN3" Q15000
        the fan slider is displayed correctly in 2.1.1
        smoki3undefined 1 Reply Last reply Reply Quote 0
        • smoki3undefined
          smoki3 @insertnamehere
          @insertnamehere I had this also on my duet 2. I now upgraded to RC6 and it is working fine
          insertnamehereundefined 1 Reply Last reply Reply Quote 0
          • hypnolobsterundefined
            hypnolobster
            I'm another with a fan thing happening. Using the laser/servo pwm with a blower on a Duet 3 for part cooling and the blower works as intended, but displays as 0 speed in DWC during a print.
            M950 F1 C"out9" Q25000
            M106 P1 C"Partcooling" S0 H-1 B0 X0.3
            • OwenDundefined
              OwenD
              With regard to the fan being missing form the DWC, I too found that initially.
              However it was simply hidden and had to be re-selected for display.
              It functions normally.
              See progression shots.
              Initial install
              Click on "Change visibility"
              Voila
              hypnolobsterundefined 1 Reply Last reply Reply Quote 0
                hypnolobster @OwenD
                @OwenD Unfortunately that's not the issue, at least with those of using using slightly odder part cooling.
                More information in general for what's happening specifically for me;
                When I call a fan name in M106, the slider is in DWC while not printing, but doesn't actually do anything. When printing, the part cooling fan works as it should, but the slider sits at zero unless I touch it (and I do then have control), until the gcode changes the fan setting (at which point the slider stays where I put it and the fan changes to the speed the gcode called for). In this instance, the option for Tool Fan and the same fan as the name I've set in M106 are available.
                If I remove the fan name from M106, it is not available while not printing at all (and neither is Tool Fan), but it otherwise functions the same during a print (Tool Fan becomes available).
                If I run M106 P1 S0.5 while not in a print, it does work.
                edit:
                After updating to RC6, the functioning slider is back while not printing, but it's displaying the pre- X value set in M106. In my case, X0.3 and setting the fan slider at 50% will cause it to snap back to 15. Using the + and - buttons is sort of fruitless unless you click really fast.
                  insertnamehere @smoki3
                  @smoki3 said in Duet Web Control 2.1.1 released:
                  Thanks, I just needed to update to RC6 and it works now.
                  • PaulHewundefined
                    PaulHew
                    @chrishamm
                    Found this this morning.
                    'Turn Everything Off' does not do anything.
                    FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2020-01-03b3
                    GrodanBundefined 1 Reply Last reply Reply Quote 1
                    • chrishammundefined
                      chrishamm administrators @garyd9
                      @garyd9 @PaulHew Thanks for reporting these issues! I'll fix them in v2.1.2.
                      Duet software engineer
                      PaulHewundefined 1 Reply Last reply Reply Quote 0
                      • mikedahlgrenundefined
                        mikedahlgren
                        Ever since RC6 I have been getting disconnects and the following error from "Journalctl -f"
                        Apr 06 14:34:56 duet3 DuetControlServer[2170]: at DuetControlServer.Model.Updater.Run() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 140
                        Apr 06 14:34:56 duet3 DuetControlServer[2170]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux
                        Apr 06 14:34:57 duet3 DuetWebServer[551]: info: DuetWebServer.Controllers.WebSocketController[0]
                        Apr 06 14:34:57 duet3 DuetWebServer[551]: WebSocket disconnected from ::ffff:127.0.0.1:35260
                        Apr 06 14:34:57 duet3 DuetControlServer[2170]: [fatal] Update task faulted
                        Apr 06 14:34:57 duet3 DuetControlServer[2170]: System.ArgumentException: Requested value 'fault' was not found.
                        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Enum.TryParseByName(RuntimeType enumType, String originalValueString, ReadOnlySpan1 value, Boolean ignoreCase, Boolean throwOnFailure, UInt64& result) Apr 06 14:34:57 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2] Apr 06 14:34:57 duet3 DuetWebServer[551]: Executed action DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer) in 535.3719ms ^CApr 06 14:34:57 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1] Apr 06 14:34:57 duet3 DuetWebServer[551]: Executed endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)' Apr 06 14:34:57 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2] Apr 06 14:34:57 duet3 DuetWebServer[551]: Request finished in 540.9393ms 101 Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Enum.TryParseInt32Enum(RuntimeType enumType, String originalValueString, ReadOnlySpan1 value, Int32 minInclusive, Int32 maxInclusive, Boolean ignoreCase, Boolean throwOnFailure, TypeCode type, Int32& result)
                        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Enum.TryParse(Type enumType, String value, Boolean ignoreCase, Boolean throwOnFailure, Object& result)
                        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Enum.Parse(Type enumType, String value, Boolean ignoreCase)
                        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Utility.JsonLowerCaseStringEnumConverter.JsonLowerCaseStringEnumConverterInner1.Read(Utf8JsonReader& reader, Type typeToConvert, JsonSerializerOptions options) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Utility/JsonLowerCaseStringEnumConverter.cs:line 62 Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Text.Json.JsonPropertyInfoNullable2.OnRead(ReadStack& state, Utf8JsonReader& reader)
                        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Text.Json.JsonPropertyInfo.Read(JsonTokenType tokenType, ReadStack& state, Utf8JsonReader& reader)
                        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Text.Json.JsonSerializer.ReadCore(JsonSerializerOptions options, Utf8JsonReader& reader, ReadStack& readStack)
                        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Text.Json.JsonSerializer.ReadCore(Type returnType, JsonSerializerOptions options, Utf8JsonReader& reader)
                        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Text.Json.JsonSerializer.Deserialize(String json, Type returnType, JsonSerializerOptions options)
                        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 282
                        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Machine.ModelCollectionHelper.UpdateFromJson(IList list, Type itemType, JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelCollection.cs:line 227
                        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 264
                        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 248
                        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Machine.MachineModel.UpdateFromFirmwareModel(String key, JsonElement jsonElement) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/MachineModel.cs:line 134
                        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetControlServer.Model.Updater.Run() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 140
                          mikedahlgren
                          Apr 06 14:59:45 duet3 DuetControlServer[7457]: Duet Control Server v1.3.1
                          Apr 06 14:59:45 duet3 DuetControlServer[7457]: Written by Christian Hammacher for Duet3D
                          Apr 06 14:59:45 duet3 DuetControlServer[7457]: Licensed under the terms of the GNU Public License Version 3
                          Apr 06 14:59:46 duet3 DuetControlServer[7457]: [info] Settings loaded
                          Apr 06 14:59:46 duet3 DuetControlServer[7457]: [info] Environment initialized
                          Apr 06 14:59:46 duet3 DuetControlServer[7457]: [info] Connection to Duet established
                          Apr 06 14:59:46 duet3 DuetControlServer[7457]: [info] IPC socket created at /var/run/dsf/dcs.sock
                          Apr 06 14:59:47 duet3 DuetControlServer[7457]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux
                          Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Hosting.Diagnostics[1]
                          Apr 06 14:59:47 duet3 DuetWebServer[551]: Request starting HTTP/1.1 GET http://duet3/machine
                          Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[0]
                          Apr 06 14:59:47 duet3 DuetWebServer[551]: Executing endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)'
                          Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[3]
                          Apr 06 14:59:47 duet3 DuetWebServer[551]: Route matched with {action = "Get", controller = "WebSocket"}. Executing controller action with signature System.Threading.Tasks.Task Get() on controller DuetWebServer.Controllers.WebSocketController (DuetWebServer).
                          Apr 06 14:59:47 duet3 DuetControlServer[7457]: [fatal] Abnormal program termination
                          Apr 06 14:59:47 duet3 DuetWebServer[551]: info: DuetWebServer.Controllers.WebSocketController[0]
                          Apr 06 14:59:47 duet3 DuetWebServer[551]: WebSocket connected from ::ffff:127.0.0.1:36822
                          Apr 06 14:59:47 duet3 DuetControlServer[7457]: [fatal] Update task faulted
                          Apr 06 14:59:47 duet3 DuetControlServer[7457]: System.ArgumentException: Requested value 'fault' was not found.
                          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Enum.TryParseByName(RuntimeType enumType, String originalValueString, ReadOnlySpan1 value, Boolean ignoreCase, Boolean throwOnFailure, UInt64& result) Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Enum.TryParseInt32Enum(RuntimeType enumType, String originalValueString, ReadOnlySpan1 value, Int32 minInclusive, Int32 maxInclusive, Boolean ignoreCase, Boolean throwOnFailure, TypeCode type, Int32& result)
                          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Enum.TryParse(Type enumType, String value, Boolean ignoreCase, Boolean throwOnFailure, Object& result)
                          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Enum.Parse(Type enumType, String value, Boolean ignoreCase)
                          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Utility.JsonLowerCaseStringEnumConverter.JsonLowerCaseStringEnumConverterInner1.Read(Utf8JsonReader& reader, Type typeToConvert, JsonSerializerOptions options) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Utility/JsonLowerCaseStringEnumConverter.cs:line 62 Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Text.Json.JsonPropertyInfoNullable2.OnRead(ReadStack& state, Utf8JsonReader& reader)
                          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Text.Json.JsonPropertyInfo.Read(JsonTokenType tokenType, ReadStack& state, Utf8JsonReader& reader)
                          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Text.Json.JsonSerializer.ReadCore(JsonSerializerOptions options, Utf8JsonReader& reader, ReadStack& readStack)
                          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Text.Json.JsonSerializer.ReadCore(Type returnType, JsonSerializerOptions options, Utf8JsonReader& reader)
                          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Text.Json.JsonSerializer.Deserialize(String json, Type returnType, JsonSerializerOptions options)
                          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 282
                          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Machine.ModelCollectionHelper.UpdateFromJson(IList list, Type itemType, JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelCollection.cs:line 227
                          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 264
                          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 248
                          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Machine.MachineModel.UpdateFromFirmwareModel(String key, JsonElement jsonElement) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/MachineModel.cs:line 134
                          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetControlServer.Model.Updater.Run() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 140
                          Apr 06 14:59:47 duet3 DuetWebServer[551]: WebSocket disconnected from ::ffff:127.0.0.1:36822
                          Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2]
                          Apr 06 14:59:47 duet3 DuetWebServer[551]: Executed action DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer) in 374.0239ms
                          Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1]
                          Apr 06 14:59:47 duet3 DuetWebServer[551]: Executed endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)'
                          Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2]
                          Apr 06 14:59:47 duet3 DuetWebServer[551]: Request finished in 374.9353ms 101
                          • PaulHewundefined
                            PaulHew @chrishamm
                            @chrishamm And fan sliders do not work or indicate current speed.
                            Sorry.
                            • DocTruckerundefined
                              DocTrucker
                              Version 2.0.7 ran fine on v0.6 and v0.8.5 boards. Is version 2.1+ dependant on using RepRapFirmware 2+ or 3+?
                                jay_s_uk @DocTrucker
                                @DocTrucker
                                Its dependant on RRF3.01+ as it uses the object model
                                  DocTrucker @jay_s_uk
                                  @jay_s_uk cheers, that's what I expected but I wasn't sure if it used the object model it available, or exclusively. From what you say it is the latter.
                                  • GrodanBundefined
                                    GrodanB @PaulHew
                                    @PaulHew said in Duet Web Control 2.1.1 released:
                                    @chrishamm
                                    Also strange is that with a dual set-up the loaded filament is moved from T1 to T0 and cannot be unloaded.
                                    (To be clear, T1 has a filament loaded, I do a pause, then immediately a cancel and suddenly T0 is loaded with T1 filament and that cannot be loaded to T1 again and T0 does not what to unload it. Temp settings is still on as espected on T1 (old temp) and t0 also as before...)
                                    I had to delete the file "filaments.csv" and do a "EMERGENCY STOP" to get T0 to relese the T1 filament...
                                    I think this happen when I cancel a print...
                                    Which I do a lot since I try to get my filament to stick.
                                    Would be nice to be able to cancel directly and not need to pause and then cancel...
                                    This time I do not see the "filament.csv" so I pray to god that a power on of cycle get my printer back...
                                    I did... the file was not shown until I made a power on/off cycle.
                                    That would be nice if it did.
                                    I also do not understand why the file "filament.csv" kept after a power cycle? At least a forced unload feature would be useful...
                                    • GrodanBundefined
                                      GrodanB
                                      For some reason I cannot change the wording mistake I did above (someServer.com identified post as spam)
                                      So a power OFF/ON did work...
                                      • smoki3undefined
                                        smoki3
                                        Is M122 working for someone?
                                        SIamundefined 1 Reply Last reply Reply Quote 0
                                          Thanks, I've already fixed the crash that occurs when a heater fault occurs and I'll fix the filament assignment next. Both fixes will be available when RRF 3.01 is released. Likewise the "Turn off all" button has been fixed and a new DWC version will be released among the next DSF version.
                                          GrodanBundefined 1 Reply Last reply Reply Quote 0
                                          • SIamundefined
                                            SIam @smoki3
                                            @smoki3
                                            M122 is working here
                                            6.4.2020, 20:32:50 	m122
                                            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC6 running on Duet WiFi 1.02 or later + DueX5
                                            Board ID: 08DGM-95BNL-MGPSJ-6J9FD-3SJ6N-K1W3Y
                                            Used output buffers: 4 of 24 (22 max)
                                            Static ram: 28052
                                            Dynamic ram: 94208 of which 24 recycled
                                            Exception stack ram used: 576
                                            Never used ram: 8212
                                            Tasks: NETWORK(ready,116) HEAT(blocked,1244) DUEX(suspended,136) MAIN(running,1608) IDLE(ready,80)
                                            Owned mutexes: WiFi(NETWORK)
                                            Last reset 11:14:43 ago, cause: software
                                            Last software reset at 2020-04-06 09:18, reason: User, spinning module GCodes, available RAM 8532 bytes (slot 3)
                                            Error status: 0
                                            Free file entries: 10
                                            SD card longest block write time: 133.8ms, max retries 0
                                            MCU temperature: min 21.7, current 39.7, max 41.7
                                            Supply voltage: min 24.0, current 24.3, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
                                            Driver 0: standstill, SG min/max 0/981
                                            Driver 1: standstill, SG min/max 0/1023
                                            Driver 2: standstill, SG min/max 0/1023
                                            Driver 3: standstill, SG min/max 0/1023
                                            Driver 4: standstill, SG min/max 0/1023
                                            Driver 5: standstill, SG min/max not available
                                            Driver 6: standstill, SG min/max not available
                                            Driver 7: standstill, SG min/max not available
                                            Driver 9: standstill, SG min/max 0/1023
                                            Date/time: 2020-04-06 20:32:48
                                            Slowest loop: 312.35ms; fastest: 0.12ms
                                            Hiccups: 0(0), FreeDm: 169, MinFreeDm: 107, MaxWait: 5922743ms
                                            === MainDDARing ===
                                            === AuxDDARing ===
                                            Heater 0 is on, I-accum = 0.0
                                            Heater 1 is on, I-accum = 0.7
                                            Segments left: 0
                                            Movement lock held by null
                                            HTTP is idle in state(s) 0
                                            Telnet is idle in state(s) 0
                                            File is idle in state(s) 0
                                            USB is idle in state(s) 0
                                            Aux is idle in state(s) 0
                                            Trigger is idle in state(s) 0
                                            Queue is idle in state(s) 0
                                            Daemon is idle in state(s) 0
                                            Code queue is empty.
                                            === Network ===
                                            Slowest loop: 789.12ms; fastest: 0.00ms
                                            Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(2) FTP(0) Telnet(0)
                                            HTTP sessions: 2 of 8
                                            - WiFi -
                                            Network state is active
                                            WiFi firmware version 1.23
                                            WiFi MAC address 2c:3a:e8:0b:06:33
                                            WiFi Vcc 3.44, reset reason Unknown
                                            WiFi flash size 4194304, free heap 15424
                                            WiFi IP address 192.168.188.36
                                            WiFi signal strength -49dBm, reconnections 0, sleep mode modem
                                            Socket states: 4 0 0 4 0 0 0 0
                                            === Filament sensors ===
                                            Extruder 0 sensor: ok
                                            Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                                            RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                                            Duet WiFi Server: 1.26
                                            Duet Web Control 3.4.0beta4 (2021-09-27)
